Paul A. Franz, P.E.
Posted: Mon Jan 19, 2009 5:29 pm Post subject: Lovely tailwheel |
On Mon, January 19, 2009 4:42 pm, gary.algate(at)sandvik.com wrote:
some clippage...
| Quote: | OK Gents here are two fotos (before) and after.
The King Pin is now basically vertical (as on old setup), plane tracks
beautifully, no shimmy (I couldn't help myself so I played hooky and went
for a couple of circuits) and it unlatches with a tap of the brake and
full rudder.
The adapter you made to straighten up the king pin angle adds a little length. Is this
increased moment arm going to be alright? That effectively softens the spring rate and
raises the tail slightly.
| Quote: | I'm sure there is more to this than any one contributing factor and it
probably also relates to the stance of the plane. (Mine has tube gear).
That appears to be the case. I now believe that a vertical king pin is ideal but if
there is a shimmy tendency, putting in a small positive angle will work in your favor.
| Quote: | Thanks to all for your help on this as once again with everyone's help a
problem has been solved and hopefully others can use the info
You certainly did nice work.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
gary.algate(at)sandvik.co Guest
Posted: Mon Jan 19, 2009 6:03 pm Post subject: Lovely tailwheel |
The spring rate is definitely softer but that's probably not a bad thing.
If necessary I can put the adaptor in a press and decrease the angle, but at the moment it appears to be pretty close to optimal for my plane.
Question to the list - does anybody know where the "chandelier" chain supplied from Kitfox with the kit for the tailwheel drag lines can be sourced. I had to extend mine and am now forced to use a cheap hardware chain as I haven't been able to find a supplier for the original.
Gary
Paul A. Franz
-Matt Dralle, List Admin.
akflyer
Posted: Mon Jan 19, 2009 7:31 pm Post subject: Re: Lovely tailwheel |
Aircraft spruce has the chain.
http://www.aircraftspruce.com/catalog/lgpages/comp_springs.php
You can order just the chains, but yer gonna pay alot more for shipping than the chain itself.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Posted: Mon Jan 19, 2009 8:17 pm Post subject: Lovely tailwheel |
Thanks Leonard
Gary Algate
