naumuk(at)windstream.net Guest
Posted: Tue Jan 20, 2009 7:22 pm Post subject: Ground block |
All-
B+C recommends installing the panel ground block on the firewall, but I've got the header tank in the way.
Is mounting the ground block near the panel, then running a braided ground cable to one of the motor mounts a workable alternative?
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
Gig Giacona
Posted: Wed Jan 21, 2009 6:34 am Post subject: Re: Ground block |
I've never looked behind the panel on a 601 with a header tank. But, could you not move the ground block closer to the floor?
601XL Under Construction
Rhino
Posted: Wed Jan 21, 2009 1:41 pm Post subject: Re: Ground block |
| naumuk(at)windstream.net wrote: | B+C recommends installing the panel ground block on the firewall, but I've got the header tank in the way.
Is mounting the ground block near the panel, then running a braided ground cable to one of the motor mounts a workable alternative? |
Yes. From Zenith's web site:
| Quote: | | Another method of grounding is to use a common grounding bus bar. This bar can be located under the instrument panel and used to connect all ground wires from equipment throughout the aircraft. This is referred to as a central grounding point. The grounding bus bar is grounded to the engine of the aircraft. In this case two wires must be run to each piece of equipment - the power wire and the ground wire. This type of grounding is more common in composite and wood aircraft. Both of these aircraft require some form of ground other than their airframe. Wood and composite material do not conduct electricity. |
http://www.zenithair.com/kit-data/ra/electric2.html
_________________ Bob Simmons
CH 750
N750TN (reserved) |
bryanmmartin
Posted: Wed Jan 21, 2009 2:01 pm Post subject: Ground block |
I just ran a cable from my engine block to the brass bolt on my
grounding block. My battery is behind the passenger seat, so I also
ran the battery negative cable to that bolt. That way there's fewer
connections to maintain. I have my grounding block mounted on the
firewall, but there's no reason it can't be mounted elsewhere as long
as everything gets bonded to that point.
If your battery is mounted ahead of the firewall, it might be better
to run the negative cable directly to the engine. Then you can run a
much smaller cable from the engine or battery to the grounding block.
On Jan 20, 2009, at 10:21 PM, Bill Naumuk wrote:
| Quote: | All-
alternative?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
jlatimer1(at)cox.net Guest
Posted: Wed Jan 21, 2009 2:36 pm Post subject: Ground block |
Bill,
Here are some photos of what I'm doing with the ground block and header
tank.
Jerry
592.17 KB |
616 Time(s) |
447.23 KB |
610 Time(s) |
Posted: Wed Jan 21, 2009 3:38 pm Post subject: Ground block |
Gig-
I could, but then I'd have all my ground wires out in the open and right
at foot level.
Bill
Posted: Wed Jan 21, 2009 3:39 pm Post subject: Ground block |
Bob-
I love it when someone has an answer I want to hear!
Bill
Posted: Wed Jan 21, 2009 4:02 pm Post subject: Ground block |
Jerry-
That's exactly what I was going to do originally. What really got me
thinking was watching the HomebuiltHelp Glass Panel DVD I got for my last
Matronics donation.
Mark used a prebuilt terminal and switch unit for all his connections,
and it's mounted in the panel. The whole DVD is shot with the panel on the
bench, so it's not clear if additional grounding is necessary. It just makes
sense to ground it to the engine somehow.
I just don't like the idea of having all your ground wires out in the
open, ready to get snagged by a passenger. I might know exactly how to
weasel my way into the cockpit without doing any damage, but just about any
flying builder I've talked to can relate to the damage a newbie can do.
Bill
Posted: Wed Jan 21, 2009 5:52 pm Post subject: Ground block |
I was worried about the same thing but I've tried to kick the firewall
while sitting in the plane and have not been able to. My legs won't
reach and I'm 6 ft tall. So I went ahead and installed it this way. I
also thought about the method in your previous method but decided to do
it this way. After all these are experimentals and we are learninig
righte.
Jerry
On Wed, Jan 21, 2009 at 6:11 PM , Bill Naumuk wrote:
<naumuk(at)windstream.net>
Jerry-
me thinking was watching the HomebuiltHelp Glass Panel DVD I got for
my last Matronics donation.
Posted: Thu Jan 22, 2009 5:56 pm Post subject: Ground block |
Jerry-
Everything's a tradeoff. I guarantee you'll find something you don't
like about the way you set your project up, and I'll do the same. Oh, well,
we'll get it right next time!
Bill
