akflyer
Posted: Thu Jan 29, 2009 10:23 am Post subject: Getting a replacement airworthiness |
Hey guys,
As you know I rebuilt a wrecked avid. I only had a copy of the airworthiness and not the original. The AI buddy that looked the plane over wont sign it off till I get an "original". This has been going on since November. Normally he said it was no big deal as he has gone through this before, he just filled out a form, faxed it in and magically the new airworthiness appears in the mail in a few weeks...
This time, they (FAA FSDO) have lost the fax 3 times. The FSDO has now decided that they need to send an inspector down to look it over before issuing a new one. Fine, come on down and look. Well they have canceled twice now (today being the second time). I told them I was not going to be held hostage and was going to continue to fly the plane anyway....
Have any of you guys been through this with the FAA just trying to get a replacement AW cert?
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
JetPilot
Posted: Thu Jan 29, 2009 10:42 am Post subject: Re: Getting a replacement airworthiness |
Leonard,
What was the damage to the Avid that your rebuilt ? Would you say rebuilding a wrecked plane took longer / was harder than building a new plane ?
Kolb MK-III Xtra, 912-S |
matronics(at)bob.brennan. Guest
Posted: Thu Jan 29, 2009 1:26 pm Post subject: Getting a replacement airworthiness |
It took six months to get a registration number for my imported UK Kitfox,
with minor obstacles; four months to get an AW Certificate with FAA-imposed
obstacles but it was expedited by a DAR who got $900 for his trouble; and I
just got my Repairman's Certificate after three months "processing" with
absolutely no obstacles at all. Even the FSDO said "expect to have to call
and ask when it will be done months from now".
Understaffed, underfunded, self-imposed problems, who knows - but the FAA is
definitely something you can't take for granted anymore, or expect anything
to go smoothly. Just my opinion of course, based on recent personal
experience.
You also might want to read "Disturbing incident with FAA" over on the Avid
forum at http://groups.yahoo.com/group/avid_flyer/message/21504 about
someone trying to replace a medical certificate that was in a lost wallet.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
akflyer
Posted: Fri Feb 06, 2009 10:13 am Post subject: Re: Getting a replacement airworthiness |
| JetPilot wrote: | Leonard,
Mike |
She was a basket case... I could have built the new kit faster than the repairs..
The good news is , I finally got the FAA inspector to come down and look at the plane. He stated that the reason he wanted to look at the plane was to determine it was the same one that had been wrecked. It has been common practice to swap data plates from wrecked planes to another to make a flying aircraft... this is not really legal and they are trying to crack down on it. Once I had the inspector in the garage he only spent about 20 minutes there, flipped through the book I put together showing all the photos from how I found the plane to the finished product. He said the documentation was outstanding, glanced over the plane for about 3 minutes then handed me the new airworthiness. He asked if i had flown the plane yet.... well the picture on the front of the book he had in his hand, was me staning in from of the plane out on the lake. I did what every good person should do at that point.... lied like a mofo. I said, "no sir, I have not flown the plane, I have just done an extended break in on the engine for the last 15 hrs". He smiled and said, good answer.
I was quite surprised at how helpful and nice the "enemy" FAA guy was. He was literally the nicest guy you could ever hope to meet!
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
7suds(at)Chartermi.net Guest
Posted: Fri Feb 06, 2009 12:01 pm Post subject: Getting a replacement airworthiness |
Leonard,
Have not been following this whole thread so I apologize if this has already
been covered. You mentioned that you got a new airworthiness certificate,
did you change the builders name on your data plate to your name or did it
remain as the original builder's name?
Lloyd Cudnohufsky
Model 5 Rebuild 912ul IVO IFA
Northern Mi.
JetPilot wrote:
| Quote: | Leonard,
plane ?
repairs..
plane, I have just!
Checked by AVG.
11:34 AM
akflyer
Posted: Fri Feb 06, 2009 12:14 pm Post subject: Re: Getting a replacement airworthiness |
| 7suds(at)Chartermi.net wrote: | Leonard,
Lloyd Cudnohufsky
Northern Mi.
I should have been more clear, it is a REPLACEMENT airworthiness cert. It is just lilke the original and has the original builders name, but it now has an R in the # to denote it as a replacement.
As a side note. The inspector told me to make a copy of it and keep on file so it would be easier to replace if need be in the future, however, he said an exact copy is illeagla to make. You must enlarge or shrink it when you copy it.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
Posted: Fri Feb 06, 2009 2:23 pm Post subject: Getting a replacement airworthiness |
If your copyright laws are anything like ours it must be enlarged a minimum
of 1.5 times.
I'm not sure about reduction but 60% seems to stick in my mind
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
