psm(at)att.net Guest
Posted: Tue Feb 03, 2009 8:05 am Post subject: XL available for Dual Instruction? |
I need to get a little dual instruction in an XL to activate my
insurance. I thought I might ask the list for an up to date summary
of planes in commercial service for training.
I know there is one in Northern California that belongs to Bob
Archibald. I believe it has dual sticks and a Lycosaurus engine. I
have heard rumors of one in AZ and another in FL, but I don't have
contact information for those or any others that might be available.
I would like to find an XL in Portland, OR with center stick, Jabiru
engine, and renting for $1 per hour including fuel and
instructor. I would appreciate any information that might help me
approach that goal.
Paul
XL getting closer.
johnd(at)data-tech.com Guest
Posted: Tue Feb 03, 2009 8:16 am Post subject: XL available for Dual Instruction? |
Hi Paul,
I just did my dual time with N130AW an AMD 601XL at the Flight School of
Gwinnett at LZU in Gwinnett GA (http://www.theflightschool.com/).
The plane seemed to be well maintained and the instructor, Eric
Jacobson, was a good guy. The plane was $95/hr plus $45/hr for the CFI.
John Davis
N601JD
Paul Mulwitz wrote:
engine, and renting for $1 per hour including fuel and instructor. I
would appreciate any information that might help me approach that goal.
Paul
XL getting closer.
Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Tue Feb 03, 2009 9:34 am Post subject: XL available for Dual Instruction? |
Paul and others,
There is also a 601XL available for training/rent in Holland Michigan. Here is their website for anyone interested:
http://www.tulipcityair.com/
Tailwinds,
Larry Hursh
Edwardsburg, MI
CH650 (N650LM Reserved)
Working on fuselage now
will be Corvair powered
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Gig Giacona
Posted: Tue Feb 03, 2009 12:21 pm Post subject: Re: XL available for Dual Instruction? |
| psm(at)att.net wrote: |
approach that goal.
Paul
XL getting closer. |
Paul, I've got the start of a list of rentable 601XLs that I have yet to get time to format an add to my website. I don't have the list handy but I don't remember one in the Portland area.
Also, pretty much all of the ones on the list have the Lyc engine.
Not to mention they charge a little more than the $1/hour.
And this isn't going to help you at all but I have recently found another 601XL that is on the rental line and has an instructor available in Vicksburg MS. This is by far the closest to me.
Here's the contact info for the archive.
Michael Nassour
Nassour Aviation, Inc.
P.O. Box 820744
Vicksburg, MS 39182-0744
601-415-3070
http://www.canufly.com/ mnassour(at)canufly.com
601XL Under Construction
lwinger
Posted: Tue Feb 03, 2009 12:34 pm Post subject: Re: XL available for Dual Instruction? |
On this topic, does anyone know about Silver Sky Aviation out of Chandler, AZ. I know they are listed as the Southwest distributor for Zenith, but I can't raise them on the phone. I believe they have close connection with League of Extraordinary Aviators for instruction in the 601XLs. Same story on no returned calls from LEA.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
PatrickW
Posted: Tue Feb 03, 2009 12:42 pm Post subject: Re: XL available for Dual Instruction? |
| lwinger wrote: | | does anyone know about Silver Sky Aviation out of Chandler, AZ. |
I flew with them a couple times, about a year ago. I haven't been able to make it down to AZ since then.
Here is their XL, which I believe is AMD serial number 1. Flies well.
http://picasaweb.google.com/Patrick.Hoyt/Airplanes#5143162406772451730
- Pat
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Tue Feb 03, 2009 1:54 pm Post subject: XL available for Dual Instruction? |
On Tue, Feb 03, 2009 at 12:21:09PM -0800, Gig Giacona wrote:
| Quote: | Also, pretty much all of the ones on the list have the Lyc engine.
Continental O-200, surely?
In any event, I'll be quite surprised to see any rental Zodiacs with the
Jabiru engine, since they'll be E-AB, and there are some fairly strict
limits on what can be done with them for instruction. (IIRC, you can only
instruct in them for transition training, and you have to have a waiver for
that.) There may be a very small number of E-LSA Zodiacs available for
instruction, but those would have had to have been registered through the
fat ultralight process, and that ended over a year ago. (The only one I can
think of might be the one at Dragonfly Aviation, and I'm not sure about
that.)
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Gig Giacona
Posted: Tue Feb 03, 2009 2:03 pm Post subject: Re: XL available for Dual Instruction? |
| jmaynard wrote: |
Continental O-200, surely? |
Yes, Continental. Not that it matters they are both over weight and underpowered and not engines manly homebuilders would choose for our custom built master pieces.
And Jay, I would in the future appreciate it if you would read what I mean instead of what I actually write.
Posted: Tue Feb 03, 2009 10:10 pm Post subject: XL available for Dual Instruction? |
Many thanks to all folks who responded.
It looks like it is California for me. I guess we currently have a
total of 4 locations for XL training now. It could be worse . . .
Paul
XL getting close
At 11:12 AM 2/3/2009, you wrote:
| Quote: | > I know there is one in Northern California that belongs to Bob
> Archibald.
He's also got a new one with an O200 which I had the pleasure to fly
about a month ago.
