jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Fri Jan 16, 2009 5:40 pm Post subject: Cowling winterization plate |
I need to do something to make my O-200 happier in the winter. I haven't
seen oil temperatures above 140 F since it got cold around here. that's
making me nervous about not boiling the condensation out of the oil.
The O-200, at least in the AMD Zodiac, does not have an oil cooler to cover
up. That means I need to restrict airflow through the cowling. I've spoken
to an owner in Crookston, Minnesota, and he recommended that I first make a
plate to cover the air exit from the bottom of the cowling, and then add
plates at the inlet only if that doesn't do enough. I've got no problems
with that plan in general. The question I have, however, is simple: How do I
attach the plate?
The forward end would need to attach somewhere inside the lower cowl,
forward of the opening. That's easily enough done: holes in the cowl itself,
and rivnuts in the plate. The fun comes in attaching the rear of the plate
to the firewall. Suggestions? More rivnuts at the bottom of the firewall
itself, or are there better ideas?
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
psm(at)att.net Guest
Posted: Fri Jan 16, 2009 6:25 pm Post subject: Cowling winterization plate |
Hi Jay,
First, I would stay away from rivnuts. They have a horrible
reputation for spinning in their holes so you can't unfasten the
screws later on. If you feel you must use threaded fasteners, then
you should learn about nut-plates or just use bolts and nuts.
You might do a lot better to use ordinary pulled rivets. I suggest
you practice a little at installing them and drilling them out when
you want them to be gone. To be consistent with the construction of
the plane you should use Avex rivets (get a fellow Zenith builder to
donate a handful of them - we all have lots of extras). For
something like these air baffles you would probably be ok with
hardware store rivets. Perhaps 1/8" aluminum short or medium length.
You might start with .025 or .016 6061-T6 sheet metal and drill first
with #40 pilot drill and then line-drill with #30 for the 1/8"
rivets. (Line drilling is when you drill through both connecting
sheets at the same time. This gets the holes perfectly lined up.)
I'd suggest leaving the firewall alone and using the skin behind the
firewall for your new baffle attachment.
Good luck,
Paul
XL getting close
Good luck,
Paul
At 05:39 PM 1/16/2009, you wrote:
attach the plate?
jmaynard
Posted: Fri Jan 16, 2009 6:27 pm Post subject: Cowling winterization plate |
On Fri, Jan 16, 2009 at 06:17:53PM -0800, Sabrina wrote:
| Quote: | The TCM manual allows you to run at 4 quarts of oil rather than 6. That
will increase your oil temp.
My engine likes to run about 4-1/2 quarts anyway...mor than that just gets
blown out the breather.
| Quote: | Steep climbs at full power will do the same.
That's how I'm getting up to 140.
| Quote: | Modifying an S-LSA???s does not sound like the answer.
This is with permission of AMD; they want a drawing of whatever I come up
with so they can offer it as an option.
| Quote: | Another option: Royco has a flight ready preservative oil that fights the
corrosion you are worried about.
That might not be a bad idea at all.
jmaynard
Posted: Fri Jan 16, 2009 7:11 pm Post subject: Cowling winterization plate |
On Fri, Jan 16, 2009 at 06:46:21PM -0800, Sabrina wrote:
| Quote: | Do you have CHT and EGT gauges? What are they reading?
They're normal: CHTs in the mid to upper 200s, dropping below the 200 F
yellow line when I power back for maneuvers (I'm working on a CFI-SP); EGTs
are in the 1300s, and can easily be raised with a little leaning. It's just
the oil temperature that's worrying me.
| Quote: | Rather than closing off the exit, changing the lower cowl's lip will
dramatically change the air flow.
True...but my goal is to have something that can easily be installed and
removed as necessary, similar to the winterization plates on other aircraft.
What would be really nice is if it had cowl flaps...
Posted: Fri Jan 16, 2009 7:22 pm Post subject: Cowling winterization plate |
I've been trying to think of non-destructive ways to block off the
air flow out of your cowl.
One idea is to take some sheet metal, or if you must poster-board,
and tape it temporarily in place with good old duct tape. You can
cut a sheet to size and slide it into the cowl exit hole and then
tape the front in place. Then tape the back to the cabin floor.
This might not give a good final fix for your winter cooling issue,
but it might lead to a good one.
Paul
XL getting close
At 07:11 PM 1/16/2009, you wrote:
| Quote: | > Rather than closing off the exit, changing the lower cowl's lip will
jmaynard
Posted: Fri Jan 16, 2009 7:29 pm Post subject: Cowling winterization plate |
On Fri, Jan 16, 2009 at 07:21:39PM -0800, Paul Mulwitz wrote:
| Quote: | One idea is to take some sheet metal, or if you must poster-board, and
tape it temporarily in place with good old duct tape. You can cut a sheet
to size and slide it into the cowl exit hole and then tape the front in
Cabin floor? The only thing at the back of the cowl exit is the firewall.
Still, you've hit on how I plan to dummy it up, although I plan to use
something besides duct tape that will come off without leaving a residue
behind. Ain't no way I'm gonna ever use duct tape on my airplane.
jmaynard
Posted: Fri Jan 16, 2009 7:39 pm Post subject: Cowling winterization plate |
On Fri, Jan 16, 2009 at 07:30:03PM -0800, Sabrina wrote:
| Quote: | There is at least one oil sump blanket that is STC'd for the O-200A in
flight. Use that and then pre-heat your oil with a plug in dip stick
heater that is removed before flight.
I've got a Tanis on my engine, and use it religiously when the temperature
is below 40 F. It includes an oil sump heater. Do you think blocking off the
sump alone will get the temperature back up?
tonyplane(at)bellsouth.ne Guest
Posted: Fri Jan 16, 2009 7:40 pm Post subject: Cowling winterization plate |
If you do use any riv-nuts, what I do is to install them with loctite 262,
or equilivant, around the head/O.D. Has worked for me.
"............I would stay away from rivnuts. They have a horrible
nuts................"
Tony Graziano
Posted: Fri Jan 16, 2009 7:46 pm Post subject: Cowling winterization plate |
Try 200 mph tape from Wal*Mart. This is the stuff NASCAR racers use
for the same sort of thing. I also use a lot of it while building my
XL. It only looks like duct tape. Duck brand is the best, in my
opinion, and Wal*mart has it. If there is any problem removing the
adhesive, just use a little lacquer thinner on a rag to wipe it off.
The cabin floor is attached to the bottom of the fire wall. This
would be a nice place to tape the aft end of a sheet of metal to hold
it in place for a test flight.
In no event would I drill holes in the firewall. That is just asking
for trouble - not to mention dull drill bits.
I was thinking two or three sheets taped in place in the corners and
middle of the cowl exit hole would work well. You can adjust the
size of each piece to get the amount of cooling reduction you
want. After you have found a nice size opening to have for your own
personal climate you can rivet some aluminum in the same place.
Paul
At 07:28 PM 1/16/2009, you wrote:
| Quote: | Cabin floor? The only thing at the back of the cowl exit is the firewall.
planecrazydld(at)yahoo.co Guest
Posted: Sat Jan 17, 2009 6:06 am Post subject: Cowling winterization plate |
Only use lacquer thinner or acetone if the finish can take it...don't ask how I know these things...
David L. Downey
Harleysville (SE) PA, USA
--- On Fri, 1/16/09, Paul Mulwitz <psm(at)att.net> wrote:
| Quote: | From: Paul Mulwitz <psm(at)att.net>
Subject: Re: Re: Cowling winterization plate
Date: Friday, January 16, 2009, 10:43 PM
| Quote: | | --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net> ...If there is any problem removing the adhesive, just use a little lacquer thinner ona rag to wipe it off. |
z601(at)anemicaardvark.co Guest
Posted: Sat Jan 17, 2009 8:36 am Post subject: Cowling winterization plate |
On Friday 16 January 2009 21:30, Sabrina wrote:
This is one of the issues we face during the relative infancy of the whole LSA
thing. An STC applies to a type certificated configuration. Unless the O200A
is being maintained and annualed by an IA, its type certification probably
isn't being maintained.
If the O200A were installed on a type certificated aircraft, one could visit
the question as to whether the sump blanket were type certificated for the
engine installation on that specific aircraft. But it isn't, it's on an LSA,
where the STC does not apply (an LSA doesn't have a type certificate).
What I'm saying is that I don't think the FAA's rules have as yet fully
addressed this situation. I have a question(s) in to the FAA on this and
related certification/maintenance subjects. I'm hoping I get something
definitive enough to share.
Yes, that's probably a naive hope.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Posted: Sat Jan 17, 2009 10:28 am Post subject: Cowling winterization plate |
On Saturday 17 January 2009 11:29, Sabrina wrote:
Jay has an S-LSA.
I can't imagine AMD approving any appliance for the engine that has not
been STC'd as to that engine. Just their changing out the FAA-PMA spark
plugs for Auto plugs required a lot of testing and analysis that Jay is not
in the position to do re: a non-STC'd oil sump blanket.
You are correct in pointing out that just because it is STC'd does not mean
an IA or AP can install it on the S-LSA, only AMD can approve such an
installation. Their exhaust configuration my not allow for such an
installation.
It is different story for the airframe--they built it and could approve
anything.
That is my point exactly. Any change to the LSA must come from the
manufacturer, not from the FAA. We can't base our usage on approval from some
other airworthiness system. The manufacturer can probably use that as a
basis, if they so desire, but we can't.
| Quote: | Question, can Jay put oil additives in an S-LSA that are not on the
approved list of lubricants from AMD?
My gut feeling is no, he cannot legally do so. But these are the exact kinds
of questions I'm hoping to get the FAA to clarify.
It's very confusing to an IA/A&P. Although we sometimes curse the FAA for
giving us too much of the wrong kind of guidance, it's probably worse not to
have any guidance. I don't think we can really do much more in some cases
than say that there is no approved procedure by the relevant airworthiness
authority. In the case of Jay's additives, that would be the manufacturer of
the LSA, AMD. If AMD didn't specifically approve it, I'd say it's not
approved.
An example for certificated aircraft would be the use of a non-approved
lubricant. For example, I've run into some who thought it was a really great
idea to use Mouse Milk as an additive in certificated engines. I probably
don't need to say that Mouse Milk is not on the approved list for any general
aviation engine of which I am aware.
Our authority, such as it is, is derived from whoever controls the
airworthiness for a given aircraft. I suspect many of us don't feel
comfortable signing log book entries without an approved airworthiness basis
for whatever was just done.
Once a year, there are nationwide training sessions for IA's, which are used
as a basis for the continuance of our IA. One of the better ones is in the
Dallas area. It covers questions IAs are having in the field: areas of
conflicting guidance, and areas of no guidance. It also usually covers
signifcant general aviation crashes of the year, and what really happened.
I submitted my questions about LSA maintenance and certification issues to the
people who conduct that training session. I was told that they would try to
create a session to address these issues, and clarify the FAA position.
Assuming that happens, I'm going to request permission to make the LSA part
of the presentation available to this list.
And, if you are in the Dallas area, the seminar is open to all (but with a
$100+ fee). I believe it's on Feb 28, this year. You can get details on it at
ASOD.com. I've found that often the information is of broader interest to
those maintaining their own aircraft than just IAs.
But a word of caution: it starts at 0730 and ends around 1700. It's pretty
cram-packed. The donuts are good, though!
Do not archive.
Jim B Belcher
A&P/IA
paulrod36(at)msn.com Guest
Posted: Sat Jan 17, 2009 10:37 am Post subject: Cowling winterization plate |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Right on, Paul---I used rivnuts for the forward upper skin, and, 78 rivnuts leter, found that almost 1/4th of them spun. There;s a little protrusion on each one that allegedly digs into the side of the hole and is supposed to hold it. It don't. 78 nut plates later, a guy suggested dipping each rivnut in epoxy or Proseal to keep them from spinning. Ah, yes, the sequence of life:
1. You have a problem.
2. You come up with a solution.
3. It's the wrong solution.
4. You correct the solution.
5. Some guy comes along with an easier solution.
Paul Rodriguez
