		| Author | Message |
		| beach(at)digitalexp.com Guest
				|  Posted: Tue Mar 21, 2006 4:30 am    Post subject: Spark Plug Conversion |   |
 Mike Roehr
 beach(at)digitalexp.com (beach(at)digitalexp.com)
 I recently installed the "automotive" spark plug and wiring kit (as supplied by Dennis Saverese) in my Yak-52W.  Easier and quicker starting; smaller mag drops; smooth running during all phases of taxi and flight.  I'm also noticing possible small reductions in fuel flow at given power settings and weather conditions.  A bonus is the lack of clutter with the elimination of the wiring ring and the old wire shielding.  Future wiring maintenance will be much easier.  I'm pleased with the conversion.
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| dsavarese(at)elmore.rr.co Guest
				|  Posted: Tue Mar 21, 2006 4:35 am    Post subject: Spark Plug Conversion |   |
				| Thanks Mike.
Dennis
 [quote]   ---
		| Back to top |  |
		| napeone
				|  Posted: Tue Mar 21, 2006 5:23 am    Post subject: Re: Spark Plug Conversion |   |
				| I,also installed the plug conversion kit. Works as advertised and then some.
David H.
		| Back to top |  |
		| HawkerPilot2015
				|  Posted: Tue Mar 21, 2006 6:34 am    Post subject: Re: Spark Plug Conversion |   |
				| I start the conversion tomorrow!! It looks pretty tight behind that engine!! I am looking forward to some busted knuckles and Russian cuss words!!!
 I am glad to hear the reviews!!
 Yak-50
		| Back to top |  |
		| jsfox(at)adelphia.net Guest
				|  Posted: Tue Mar 21, 2006 6:59 am    Post subject: Spark Plug Conversion |   |
				| On Mar 21, 2006, at 9:34 AM, Tim Gagnon wrote:
  	  | Quote: |  	  | I start the conversion tomorrow!! It looks pretty tight behind that engine!! I am looking forward to some busted knuckles and Russian cuss words!!!
 Be patient, getting that ring off is a bitch. If you have a five year old that's good with a wrench his/her small hands will come in handy
  Also  Dennis is right - it's a lot easier to wire up the mag cover on a bench and then run wires. I did it the other way, ran the wires and then hooked into cover.  It's doable, but it adds time to the process. Also, and you may  already know this, but be careful when putting the cover back on, the high tension post in the mag is easier than you think to bend and crack. Trust me, I found out the hard way.
 And lastly, the clamps holding the wires on my plane where all single slot screws - another pain. Once I had the clamps off I tossed the screws and replaced with a slightly longer phillips head. This makes putting the clamps back on much easier.
 However, once you are done and your hands look like you've been working in barbed wire factory, you'll love how your plane runs, start and the cost of replacing a plug should you ever have to.
 Have fun!
 Steve Fox
		| Back to top |  |
		| BitterlichMG(at)cherrypoi Guest
				|  Posted: Tue Mar 21, 2006 12:57 pm    Post subject: Spark Plug Conversion |   |
				| I'd  strongly advise purchasing .... sheesh,. what is the official name of this  tool?  It's a 1/4" or 3/8" drive socket that has a universal joint built  right into the back of it.  ANYWAY, there are two types, one has an actual  universal type knuckle joint built in right behind a SHALLOW socket (important  that it is shallow) and the other BETTER type is one that uses a kind of hex  ball in a round socket universal joint, again built in right behind a shallow  socket.  Forget about using a normal socket "connected to" a universal....  it's too darn long/big for the worst ones.
 I am  sorry for being vague and not remembering the metric size off the top of my  head, but this tool coupled with a long extension makes getting the "ring" off a  LOT easier, saving a lot of knuckles and also a lot of cursing and  muttering.
 Just  an observation from one who helped do a few without this tool, and then one  with.  Night and day difference.
 Mark  Bitterlich
 N50YK
 [quote]   --
		| Back to top |  |
		| dstroud(at)storm.ca Guest
				|  Posted: Tue Mar 21, 2006 1:35 pm    Post subject: Spark Plug Conversion |   |
				| Anyone know if you save much weight  by the conversion?
 David Stroud   Ottawa, Canada
 C-FDWS  Christavia
 Fairchild 51 early construction
 [quote]   ---
		| Back to top |  |
		| gus.fraser(at)gs.com Guest
				|  Posted: Tue Mar 21, 2006 1:44 pm    Post subject: Spark Plug Conversion |   |
				| A little because you remove the metal ring all together,  but I would say that you would better affect the W&B by avoiding that next  burger, the difference is not great.
 Gus
 [quote]         From: owner-yak-list-server(at)matronics.com    [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of david    stroud
 Sent: Tuesday, March 21, 2006 4:33 PM
 To:    yak-list(at)matronics.com
 Subject: Re: Re: Spark Plug    Conversion
 C-FDWS  Christavia
 [quote]     ---
		| Back to top |  |
				|  Posted: Tue Mar 21, 2006 3:44 pm    Post subject: Spark Plug Conversion |   |
				| It's an 11 mm nut that has to be removed and  reinstalled.  1/4 drive with a nice 9" or so extension works  perfectly.  1/4 drive universal is also very handy.
Dennis
 [quote]   ---
		| Back to top |  |
				|  Posted: Tue Mar 21, 2006 3:52 pm    Post subject: Spark Plug Conversion |   |
				| Weight savings is less than 5 pounds.  Not enough to make  a difference.
Dennis
 [quote]   ---
		| Back to top |  |
		| HawkerPilot2015
				|  Posted: Sun Mar 26, 2006 8:18 pm    Post subject: Re: Spark Plug Conversion |   |
				| Its on (but not wired into the mag yet) and no busted knuckles but there were a few foul words. Mostly self induced issues but you learn quickly not to make the same mistake twice.
Nice setup and easy to do. We had less than five hours in the installation with a stop for lunch and a little Yak airshow!!
 Thanks to Jay Hodge and Kurt (our A&P and IA) for the help! Actually I think I was helping them....
		| Back to top |  |
