longg(at)pjm.com Guest
Posted: Fri Jan 16, 2009 5:57 am Post subject: Contactor Polarity |
I think this question was raised last week, but I could not find it via the search engine.
For appearances I am planning to mount my contactors (3), ANL’s, SD-8 capacitor/relay on a sheet of glossy carbon fiber bolted to the firewall. To make it look good it will require the contactors be properly arranged on the board. Does polarity (primary lugs) matter on the B & C contactors? I have both momentary and constant.
Glenn
rampil
Posted: Fri Jan 16, 2009 6:38 am Post subject: Re: Contactor Polarity |
Glenn,
Are you sure you want to use carbon fiber??
It is a conductor, but not good enough to serve as a common ground
in a power circuit. You might be chasing ground loops until the end of time,
unless you tie the things wanting to be connected together with thick
buss cable and isolate the mounts that should not be grounded.
Contactors should not have polarity in the power leads
Posted: Fri Jan 16, 2009 7:02 am Post subject: Contactor Polarity |
At 07:55 AM 1/16/2009, you wrote:
| Quote: | I think this question was raised last week, but I could not find it
For appearances I am planning to mount my contactors (3), ANL's,
No. The contactors themselves are not polarity critical,
only the diodes you may have to put on the outside.
( -Thomas Paine 1776- )
Posted: Fri Jan 16, 2009 8:37 am Post subject: Contactor Polarity |
Bob,
So if I use the B & C jobs (they come with diodes), I will need to
switch them accordingly, yes?
