Elevator Gap Seal Test Report (image missing)
Paul A. Franz, P.E.
PostPosted: Sat Jan 31, 2009 12:55 pm    Post subject: Elevator Gap Seal Test Report (image missing) Reply with quote
On Sat, January 31, 2009 9:55 am, Rexinator wrote:
So has anyone thought of applying tape top and bottom with the adhesive
fully contacting each other in the gap? Something like this: >-<
That's a great idea. Or sew two pieces of fabric together and dope the V's as Jan of
"JC Propeller Design" suggested. You could use two parallel rows of stitching spaced
the width of the gap.
It would be very difficult to do well unless you could design and
fabricate a special tool, but I think it could be done. I'm imagining
careful measurement of your gap and tape width then positioning the tape
on one side correctly such that it would allow the other side to be
applied and close all of the gap with no significant spaces or air bubbles.
Applying strips of peelable release to the adhesive, cut just right could make this
fairly straight forward.
I think a perfect tool might be a stiff rubber block shaped to follow
the half cross section of the intended gap seal. After the 1st side of
tape has been applied (bottom?) then the block could be clamped on that
side to hold the applied tape in the proper shape it would retain for
the gap if the other side was already installed. Then it should be
possible to lay the upper tape like positioning a large pre-cut decal.
Here's an attempt of a drawing of the cross section with the tape red,
block shape in black and a clamping bar in green.
Gap seal image
Your image/scan didn't come through. You might post it as an attachment or use the
forum interface.
Anybody following my attempt to describe this concept?
Would help to see your intended drawing/image.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
rexinator
PostPosted: Sat Jan 31, 2009 2:05 pm    Post subject: Re: Elevator Gap Seal (image not missing) Reply with quote
I guess my forum registration expired as I couldn't log in as I had in the past. It's been a while.
Here's the drawing I created for the gap seal idea.
gap seal drawing
 Filesize:  7.63 KB
 Viewed:  2565 Time(s)
