| brian
				|  Posted: Mon Mar 27, 2006 8:57 am    Post subject: Slick-start on M14P and Housai mags |   |
				| A. Dennis Savarese wrote:
  	  | Quote: |  	  | <dsavarese(at)elmore.rr.com>
 Some of the TW's which have the centrifugal advance M9-35 mags had the
 Slick Start shower of sparks installed.  But not all of them.  The
 "sissy yaks" as I call them solve the air start problem by installing
 the electric starter on the nose case.  When no shower of sparks system
 is installed, it makes starting the M14PF much easier.
 Cranking speeds, even with an electric starter, are very marginal for
 getting a spark from a magneto unless you have either a starting
 vibrator ("shower of sparks"), an HT boost coil (stock CJ6A and
 Yak-52 system), or an impulse coupling to increase the rotating speed of
 the mag for starting.
 The solid-state vibrator (Slick-Start) strikes me as the most elegant
 compromise if you want to have a magneto ignition system.
 Brian Lloyd
 brian HYPHEN yak AT lloyd DOT com
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
 Brian Lloyd
 brian-yak at lloyd dot com
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
