Paul A. Franz, P.E.
Posted: Mon Jan 19, 2009 6:22 pm Post subject: Tailwheel chain |
On Mon, January 19, 2009 6:00 pm, gary.algate(at)sandvik.com wrote:
| Quote: | Question to the list - does anybody know where the "chandelier" chain
supplied from Kitfox with the kit for the tailwheel drag lines can be
sourced. I had to extend mine and am now forced to use a cheap hardware
chain as I haven't been able to find a supplier for the original.
At Lowe's here, they have two type - case hardened nickel plate and galvanized mild
steel.
What are the attributes you're looking for in a chain? Wear resistance? Corrosion
resistance? High tensile strength? Or maybe, you're looking for something other than
simple closed link chain?
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Float Flyr
Posted: Mon Jan 19, 2009 6:59 pm Post subject: Tailwheel chain |
With airplanes having 4130 frames you can just about forget corrosion
resistant... All the corrosion resisting is in the finish. So naturally go
for the case hardened nickel plate. Oh yes ... keep your plane off the
Utah salt flats in the rainy season.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
gary.algate(at)sandvik.co Guest
Posted: Mon Jan 19, 2009 8:00 pm Post subject: Tailwheel chain |
Hi Paul
I was really just looking for the same as supplied with the Kit. It is far heavier duty than I have been able to find here and also tends to stay on the spring far more securely than standard closed link chain
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas". [quote][b]
