matronics(at)bob.brennan. Guest
Posted: Wed Feb 04, 2009 9:12 am Post subject: Insurance Question, for those that garage "hangar" |
James - I can answer the first part from personal experience. I keep my
Kitfox in my barn and trailer it to a local airstrip. I got my insurance
from Falcon through AOPA and I chose to have liability and hull since I
think I would be more likely to have hull claims but am aware that liability
claims against me could be financially catastrophic in my circumstances.
I don't recall being specifically asked about where the aircraft is stored,
only where it is "based", and for FAA reasons I call my base airport 8N7
even though I trailer to it to fly. I suppose because the FAA required I
declare a base airport for Airworthiness I didn't give it a second thought
about giving an airport to the insurance company and saying "yes" to
"hangered?" because it is stored under cover in my barn.
I re-trained (already had a "stale" US PPL) in my Kitfox without dual
brakes; in a taildragger on a grass strip brakes are not that important and
none of the FBO training microlights had brakes at all, but that was in the
UK where insurance was less specific and a *lot* less expensive.
Regarding your experience in a glider - I doubt your experience could be
applied to a taildragger rating but it should certainly help you keep to
minimum hours of dual instruction. Any applied experience according to the
FAA must be "in type", and I doubt anyone would accept a Kitfox as a similar
"type" to a glider. Just my opinion on that last point.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
Paul A. Franz, P.E.
Posted: Wed Feb 04, 2009 9:42 am Post subject: Insurance Question, for those that garage "hangar" |
On Wed, February 4, 2009 8:23 am, WurlyBird wrote:
| Quote: | First, AOPA says that none of their underwriters will insure my plane, even though I
only want liability, because I am hangaring it at my house and not an airport. Does
this make any sense?
My guess is someone is just reading information to you that specifically applies to
hull insurance. Get another person on the phone and emphasize from the start that you
only want to buy a liability policy.
Incidently, I'd check with your home owner's insurance carrier for specifics of having
an airplane in your garage. You may have some options such as extending fire insurance
coverage and you may also have an obligation to report such use of your garage. I
found there were some limitations on fuel storage.
| Quote: | Avemco gave me a quote but they never specifically asked where I
hangared the plane, could this be an issue in the future?
If they didn't ask, it apparently wasn't considered a significant risk influence. If
you buy hull insurance they do care. Secured in a hangar is a lower risk than outside
tiedown for example.
| Quote: | Secondly, Avemco said they would not insure me during the instruction phase because
there is only single brakes in the plane. Any suggestions on this one?
Get your instruction in a similar plane through PPL, then get clearance for dual
instruction in your own plane for check ride purposes. Explain to them that brakes
aren't needed for the check ride at all if that is necessary.
| Quote: | And one last thing that seems to keep coming across my mind; I have a glider rating
with 175 hours. At least 100 hours of that is in gliders that are set up in a tail
dragger configuration. They still have only one primary wheel and a smaller tail
wheel and the CG is significantly rearward of the main wheel. So does this time count
for insurance purposes?
Ask them. If you held a PPL or better, glider time and operations in a log book would
count as experience.
| Quote: | I realize that I do not taxi in the same manner as a power
plane, but we do have to ground taxi for a short while on take off and also on
landing, and depending on how far you want to push the glider this may be a very long
and complicated energy management taxi. Any thoughts?
As a practical matter, that glider experience will greatly reduce the time and
difficulty required to get your PPL. You still have to meet the minimums for
instruction time but that instruction can be devoted more to other things of interest
such as instrument flying, mountain flying, soft field and short field work.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Float Flyr
Posted: Wed Feb 04, 2009 10:37 am Post subject: Insurance Question, for those that garage "hangar" |
For the thousands and thousands of people that keep their bush planes on
lakes and grass strips outside their homes it makes no sense at all. Tell
them you fly out of the strip where you buy most of your fuel. Don't
mention storage. While the plane is being stored it is not covered for the
PLPD any way.
This is additionally strange as the closer you are to a large airport the
greater the chances you have of hitting something expensive if you have to
come down unwillingly. If you fly out of a strip in the boonies you may
have to fly an hour or two to find a decent target.
As for the dual brakes the insurance companies would like you to use a
spam-can to learn on. They have less accidents or so they say... BTW while
learning (dual) you are not the PIC the instructor is. He may have
additional insurance, for which he pays in spades, to cover the
instructional phase.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
jdmcbean(at)kitfoxaircraf Guest
James,
Try David McCoy at NationAir. http://www.nationair.com/
Fly Safe !!
John McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
davestapa
Joined: 13 Mar 2007 Posts: 30 Location: Woodstock, GA
Posted: Wed Feb 04, 2009 2:45 pm Post subject: Insurance Question, for those that garage "hangar" |
James, I just had a related question come up about insurance Monday. I am
losing my hanger because the guy I rent from wants it back. My only
option now is to store it at my office/warehouse and trailer it 7-10
miles to a closer airport. I am insured thru EAA (Falcon Insurance). Both
liability and hull. I called and asked about how it would affect my
insurance coverage. The answer was it wouldn't. They just want to notify
the underwriter as to which airport I am flying out of and wanted to be
sure it was stored indoors. It is even covered when trailering it to and
from the airport. Be sure and talk to your homeowners insurance co. I
have State Farm and they will not cover anything related to aviation,
period.
David Estapa
Woodstock, Georgia
N97DE S5TD 912ULS
On Wed, 4 Feb 2009 08:23:52 -0800 "WurlyBird"
<james.t.trizzino(at)us.army.mil> writes:
So I got my new toy home, thanks to the help of this forum, and now
I am looking to start flying it. Here are the two things I am
running into;
plane, even though I only want liability, because I am hangaring it
at my house and not an airport. Does this make any sense? Avemco
gave me a quote but they never specifically asked where I hangared
instruction phase because there is only single brakes in the plane.
a glider rating with 175 hours. At least 100 hours of that is in
gliders that are set up in a tail dragger configuration. They still
have only one primary wheel and a smaller tail wheel and the CG is
for insurance purposes? I realize that I do not taxi in the same
manner as a power plane, but we do have to ground taxi for a short
while on take off and also on landing, and depending on how far you
want to push the glider this may be a very long and complicated
Prospective Kitfox buyer
Here for information on airframes and engines
http://forums.matronics.com/viewtopic.php?p 28449#228449
WATCH THE EXTERMINATORS ON A&E
Wed Feb 4 10.30/9.30C join Billy tackling the worst pests imaginable
http://thirdpartyoffers.juno.com/TGL2141/fc/u4MuScM2GTJOD9BhN1BF2oLbFMs5INucB9J72KoDPowGaib4yMcCH/
_________________ C. David Estapa
Woodstock, GA
S5TD N97DE |
thesupe(at)hotmail.com Guest
Posted: Wed Feb 04, 2009 9:14 pm Post subject: Insurance Question, for those that garage "hangar" |
I've had insurance through AIG aviation C sold by Falcon Ins. Agency. If you are an EAA member C you get a discount. Give them a try. 1-866-647-4322 Jim Chuk Avid MK IV C Mn
| Quote: | Subject: Insurance Question C for those that garage "hangar"
Date: Wed C 4 Feb 2009 08:23:52 -0800
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil>
So I got my new toy home C thanks to the help of this forum C and now I am looking to start flying it. Here are the two things I am running into;
First C AOPA says that none of their underwriters will insure my plane C even though I only want liability C because I am hangaring it at my house and not an airport. Does this make any sense? Avemco gave me a quote but they never specifically asked where I hangared the plane C could this be an issue in the future?
Secondly C Avemco said they would not insure me during the instruction phase because there is only single brakes in the plane. Any suggestions on this one?
And one last thing that seems to keep coming across my mind; I have a glider rating with 175 hours. At least 100 hours of that is in gliders that are set up in a tail dragger configuration. They still have only one primary wheel and a smaller tail wheel and the CG is significantly rearward of the main wheel. So does this time count for insurance purposes? I realize that I do not taxi in the same manner as a power plane C but we do have to ground taxi for a short while on take off and also on landing C and depending on how far you want to push the glider this may be a very long and complicated energy management taxi. Any thoughts?
http://forums.matronics.com/viewtopic.php?p=228449#228449
Windows Live™: Keep your life in sync. See how it works. [quote][b]
