rwayne(at)gamewood.net Guest
Posted: Sun Feb 15, 2009 5:37 am Post subject: AML34 connectors |
What connectors should I use for the Honeywell AML34 rocker switches? The
common 1/4" Fast Ons are too loose. Thanks.
Wayne
Checked by AVG.
6:01 PM
Posted: Sun Feb 15, 2009 6:59 am Post subject: AML34 connectors |
Wayne Williams wrote:
Well, they shouldn't be. The problem may be in the connectors you're
using. Get some from an automotive supply place and compare the
thickness of the metal. Should be obvious.
You can crimp the 'curl' of the faston .... just be gentle, adn don't
overdo it ..... they're a b...h to push on of they're too tight!!!
Linn
Posted: Sun Feb 15, 2009 7:05 am Post subject: AML34 connectors |
You can crimp the 'curl' of the faston .... just be gentle, and don't
Linn
Jim Berry
Posted: Sun Feb 15, 2009 10:10 am Post subject: Re: AML34 connectors |
Wayne,
You want the AMP PIDG Faston with a 0.205" tab width. Aircraft Spruce #640917-1 for 22-18AWG. See page 470 for other wire gauges.
Jim Berry
40482
N15JB
Posted: Mon Feb 16, 2009 7:53 am Post subject: AML34 connectors |
Assuming you have the right width, I encountered the same problem with
some Faston's from McMasters. I have been able to give them a gentle
squeeze with pliers to tighten them up. As other's mentioned, it's easy
to over-tighten too.
Wayne
Checked by AVG.
6:01 PM
