Lynn Matteson
Posted: Tue Jan 13, 2009 2:20 pm Post subject: Ski report...flying |
I couldn't stand not flying today, so I sucked it up and went out. I
was a bit reluctant because I woke up a t 3 am, couldn't get back to
sleep, and figured by 11 am or so, that I probably was too pooped to
participate. Got an hours' rest and the pretty clear sky and calming
winds...only 20 mph at altitude....told me this was my only shot for
at least 3-4 days, what with below zero coming (yeah, I know, I'm a
wimp, Leonard) for the next 3 days and a storm promised. I got
airborne without much of a problem, circled the field and came back
in. Wind was pretty much down the 27 runway...I cleared the trees to
the east, landed pretty short, felt it become real normal and slow,
then powered it up and took right off again, using less than half the
1700' field for the landing, the roll-out and the takeoff. Flew it
over to Napoleon Airport (3NP), landed on 33 there...wind was
favoring that one over there. I went into the restaurant, and seeing
nobody ready the hang a laurel wreath on me for valor, I left and
went back up. I saw some snow headed my way on both sides of the
plane, so figured I'd better beat it back home.
So three landings in the book, the plane works beautifully with these
skis....I was plowing through the fresh snow at 2100 rpm, much better
than the old "cheese slicer" models. Boy, the guy who built those
must've been a damn photographer in another life.
I hope these aren't too large...1.9 megs worth...if they bounce, I'll
separate them....
On Jan 13, 2009, at 1:57 PM, Noel Loveys wrote:
Ski reports on airplanes are hardly off topic.... when do we get
to see
some pics???
Noel
306.08 KB |
598 Time(s) |
322.01 KB |
642 Time(s) |
373.79 KB |
651 Time(s) |
456.94 KB |
620 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
patreilly43(at)hotmail.co Guest
Posted: Tue Jan 13, 2009 3:10 pm Post subject: Ski report...flying |
Lynn C Beautiful set of skis. Did you gas weld them? There are 2 brackets on the front tube. You used 1 for bungees. What is other 1 for? Did you heat the bottoms to curl the edges and the rear kickup? What is the orange piece sticking out of the bearing grease cap? I have bigger bush tires C I guess I could make a taller tower to accommodate them. I will have to have a set of axles made 3" longer so they will stick out the back of the mount. Thanks for the briefing and sorry to ask so many questions C but C again C those are beautiful skis that can be mounted very quickly. Do you have a tail wheel ski?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lynnmatt(at)jps.net
Subject: Ski report...flying
Date: Tue C 13 Jan 2009 17:07:11 -0500
I couldn't stand not flying today C so I sucked it up and went out. I
was a bit reluctant because I woke up a t 3 am C couldn't get back to
sleep C and figured by 11 am or so C that I probably was too pooped to
at least 3-4 days C what with below zero coming (yeah C I know C I'm a
wimp C Leonard) for the next 3 days and a storm promised. I got
airborne without much of a problem C circled the field and came back
the east C landed pretty short C felt it become real normal and slow C
then powered it up and took right off again C using less than half the
1700' field for the landing C the roll-out and the takeoff. Flew it
over to Napoleon Airport (3NP) C landed on 33 there...wind was
favoring that one over there. I went into the restaurant C and seeing
nobody ready the hang a laurel wreath on me for valor C I left and
plane C so figured I'd better beat it back home.
So three landings in the book C the plane works beautifully with these
skis....I was plowing through the fresh snow at 2100 rpm C much better
than the old "cheese slicer" models. Boy C the guy who built those
Paul A. Franz, P.E.
Posted: Tue Jan 13, 2009 3:35 pm Post subject: Ski report...flying |
On Tue, January 13, 2009 2:07 pm, Lynn Matteson wrote:
| Quote: | I hope these aren't too large...1.9 megs worth...if they bounce, I'll
separate them....
These photos are great. I waited hours for them! More photos would be good too.
I've got a suggestion regarding photos. If you use the forum interface to this list it
is a fairly simple matter to post pictures. If you do that, you need not worry about
e-mailing photos that are too large. This is a good thing to do for a couple of
reasons. 1st, when you attach them, everyone on the list gets them via e-mail whether
or not they want to look at them. Secondly, when a photo or any attachment is e-mailed
it has to undergo some type of 7 bit encoding, either uuencoding or MIME base64. That
encoding process adds roughly 50% to the file size. And the other consideration is
that some e-mail servers have limits to the size of an e-mail it will accept. Some are
set to accept a total maximum size of 2 MB, many are limited to 10 MB. That would be
roughly 6.5 MB of actual pre-encoded material. The next consideration is to Matt
Dralle. He has asked politely in numerous locations that people post photos in the
space provided.
It's not very hard and you don't have to make a major project out of doing so either.
I will post a detailed step by step procedure if anyone would find that more useful
than the instructions already on the forum. So if just one person wants that I will do
that so it is as close to fool proof as possible.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Lynn Matteson
Posted: Tue Jan 13, 2009 3:52 pm Post subject: Ski report...flying |
I used my new Miller TIG welder for all welds. The two brackets/tabs
are both for bungees and the front restraint cables...I just haven't
installed the redundant bungee/cable set yet. The same goes for the
rear. And my CFI, Brian, won't see the skis until they are all in
place...in fact, he won't hear of this flight until the cables are
all in place. Others have said "they only use one set of cables and
bungees up north"...well I ain't "up north" and I have to fix my own
plane, so I'll go with the dual cables/bungees.
I wanted to get a test flight in before the weather locked me out for
the next 3-4 days, so I went minimal on the cables for this flight.
Yes, I used a propane torch to heat the 3/16" HDPE material so it
would bend. The longer side bends were the toughest, as they tended
to spring back...I would have needed another torch and possibly
another person to facilitate this bending operation, but the tabs
along the sides hold it in position, but there are "scallops" visible
in the surface. The orange thing is a "stand-off" for the wheel
pants...no point in removing it for the winter, in fact, I'd like to
make a wheel cover that would bolt to this stand-off and maybe reduce
the amount of snow that collects inside the wheel dish. No tail wheel
ski...I heard that they can be a problem with aerodymanics, trying to
make the tail do strange things, and I figured I didn't need that
kind of grief.
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 13, 2009, at 6:08 PM, patrick reilly wrote:
| Quote: | Lynn, Beautiful set of skis. Did you gas weld them? There are 2
cap? I have bigger bush tires, I guess I could make a taller tower
briefing and sorry to ask so many questions, but, again, those are
wheel ski?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
N369LM |
Float Flyr
Posted: Tue Jan 13, 2009 3:53 pm Post subject: Ski report...flying |
A real nice job Lynn. How about a couple of close ups of the inside and
outside of the attach points. Next year a look at the axles would be
appreciated too.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Jan 13, 2009 4:04 pm Post subject: Ski report...flying |
I'd appreciate the step-by-step, Paul. It's a pain for me to send
photos because I'm on dial-up and the going is slow. I haven't gone
to the forum interface, so it's possible I don't know how easy it is.
I've got more photos, so easier posting would be a big help. And I'd
rather not post the photos directly for those that are NOT members of
my "fan club" (ha, ha)...and to those of you out there that are not,
why the hell not? : )
Lynn Matteson
Sensenich 62x46
On Jan 13, 2009, at 6:35 PM, Paul Franz - Merlin GT wrote:
<paul(at)eucleides.com>
> separate them....
be good too.
a couple of
via e-mail whether
MIME base64. That
consideration is
MB. That would be
post photos in the
space provided.
of doing so either.
that more useful
Paul A. Franz
Bellevue WA
425.241.1618 Cell
N369LM |
gary.algate(at)sandvik.co Guest
Posted: Tue Jan 13, 2009 4:07 pm Post subject: Ski report...flying |
Lynn
When I flew up in N.Ontario everybody used a secondary bungee with a restraint cable front and back. I know its important because I landed with one broken as it evidently got damaged when I was taxiing thru a strong snow crust on take off.
I also had a tail ski and although it made a fair difference to manoeuvring performance on snow I never noticed any issues in flight. Mine wasn't really "engineered" just an aluminum frame and a piece of teflon. Hell, my balls never in the centre anyway !!!!!!
Gary
Gary Algate
Classic 4 jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
14/01/2009 10:00 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: Ski report...flying
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
kind of grief.
Lynn Matteson
Sensenich 62x46
> wheel ski?
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford, IL
Lynn Matteson
Posted: Tue Jan 13, 2009 4:22 pm Post subject: Ski report...flying |
Not sure what you mean by the "inside and outside of the attach
points", Noel...you mean the stub "axle" where the ski pivots? or the
cable attach points?
Lynn Matteson
Sensenich 62x46
On Jan 13, 2009, at 6:53 PM, Noel Loveys wrote:
inside and
appreciated too.
Noel
N369LM |
Lynn Matteson
Posted: Tue Jan 13, 2009 4:28 pm Post subject: Ski report...flying |
That's the exact reason that my CFI strongly suggested the second set.
I may try building a tail ski....if it's not too large, it probably
wouldn't wreak havoc with the flight characteristics, I guess. It's
worth a try.
Mine are dead center of the left-hand seat. : )
Lynn Matteson
Sensenich 62x46
On Jan 13, 2009, at 7:06 PM, gary.algate(at)sandvik.com wrote:
Lynn
Gary
Gary Algate
Classic 4 jab 2200
have made a contribution to UNICEF Australia. We wish you a safe
14/01/2009 10:00 AM
Please respond to
To
cc
Subject
kind of grief.
Lynn Matteson
Sensenich 62x46
> wheel ski?
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford, IL
www.matronics.com/contribution _-
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jan 13, 2009 5:00 pm Post subject: Ski report...flying |
Lynn,
My old gone airplane had hubcaps. That is the only thing I still have as I
found that they didn't measurably affect performance and they were just in
the way when I needed to top up the air pressure so I took them off. I
still have them if you want them. I attached them by gluing an aliminum
flange over the wheel hub and putting three nutplates in the appropriate
position around the hub. come to think of it, it was the flange that was a
pain when trying to check pressures. If you want to make your own, I used
one of my wife's frying pan lids as a female mold. A little bit of PVA
release agent sprayed on them and presto a very nice moon type hubcap. My
advice to those who's wife doesn't leave the house for days at a time for
work, get permission or be real careful you don't get caught or you may get
"the look" or worse.
Lowell
Float Flyr
Posted: Tue Jan 13, 2009 5:04 pm Post subject: Ski report...flying |
That's the ones.
BTW what do you use to manipulate your photos? Trying to remember the Apple
equivalent in I-Life. It is possible to reduce the size of the pictures
without cropping to make them easier to zap out on phone lines.
Noel
Kitfox III-A
akflyer
Posted: Tue Jan 13, 2009 5:05 pm Post subject: Re: Ski report...flying |
[quote="Lynn Matteson"]That's the exact reason that my CFI strongly suggested the second set.
worth a try.
Lynn Matteson
Sensenich 62x46
Several of the ski manufactures had a second cable on the front that they called a "crust cutter" to keep the ice from popping the main cable, but I have not seen a redundant set of bungees or springs.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Tue Jan 13, 2009 6:21 pm Post subject: Ski report...flying |
I think that I might be able to form a Baby Moon-type cover out of
aluminum or maybe this is a job for my "next-to-aquire" vacuum-
bagging skills and fiberglass. Maybe there's something out there that
I could adapt. I was thinking of using the wheel pant stand-off
because it's already there. One bolt would remove it, but it would be
stationary, and would have to clear the wheel. I'm not sure if this
would keep the snow out or not. Then there is the sprint car trick of
stuffing a foam donut into the wheel cavity to keep the dirt/mud out
of the wheel.
Hey, that fry pan lid mold idea sounds great...might give that a try.
Lynn Matteson
Sensenich 62x46
On Jan 13, 2009, at 7:55 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
Lynn,
have as I found that they didn't measurably affect performance and
they were just in the way when I needed to top up the air pressure
so I took them off. I still have them if you want them. I
attached them by gluing an aliminum flange over the wheel hub and
putting three nutplates in the appropriate position around the
hub. come to think of it, it was the flange that was a pain when
PVA release agent sprayed on them and presto a very nice moon type
hubcap. My advice to those who's wife doesn't leave the house for
days at a time for work, get permission or be real careful you
don't get caught or you may get "the look" or worse.
Lowell
N369LM |
Lynn Matteson
Posted: Tue Jan 13, 2009 6:39 pm Post subject: Ski report...flying |
I just drag them into the email and see how big the file is, then hit
"large", "medium", or "small" if they are too large. I also have
Photoshop Elements, but that's a longer process.
Which are the "ones"? ....both the axle, and the cable attach points?
The square block here bolts to the inside/backside of the Grove
landing gear. I'm not really sure what you wanted to see.
Lynn Matteson
Sensenich 62x46
On Jan 13, 2009, at 8:04 PM, Noel Loveys wrote:
That's the ones.
the Apple
pictures
Noel
139.27 KB |
557 Time(s) |
124.84 KB |
633 Time(s) |
N369LM |
Lynn Matteson
Posted: Tue Jan 13, 2009 7:00 pm Post subject: Ski report...flying |
I used my main restraint cable on the front as a crust cutter, by
bringing it down to the front tube of the ski, then doubling it back
up about 9", installing a thimble and nicopress sleeve for the bungee
to connect to. When I get to it, I'll make up the second, redundant,
cable/bungee and install it, so it will be just like the previous
skis I made, pictured here. These are connected to separate 3-hole
tangs bolted to the float brackets on the Kitfox IV. So there is
complete redundancy, unless the bolt fails and that is pretty
unlikely, I think. The rear restraint cables...also two of them
(although this picture shows only one rear at the time) will connect
to two separate 2-hole tangs, bolted to two separate float
brackets....about as separately redundant as I can make it.
Lynn Matteson
Sensenich 62x46
worth a try.
Lynn Matteson
Sensenich 62x46
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis
takes over.
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 24630#224630
418.46 KB |
604 Time(s) |
N369LM |
Float Flyr
Posted: Tue Jan 13, 2009 8:17 pm Post subject: Ski report...flying |
Making out of composite w/ vacuum bagging will give reproducible light
weight covers... but composites require sealing to keep them from absorbing
water. The first thing you will have to do is build a nice small autoclave
with vacuum outlets inside it.
Noel
Kitfox III-A
Float Flyr
Posted: Tue Jan 13, 2009 8:26 pm Post subject: Ski report...flying |
I thought you used a Mac....
The pics I wanted to see was the ski attach points behind the wheel. I have
to take my whells off to put the skis on. Did it once. It's quite a
process because the brakes have to be disassembled than everything has to be
re assembled. Changing out the axels (stubs) would be a lot easier and
faster. I was also wondering about putting a set of the narrow wheels on
the straight skis I now have. Of course then I would be flying without
brakes.
Noel
Kitfox III-A
Lynn Matteson
Posted: Wed Jan 14, 2009 12:49 am Post subject: Ski report...flying |
I do use a Mac. It's an eMac that I bought in about 2001 or 2002. I
got Photoshop Elements for it about a year later.
Did the pictures help you figure out the mounting of the skis? I can
take more pics if you need them...in fact, I'll bet I could pull the
large cotter pin, remove the nut and slide the ski off the stub axle
without even undoing the cables, or jacking up the plane. In fact,
after the plane was initially jacked up to install the stub axles, I
did not have to move the plane in any way to install the skis. This
is the only way to fly, if you'll pardon the expression, around here
where the snow comes and goes so frequently. I just can't get over
how easily these skis install, and in fact if I were to substitute
the present cotter pins for those safety pins, it'd cut the install/
remove time by a couple of minutes....hey, now there's a topic for a
U-tube video...nah, I guess not.
Let me know if you want more pics, Noel.
Lynn Matteson (who woke up early again when the temp hit 9 below F.
just now)
Sensenich 62x46
wheel. I have
has to be
and
wheels on
without
brakes.
Noel
N369LM |
Paul A. Franz, P.E.
Posted: Wed Jan 14, 2009 1:29 am Post subject: Using the Matronics forum to post pictures and messages |
| Lynn Matteson wrote: | I'd appreciate the step-by-step, Paul. It's a pain for me to send photos because I'm on dial-up and the going is slow. I haven't gone to the forum interface, so it's possible I don't know how easy it is.
Well you probably will prefer to use the Forum once you get the hang of it. Your messages will always be there so you don't have to clutter up your computer getting messages e-mailed to you. Of course you have that option if you want it.
I posted the instructions. In brief format they are:
1) register (once only good to post in any Forum too)
2) login (not required just to read messages)
3) post a new topic or reply to an existing one. Click "add an attachment" then browse for it on your own computer, fill in the descriptive information then click "add attachment". You can then preview your post before submitting it just to make sure it looks right.
People that want a very easy and free program to resize photos, make albums, post web presentations of them and write text on the photo try Google's Picasa. It also will find and make viewing all the photos on your 'confuser' easy.
[http://picasa.google.com/]
It is available for Windows XP and Vista as well as for Mac OS X and Linux
Here's a YouTube video showing off Picasa. You're bound to like this program. The price can't be beat (free).
[http://www.youtube.com/watch?v=rskC6c_5L1M]
Bellevue WA
425.241.1618 Cell
Fox5flyer Guest
Posted: Wed Jan 14, 2009 4:39 am Post subject: Ski report...flying |
Lynn, great job on the skis! I really do like the way you designed them and
they appear to be plenty strong, yet light, for your airplane. You're a
"real" experimenter. Kudos.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
- Joseph Joubert
