K Dilks
vvkidd(at)mindspring.com Guest
Posted: Mon Jan 26, 2009 5:34 am Post subject: Whats your weight ? |
CH601XL, N922VK, CRW, Charleston, WV
Empty Wgt 806 lbs
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Jan 26, 2009 5:44 am Post subject: Re: Whats your weight ? |
N554SG Empty Weight Data:
601XL, 2006-2008 regular kit built
ZAC tri-gear legs, no wheel pants, ZAC lighting package, wing lockers
Jabiru 3300, Sensenich wood prop
Dynon D180, Garmin 296, Icom A-200, Garmin GTX-327, Whiskey Compass
Y-Stick, hand-made comfor-foam seats covered in marine vinyl, King ELT
Polished finish, no paint
Empty Weight = 749 lbs.
Nose = 218 lbs.
Right = 259 lbs.
Left = 272 lbs.
Actual numbers recorded on digital automotive scales rotated between different tires to assure repeatability.
_________________ David Gallagher
Cincinnati, OH area
jaybannist(at)cs.com Guest
Posted: Mon Jan 26, 2009 5:50 am Post subject: Whats your weight ? |
Dry weight - 840 lb
Take-off weight - ~1120 - 1310 lb
Corvair 2700
Two Blade, 66" Warp Drive Prop
Single axis Autopilot
Airspeed Indicator
Altimeter
Vertical Speed Indicator
Compass
Garmin GPS 296
ICOM IC-A200 Trasceiver
Narco AT50A Transponder
Dynon EMS-D10
Clock
Softcomm ATC-2P Intercom
ACK Model E-01 ELT
Tri-Gear
No wheel fairings
Dual sticks
Minimal paint
Jay Bannister
Zodiac CH 601XL
N2630J "Lil Bruiser"
Dallas, TX
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Mon Jan 26, 2009 6:05 am Post subject: Whats your weight ? |
Empty weight: 850 pounds
Takeoff weight: 1100-1320 pounds
O-200 engine
Sensenich W68ZK57G wood-composite prop
Electric gyros (standard six pack)
TruTrak IIVSG two-axis autopilot
Garmin stack: GNS430W GPS/nav/com with CDI, SL40 com, GTX330 transponder,
GMA340 audio panel, GPS496 backup/XM
Dynon EMS-D10
ACK E-01 ELT
Tricycle gear
Wheel pants
Dual sticks
Piano hinge ailerons
Aileron trim
Pretty paint job
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
jmaynard
Posted: Mon Jan 26, 2009 6:10 am Post subject: Whats your weight ? |
On Mon, Jan 26, 2009 at 08:00:03AM -0600, Jay Maynard wrote:
| Quote: | Empty weight: 850 pounds
Forgot...nose wheel 292, right wheel 269, left wheel 289 pounds.
I played with the numbers a while back...it's just about impossible to load
my Zodiac out of the allowable CG range aft, and not too hard to get out of
the forward end of the range with full fuel (especially if I'm solo).
bryanmmartin
Posted: Mon Jan 26, 2009 9:48 am Post subject: Whats your weight ? |
Empty weight: 815 lbs
Normal TO weight: About 1200 lbs
Subaru EA81 with Stratus redrive
Warp Drive three blade prop
full six-pack with electric gyros
Garmin GNS 430
Mid-Continent CDI
Microair 760 com
PMA 4000 audio panel
King KT-76A transponder
blind encoder
AK 450 ELT
15 lb battery behind passenger seat
aileron and elevator trim
nav and strobe lights
dual landing lights
hot water cabin heater
sound/thermal insulation throughout the cabin
<kevin.dilks(at)liwest.at>
Ok I mean your XL!
Empty and normal take off weights .
Equipment fitted
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
