wild.blue(at)verizon.net Guest
Posted: Tue Feb 10, 2009 3:50 pm Post subject: Hydro lock |
Time: 01:56:39 PM PST US
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Subject: Re: Blackwell Exhaust
All true Nigel. But what happens if the piston is already on the
Compression stroke while pulling the prop through and there is
Sufficient oil collected in the combustion chamber when the piston gets
To close to TDC? Then it's too late for an opening exhaust valve to be
Of any benefit.
Dennis
Right you are, Dennis. "Clean" kits are no cure-all, either. If you feel
resistance, stop, pull plugs and drains. Surprising how much will sometimes
be in a cylinder, clean kit or not. DO NOT try to clear the cylinder by
pulling the prop backward--only pushes the oil into the intake manifold so
it gets a second opportunity to bend your rods or blow a jug off. Doubly so
with tailwheels.
Jerry Painter
Wild Blue Aviation
425-876-0865
JP(at)FlyWBA.com
www.FlyWBA.com
vectorwarbirds(at)aol.com Guest
Posted: Tue Feb 10, 2009 4:06 pm Post subject: Hydro lock |
We stock both electric and manual oil tank shut off valves for radials. We have never had oil in a cylinder since installing them on several aircraft. But that does not mean that we don't pull it through! The oil tank shut off valve will pretty much eliminate oil in the cylinders and hence hydraulic lock. My CJ never has more than two ounces in the exhaust cans even after sitting for weeks. Smartest thing you can do is install a shut off valve.
Gary 'Bunndini' Bunn
Vector Warbirds USA
Posted: Tue Feb 10, 2009 4:21 pm Post subject: Hydro lock |
I've seen several M-14's with these type valves installed and I could
not agree more. Sergei Boriak had one on his SU-31, and it worked
flawlessly.
Do you happen to sell a KIT? The problem I usually have come across is
the hassle of interfacing an American made valve with the Russian hoses.
Do you sell adapters, etc.,etc?
Mark Bitterlich
N50YK
Posted: Tue Feb 10, 2009 4:38 pm Post subject: Hydro lock |
Yes we can make up kits to fit anything, but just for your information the AN-12 303 hose fitting will fit the stock oil hoses and vise versa. We usually put the stock metric oil hose fitting on AN 303 hose and use a AN-12 on the other end to interface with the valve since AN fittings are easier to come by than metric. In other words there is no problem either way.
ChangDriver
Posted: Tue Feb 10, 2009 6:49 pm Post subject: Re: Hydro lock |
How much are they??
