clemwehner(at)sbcglobal.n Guest
Posted: Fri Jan 16, 2009 10:40 am Post subject: Fuel pickup mods |
My KF-IV, 1991 vintage has the fuel pickups at the aft end of the tank. Didn't Skystar have a mod to move the pickups forward to eliminate fuel unporting during descent?
Was this a good idea and should I modify my tanks?
thanks,
Clem Wehner
KF-IV, 912
Lawton, OK
Float Flyr
Posted: Fri Jan 16, 2009 11:47 am Post subject: Fuel pickup mods |
My plane has a header tank that will take care of the engines needs for around 20 min.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of clemwehner
Sent: Friday, January 16, 2009 3:08 PM
Subject: Fuel pickup mods
thanks,
Clem Wehner
KF-IV, 912
Lawton, OK
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Fri Jan 16, 2009 1:01 pm Post subject: Fuel pickup mods |
So's mine....I figure 15 minutes to be safe, though....in fact while
descending into my flight instructors' place yesterday the low fuel
came on, and I pointed the nose level, banked to the left a bit, did
a little circle to line up with the runway, and the light went off,
telling me I had a t least 15 minutes left. I put in 10 gallons and
went home. I knew I was getting low, but kept it purposely low to
enable lifting the tail during the recent ski cable rigging
procedure, and was having so much fun with the skis I just plain
forgot to fuel up. I seem to be reporting a lot of these "low fuel
antics" but I maintain that knowing how to get out of the predicament
is first and foremost. Secondary is scolding myself for doing it
again and again. : (
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 16, 2009, at 2:46 PM, Noel Loveys wrote:
| Quote: | My plane has a header tank that will take care of the engines needs
for around 20 min.
Noel
thanks,
Clem Wehner
KF-IV, 912
Lawton, OK
http://www.matronics.com/Navigator?Kitfox-Listhttp://
forums.matronics.comhttp://www.matronics.com/contribution
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
sbennett3(at)aol.com Guest
Posted: Fri Jan 16, 2009 1:30 pm Post subject: Fuel pickup mods |
I have 27.5 usable on my fox. 13-13-1.5 header. I have completed a cross country at a comfortable cruise (5000rpm rotax 912) I flew that plane for 6 hrs strait from Northern Penn. to North Carolina. I had 9 gallons of fuel when I touched down. I was amazed with the fuel burn at a slower cruise rpm. I still get a laugh when I see "The only time I don't want my tanks full is when i'm on fire". Every time I launch my plane, my tanks are full. It also seems to handle the bumps in midday flying better being a little heavy. Also less chance of picking up moisture when you keep you tanks full. Steve Bennett North Carolina KF4-912 classic speedster
In a message dated 01/16/09 16:02:43 Eastern Standard Time, lynnmatt(at)jps.net writes:
[quote] .aolmailheader {font-size:8pt; color:black; font-family:Arial} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal} --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Ki tfox IV Speedster, taildragger
Sensenich 62x46
brianm(at)snolab.ca Guest
Posted: Fri Jan 16, 2009 1:48 pm Post subject: Fuel pickup mods |
Hi Guys
I am in the process of building a speedster with a 912 and was wondering what cruise speed I can expect at different rpms. I'll be installing a IFA Ivo so I will be able to play with the pitch.
thanks
Brian
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of sbennett3
Sent: January 16, 2009 4:29 PM
Subject: Re: Fuel pickup mods
Lynn Matteson
Sensenich 62x46
for around 20 min.
Noel
Was this a good idea and should I modi f y my tanks?
t
Which stars will make the biggest headlines in 2009? Get Hollywood predictions, celebrity holiday photos and more with the PopEater Toolbar.
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jan 16, 2009 2:22 pm Post subject: Fuel pickup mods |
Clem,
My first Mod IV has pick-ups as you describe and my new build will have the
same. I flew often on cross countrys with the guys and sometimes solo and
never felt the need to change. I did have the light come on once after a
non stop from the factory area in Idaho to home in California. It happened
on the long 400 fpm descent from the crest of the Sierras to my home in the
foothills, a descent of about 30 minutes. I knew I had at least six
gallons - quite accurate markings on the sight gauges - so leveling for a
while to refill the header was no problem. With no boss where at the new
location, drilling and tapping at the location, mess clean-up and resin
bonding issues, for me it would not be worth the effort.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Almost ready to cover left wing and fuselage.
clint_bazzill(at)hotmail. Guest
Posted: Fri Jan 16, 2009 5:52 pm Post subject: Fuel pickup mods |
I am going to add a little to Lowell's reply. I have Williams low fuel warning in my aircraft also. I had the light go on a number of times when letting down. It does get your attention. What I do is pick the nose up C do a high wing up and let the header fill. The test I did over Half Moon Bay airport about 8 months ago went like this. I climbed over the airport to 3500 feet. Shut off fuel to both tanks C had power setting at 24 inches Manifold Pressure C 5100 RPM's. Engine shut down and prop stopped 21 minutesand 40 seconds later. A 912 ULS will not air start C so fuel went back on and engine started in about 4 or 5 seconds with starter.
Clint C lots of time with 912 ULS.
[quote] From: lcfitt(at)sbcglobal.net
Subject: Re: Kitfox-List: Fuel pickup mods
Date: Fri C 16 Jan 2009 14:18:29 -0800
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Clem C
foothills C a descent of about 30 minutes. I knew I had at least six
location C drilling and tapping at the location C mess clean-up and resin
bonding issues C for me it would not be worth the effort.
Lowell Fitt
Cameron Park C CA
Guy Buchanan
Posted: Fri Jan 16, 2009 8:58 pm Post subject: Fuel pickup mods |
At 10:38 AM 1/16/2009, you wrote:
| Quote: | | Was this a good idea and should I modify my tanks? |
I wouldn't do it unless the tanks had a significant sump. I don't find it a problem to re-fill the header every now and then on descent. Besides, it's the only way to check that my low-fuel light is working. (Too lazy to put in a test circuit.)
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
