daveleikam(at)wi.rr.com Guest
Posted: Sun Jan 18, 2009 9:30 pm Post subject: AOA CPU |
For those who have installed an AFS AOA, where did you mount the CPU?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
wayne.e(at)grandecom.net Guest
Posted: Mon Jan 19, 2009 4:22 am Post subject: AOA CPU |
Hi Dave,
I built a shelf and mounted it up under and to the rear of the instrument panel.
Wayne Edgerton N602WT
Time: 09:30:59 PM PST US From: "Dave Leikam" <daveleikam(at)wi.rr.com (daveleikam(at)wi.rr.com)> Subject: AOA CPU
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
rene(at)felker.com Guest
Posted: Mon Jan 19, 2009 5:14 am Post subject: AOA CPU |
Subpanel, behind GRT displays……
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Sunday, January 18, 2009 10:29 PM
To: RV-10 matronics
Subject: AOA CPU
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
hotwheels
Posted: Tue Jan 20, 2009 8:21 am Post subject: Re: AOA CPU |
Subpanel photo attached... The AOA CPU is in the lower left hand corner. The AL angles used were 1"x1" (trimmed one side) as the AOA screw holes didn't line up to be able to use 3/4 x 3/4 angle without cutting yet another subpanel hole.
Jay
609.46 KB |
367 Time(s) |
