Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Thu Jan 29, 2009 8:39 am Post subject: Sport cruiser wing [OFF LINE RESPONSE] |
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
Last edited by Terry Phillips on Thu Jan 29, 2009 10:12 am; edited 1 time in total |
Afterfxllc(at)aol.com Guest
Posted: Thu Jan 29, 2009 9:36 am Post subject: Sport cruiser wing [OFF LINE RESPONSE] |
(I'd appreciate if you do not quote this message on the lists. Thanks.)
It's a little late for that but it has happened to us all I think.
Kev
I have seen drawings and photos of the SC wing. Yes, clearly it is a
derivative of the 601XL wing. No question of that. However, I'm unaware of
any patent on the 601XL wing design, so there would be no patent
infringement. Plus, I'm sure that if there was any violation of an
intellectual property agreement between Zenair and CZAW, then Zenair
lawyers would have them in the courts. I haven't heard of any sign of that.
While I have never seen detailed construction drawings of the SC wing,
IMHO, CZAW produced the design that Zenair should have copied for the 650.
The SC wing addresses several shortcomings in the 601XL wing. The spar root
is significantly stronger and the center spar is reinforced. The ailerons
are not balanced and (I believe) are cable operated. However the flap and
aileron designs are significantly different from the Zenair
design--particularly the hinging. I think the ailerons should be balanced.
But, if and when there are significant SC numbers flying, we'll see if the
wings start falling off. That is the ultimate test.
The biggest differences between the SC and the CH601XL designs, again,
IMHO, is that the CH601XL was designed to allow scratch building from
plans. The SC would require machined aluminum parts. But that's not all
bad. A friend is building a Waiex. He told me that the Waiex can be
completely scratch built--except for the wing spar caps. If you are going
to use their plans, you must buy their spar caps, and they are pretty
complex pieces. The Waiex spar caps are about what the 601XL needs (see
attached photo). Instead we have a spar cap with doubler composed of 0.25 x
1.5" 6061-T6 bar. Very little chordwise stiffness. Even the HD and HDS at
least had an extruded angle for the spar cap. Oh well, we pays our money
and we takes our chances.
Perhaps when you have a holiday you could take a drive over to Brno and
take a CZAW plant tour. Take your camera and take lots of photos. CZAW has
some pretty sharp folks with some good ideas, and the Zenair community
could benefit from what you learn.
Regards, Terry
At 06:23 AM 1/29/2009 -0800, you wrote:
| Quote: | Does anyone know if the ailerons on the sport cruiser are balance ? And if
they are cable operated?
IF the answers are no and yes then I consider it a straight rip off of
the 601 wing.
Look at the picture in this link and see what you think. spare angle ,
rear spar look identical.
http://www.spriteaviation.co.uk/howcome.html?Button1.x=75&Button1.y=6
If link does not work google sprite aviation services.
My point is why then did this pass LAA test and the XL needs this work?
Kev
Austria ............
A Good Credit Score is 7001028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
alex_001
