Tim Olson
Posted: Tue Jan 27, 2009 7:39 am Post subject: Ameri-King AK-451 ELT |
Have any of you builders installed the AK-451 yet? I have
the old AK-450 right now, and want to go to 406Mhz for an
ELT (I already carry a 406 PLB with GPS integration).
I just want to verify that the standard AK-451 ELT model
has the inputs to accept GPS from an external aviation GPS.
I know they sell some much more expensive ones with
INTEGRATED GPS and it's own antenna, but from what I understand
from a little reading, I think the AK-451 supports external
GPS for no extra cost, whereas other companies make you pay
more for the ability to accept an external GPS. I would
buy and install it right away if I knew it supported that
feature, as it would fit in my existing mounting.
I emailed the company but got nothing back. Thought maybe
one of you had experience with it already.
steveg(at)redmondair.com Guest
Posted: Tue Jan 27, 2009 8:22 am Post subject: Ameri-King AK-451 ELT |
It looks like you have to order the ELT with the GPS option, which adds to
the cost; even though I think it is a worthwhile expense. What price does
on place on their life or the closure for loved ones?
Steve Graves - Avionics Tech
Kelly McMullen
Posted: Tue Jan 27, 2009 8:38 am Post subject: Ameri-King AK-451 ELT |
Not what the brochure shows, that I just sent the list. Looks like
standard RS232 interface.
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Tim this brochure gives the detail you want. It looks like some
dealers have very good discounts on this unit, under $600
http://www.seaerospace.com/lc/cart.php?target=productDetails&model=AK-451&substring=ak-451
On Tue, Jan 27, 2009 at 8:33 AM, Tim Olson <Tim(at)myrv10.com> wrote:
AK-451-7.pdf |
198.88 KB |
1144 Time(s) |
KCHD |
ScooterF15
Posted: Tue Jan 27, 2009 9:09 am Post subject: Ameri-King AK-451 ELT |
I have also been looking at the AK-451 and I'm waiting for a response from the company as well. I'd like to know whether this unit will fit on the same mounting tray and use the same remote unit/wiring as the AK-450 that I already have. They look very similar but I'd like to know for sure.
-Jim
N312JE - Doing the second annual
On Tue, Jan 27, 2009 at 7:33 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Tim Olson - RV-10 N104CD -======================
ownload, 7-Day Browse, Chat, FAQ,
ef="http://www.matronics.com/Navigator?RV10-List" target="_blank">http:=====
Posted: Tue Jan 27, 2009 9:46 am Post subject: Ameri-King AK-451 ELT |
ELT SET 406 WHIP & PORT ANT (AK-451-2) has no GPS interface
ELT SET 406 WHIP & PORT ANT w/GPS (AK-451-6) has GPS interface
If you order the basic lower priced AK-451-2 thinking you can interface it
to the GPS, you will be very disappointed. There is a considerable price
difference.
dlm46007(at)cox.net Guest
Posted: Tue Jan 27, 2009 9:53 am Post subject: Ameri-King AK-451 ELT |
You might want to consider the ACK E04. http://www.ackavionics.com/ It uses
the existing AK 450 remote wiring and will accept NEMA0183 format GPS
signals.
Tim Olson
Posted: Tue Jan 27, 2009 10:23 am Post subject: Ameri-King AK-451 ELT |
Good question... I guess I have to look at each life individually
to come up with a valuation. For instance, my older daughter
is kind of sassy. I put her at 3 million. My younger one is
still pretty sweet, so for the time being, I'll consider her
4 million. My wife, although very very nice, she's already
approaching half of her useful life...so I'll only go 2 mil on
her. Now me, I don't think I'd put myself anywhere over a million,
unless I can get in better shape. If I lost a few lbs and
maybe buffed up a bit, I might be worth more.
Ok, being serious now....
Kelly, that is great pricing. It does seem to be well below the
standard. The thing is, I am having a hard time really
trusting all the websites that basically list the promo features,
but don't identify the specific models. Now, in that page's case,
you'll notice that the part number is AK-451-PLB (P-ELT)
So it's really a PLB, not a legal ELT, that needs to be the
"AF" Automatic Fixed type. So sure, it would be fine for
signalling, but not legal as an ELT. The pricing I'm seeing
for the real AF type seems to be in the $850 range from most
places. But, there again, there are so many higher priced models
that it's hard to see what features are truly with that model.
Here is one of my purchase options:
http://www.skygeek.com/ameri-king-ak-451-406-mhz-elt.html
I can answer at least part of Jim's question though...
Jim, there is a bracket adapter that they have available
for mounting a 451 in the 450's tray. And, I think
I've seen/heard that the remote wiring is the same.
That's what did it for me. Also, I did at one point hear
that they were going to offer upgrade pricing...in my
email to them (that they haven't answered) I asked the
question, so I hope it is true.
Oh well, maybe I should get on the phone or email daily.
Posted: Tue Jan 27, 2009 10:42 am Post subject: Ameri-King AK-451 ELT |
RETROFIT INSTRUCTIONS FROM AK-450 TO AK-451
Old Model No.: AK-450-(AF)(AP), ELT 121,5/243 MHz, FAA TSO C91a approved.
New Model No.: AK-451-(AF)(AP), ELT 406/121,5/243 MHz, FAA TSO C126/91a approved.
RETROFIT INSTRUCTIONS:
1. Swap the followings items: ELT with mounting tray; Antenna with Coaxial Cable; Remote Switch Unit with Buzzer.
Note 1: All mounting holes and cut out holes are exactly the same.
Note 2: Wiring Harness, between ELT and Remote Switch Unit, is exactly the same i.e. Do not change the wiring harness. It is OK to use the existing AK-450 wiring.
Note 3: Adding a new Buzzer to be mounted anywhere in the cockpit, i.e. Tie wrap into the aircraft Wiring Harness, or Fasten onto or behind the instrument Panel, or fasten on the Remote Switch Unit.
2. Register with NOAA (or IBRD) (or National) via on line, or mailing the Registration Form using the provided pre-stamped envelop.
QUICK OPERATION CHECK:
Main Switch (at) ON position: Same as the AK-450, except you will see the LED lights flashing and Buzzer sound (1 second ON, 4 seconds OFF), in lieu of steady ON. (This is to save Battery Power for the LED Lights and Buzzer).
Main Switch (at) ARM position: You will see the 2 LED lights illuminate and Buzzer sound, for 4 seconds, then extinguished.
Wait for additional 20 seconds, then Press the ON Switch on the Remote Switch Unit, ELT swept Tone must be heard on the VHF Radio (at)121.5 MHz.
The 2 LED lights flashing (1 second ON, 4 seconds OFF), synchronized with the Buzzer sound (1 second ON, 4 seconds OFF).
Press the RESET Switch on the Remote Switch Unit.
Leave the Main Switch (at) ARM position at all times
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James McGrew
Sent: Tuesday, January 27, 2009 8:59 AM
Subject: Re: Ameri-King AK-451 ELT
-Jim
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Tim Olson
Posted: Tue Jan 27, 2009 11:32 am Post subject: Ameri-King AK-451 ELT |
Steve,
Not trying to doubt you, but...
Do you have personal experience with those units, or are you just
showing what you find on websites? That's what is so confusing
is that depending on where you look, they talk about GPS
interfaces on most all of the models. And there just isn't
good consistency in promo material.
Looking at these 2 sheets, I can't even see a difference:
http://www.edmoap.com.au/modules/products/xarimages/PDF/AK-451-2.pdf
http://www.edmoap.com.au/modules/products/xarimages/PDF/AK-451-6.pdf
Pricing is easily seen here:
http://www.chiefaircraft.com/airsec/Aircraft/ELT/Ameriking.html
But again, none of the explanation in the lower half of the
page really explains that there are models that DO NOT
have GPS integration. Some sites even make it sound like
it has onboard GPS.
So I just hoped to talk to someone with personal experience,
not just from reading the web....because if someone else
ordered a AK451-2 and got burned, certainly they would
know.
As David pointed out, there is the ACK E-04 coming
out too. But, they still show on their website that
they are not taking orders until it's TSO'd.
http://www.ackavionics.com/index.html
Now, in my personal situation, there is still a significant
difference between the E-04 and the AK-451, even if both
accept GPS. The E-04 says it will accept a NEMA-0183 GPS
position....where the ACK doesn't say it will. I have a
perfectly positioned (wiring wise) NMEA-0183 GPS that
would be really handy to plug in. And, if the MSRP holds
true at $599, this one would sure be the way to go.
It sounds like best case, the E-04 will be available in
late March to mid-april.
difference.
Posted: Tue Jan 27, 2009 12:29 pm Post subject: Ameri-King AK-451 ELT |
After forwarding the ACK E04 diagram I called to confirm its meaning. The
external GPS hook up requires 4 wires. Power, ground, GPS in/out. The out
need only be used to verify on initial install that the E04 is receiving the
GPS data properly. It can then be discontinued. This would allow Y ing the
GPS out to the normal EFIS input and into the ELT to constanly update
position.
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Jan 27, 2009 12:31 pm Post subject: Ameri-King AK-451 ELT |
I talked with Keith at AmeriKing and what Steve says is correct. The cheaper unit cannot be interfaced with any GPS. The more expensive one does not have an onboard GPS and must be hooked up to an external GPS. Given the Ameriking prices I would wait for the ACK E04 that is cheaper than either AmeriKing unit and accepts GPS data.
Michael
Kellym
Posted: Tue Jan 27, 2009 12:48 pm Post subject: Ameri-King AK-451 ELT |
You are probably correct. From their brochure, if what you say is true,
I would call it deceptive advertising. I would interpret the w/GPS to
actually have a built-in GPS, as opposed to just an interface. BWTFDIK.
Sure would be nice if the literature were clearer on the available options.
difference.
KCHD |
msausen
Posted: Tue Jan 27, 2009 12:52 pm Post subject: Ameri-King AK-451 ELT |
Kelly,
There are lots of different versions which doesn't help the confusion. The model that is found for around $500 is probably the PLB model which only comes with a whip and doesn't even contain a "G" switch.
Michael
Posted: Tue Jan 27, 2009 1:04 pm Post subject: Ameri-King AK-451 ELT |
Is 36 years as an avionics technician enough experience?
msausen
Posted: Tue Jan 27, 2009 1:29 pm Post subject: Re: Ameri-King AK-451 ELT |
Kelly wrote:
Steve wrote:
I agree and had the exact same thought as you Kelly. Even had an email T'd up to that effect when I slapped myself and remembered this old thing sitting in front of me with a bunch of numbered buttons on it. I punched a few of them and was talking (loosley defined as I wouldn't call what I was hearing english) to their tech guy. Either way he was very clear on the differences between the units and that only the expensive one could take GPS data.
And Steve, I certainly wasn't disregarding what you were saying but I also wasn't sure if you were quoting direct experience or the brochure as it really could have been interpreted either way. As the old saying goes, trust but verify.
Michael
Tim Olson
Posted: Tue Jan 27, 2009 1:43 pm Post subject: Ameri-King AK-451 ELT |
Thanks for reporting. I got basically that info just a bit
ago offline as well. That turns their stuff from being
a fairly decent offering to being out of this world in
pricing. Given the ability to use my wiring with an
ACK E-04, and the flexibility of NEMA-0183 GPS, AND the
pricing being $599, I think that's my plan as well.
I plan to do some international flying in the near future,
and while it's not required for this trip, and I probably
won't have it for the trip, I see no reason to just leave
a plain old 121.5Mhz system as my only ELT. I have a PLB
that should work fine, and that has GPS in it too. Given
the combo, searchers should be able to find both the
plane, AND a moving group of hikers (or floating group of
swimmers) if we take the PLB portable. Assuming, of
course, that I crash.
RV Builder (Michael Sausen) wrote:
<rvbuilder(at)sausen.net>
Michael
Tim Olson
That's very cool that they have an In and an Out. Right now
I have a GPS signal split that goes to my APRS, also, so in the
case of the ELT, I'll probably change the APRS so that the ELT
gets the GPS signal and then outputs it to the APRS. It should
be almost nothing to change my wiring to support that plan.
Thanks for the update David.
position.
n212pj(at)gmail.com Guest
Posted: Tue Jan 27, 2009 2:28 pm Post subject: Ameri-King AK-451 ELT |
When is the 406 required in Canada? I thought it might already be, and I
thought that a PLB was not enough for them.
John Jessen
Tim Olson
Posted: Tue Jan 27, 2009 2:30 pm Post subject: Ameri-King AK-451 ELT |
No, that's great. I wasn't doubting you...it's just there
is so much fuzzy info I wanted to know if you saw it firsthand....
not just that you saw it on the web. Sounds like you must
have firsthand experience with them.
