wannafly
Posted: Thu Jan 15, 2009 9:52 am Post subject: engine mount |
anyone have a mount for a 912 ul to go on a model IV need a muffler as well. Do any changes have to be made to the cowling for it to fit.
thanks
patreilly43(at)hotmail.co Guest
Posted: Sat Jan 17, 2009 8:29 am Post subject: engine mount |
I have one that came off of a Model 3 C if they are the same.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jan 18, 2009 10:59 am Post subject: engine mount |
As mentioned before, I asked for some input from those who built their own
engine mounts. Fom the list, I got some information about the need for
thrust offset. Then a friend told me that he heard from one of the original
Kitfox designers that there was no thrust offset in the Model IV mount. A
little research showed that the offset is to counteract (in part) the
tendency of an airplane to yaw to the left during cruise from a number of
factors.
Now I have more specfiic questions. My first Model IV had a definite left
yaw tendency (it was a different airplane when I finally put on a trim tab).
I have never seen a rudder trim tab on a kitfox correcting a right yaw.
What is the experience of the list in this regard? Do you yaw left in
cruise requiring right rudder? Do you have a trim tab and if so, can you
fly hands and feet off? With or without a trim tab Do you yaw left in climb
and right in descent - in other words, right rudder in climb and left rudder
in descent (as it should be)?
Lowell
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sun Jan 18, 2009 2:01 pm Post subject: Re: engine mount |
| Quote: | What is the experience of the list in this regard? Do you yaw left in
Lowell |
Lowell, mine is a Classic 4 with a left hand turning propellor. It yaws opposite all the planes I have flown with a right hand turning propellor. I have no trim tabs and trim for level flight with a little up flap handle.
On take off when power is first added yaw is to the right, when the tail comes up more yaw to the right, on climb yaw is to the right.
In level cruse there is a slight Yaw to the right. I can sometimes fly straight and level hands and feet off with no yaw, I think it depends on weight of the load and power setting.
I haven't noticed what direction yaw is on reducing power.
As near as I can tell, the engine thrust line is straight ahead and a degree or two down.
My personal theory on the yaw in level flight is it is due mostly to spiraling slip stream.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
