Canopy repair (was)
tonyplane(at)bellsouth.ne
PostPosted: Wed Jan 28, 2009 12:51 pm    Post subject: Canopy repair (was) Reply with quote
Randall,
Yes
Methylene Chloride, Trichloroethylene, as per the info on .IPS -Weldon 3 "Clear, Water Thin, Very Fast Curing Solvent Cement" with a Plexiglas patch (Plexiglas from Lowe's), .
See page 71 of latest ACS Catalogue; also Section 3 of AC 43.13-1B "Acceptable Methods, Techniques, and Practices Aircraft Inspection, Repair & Alterations"
I procured the solvent cement from ACS, but could not find it in their current catalogue (may have been owlgored) - you may wish to call them if you can not get it, or see if Home Depot or Lowes carries it.
I used a very fine hypo (you can get one from Wal-Mart or probably any pharmacy - the kind used by insulin users) to wick the cement between the patch and canopy, after stop drilling the crack.. The bond is pretty optically clear if done right.
Hope this helps
Tony Graziano
601XL/Jab3300; N493TG; 464 hrs
 Filesize:  569 Bytes
 Viewed:  2194 Time(s)
randy(at)rjhebertassoc.co
PostPosted: Wed Jan 28, 2009 2:40 pm    Post subject: Canopy repair (was) Reply with quote
Thanks Tony I just wasn’t sure it was doable.
Randall J Hebert
Randall,
Yes
 Filesize:  569 Bytes
 Viewed:  2193 Time(s)
