Paul A. Franz, P.E.
Posted: Thu Jan 15, 2009 1:30 am Post subject: ELT - 406 MHz or 121.5 standard? |
I just came across an advertisement for a 1.87 LB ELT with a 6 year battery life.
<http://www.kannad.com/en/safety/index.php?id=51>
Is this 406 MHz a replacement for the 121.5 MHz standard that I'm familiar with?
What are you using? What antenna considerations should there be? I assume an external
antenna should be on top since an ELT would most likely be deployed on the ground and
hopefully with the aircraft right side up.
Maybe you don't even need an external antenna.
Recommendations?
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
pwmac(at)sisna.com Guest
Posted: Thu Jan 15, 2009 6:32 am Post subject: ELT - 406 MHz or 121.5 standard? |
That is my understanding - $406$ is an acceptable replacement for 121.5
Consider buying the lowest cost to meet the FAA requirements (121.5)
then buy Spot and choose the tracking feature that best meets your
needs. Spot works and works as intended and as advertised. Very
popular solution for pilots and wilderness adventurers. Much less
expensive and more functional than the PLBs that was the first
generation of such devices.
Lots of discussion on other Matronics forums as well as on the
Internet. Check the Aeorelectric forum archives.
Paul
At 01:28 AM 1/15/2009, you wrote:
<paul(at)eucleides.com>
familiar with?
Recommendations?
Paul A. Franz
Bellevue WA
425.241.1618 Cell
akflyer
Posted: Thu Jan 15, 2009 7:49 am Post subject: Re: ELT - 406 MHz or 121.5 standard? |
| Paul A. Franz, P.E. wrote: | I just came across an advertisement for a 1.87 LB ELT with a 6 year battery life.
<http>
Recommendations?
Paul A. Franz
Bellevue WA
425.241.1618 Cell |
The 406 is only REQUIRED if you plan on flying into Canada or another country. 121.5 is still USA, you just wont have satellite monitoring, it will rely on overhead traffic and other pilots to hear the signal and get the ball rolling.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
temco(at)telusplanet.net Guest
Posted: Thu Jan 15, 2009 8:02 am Post subject: ELT - 406 MHz or 121.5 standard? |
Paul
The ELT standard is changing from 121.5 MHz to 406 MHz and in Canada in the
next while we will be mandated to change over to 406 MHz. There are several
aviation organizations lobbying the Gov't to allow alternatives such as SPOT
to be used for small aircraft. So far in this Country the DOT (our
equivalent of your FAA) is not budging on this request from the aviation
groups. I don't recall the exact dates for the change over but I believe it
is in the next year. Perhaps Noel could chime in on this. This change in
Canada is also a point of discussion with the AOPA , FAA, EAA and others as
the change here would affect small aircraft such as our group flying from
the lower 48 through Canada to Alaska.
The way I now understand it --- after implementation an aircraft going from
the lower 48 to Alaska would need 406 MHz ELT to make the trip through
Canada.
This story is still on going here and things may change depending on how
much the DOT listens to the Aviation Groups.
Ted Palamarek
Edmonton, Ab
Kitfox 4-1200/912
Guy Buchanan
Posted: Thu Jan 15, 2009 9:32 am Post subject: ELT - 406 MHz or 121.5 standard? |
At 08:01 AM 1/15/2009, you wrote:
| Quote: | The way I now understand it --- after implementation an aircraft going from
Canada.
Ted,
I have a question on the Canadian implementation. Will they
allow 406 PLBs? Or must you have an aircraft model with G-switch?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Guy Buchanan
| Quote: | I assume an external
on the ground and
Nice thing about a Kitfox is that the antenna can be internal. The
cloth doesn't impede transmission.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Mike C
Joined: 24 May 2006 Posts: 17 Location: Ontario, Canada
Posted: Thu Jan 15, 2009 11:29 am Post subject: Re: ELT - 406 MHz or 121.5 standard? |
The Canadian implementation of the 406 ELT will be phased in over the next 2 years starting next month. It must be an impact activated device so only a proper ELT will do. The grapevine is saying that Transport Canada (TC) will look the other way when US planes are flying into or through Canada without the 406 ELT.
The grapevine is also saying there is going to be an 11th hour meeting between TC and the stake holders that could see some changes but no specifics.
The new ELT will have to be registered to the aircraft owner so that any signals will be directly traceable to the plane and there is the option of transmitting GPS co-ordinates. I understand that the 406 will transmit at 5 watts instead of the 1/2 watt transmission of the 121.5. This will help when using an antenna inside the frame.
Battery packs will be expense (Li-Ion) but they are good for 5 years. The kicker in Canada is the annual re-cert which will be at least triple the cost of the old units.
I'm usually in the shadows but this info was gathered from a seminar I attended late last year.
Mike C
Simcoe, Ontario
Model II 582
Posted: Thu Jan 15, 2009 12:02 pm Post subject: ELT - 406 MHz or 121.5 standard? |
Guy
The way I understand it now is that the aircraft must have the ELT mounted
in the aircraft with an inertia switch that would activate the ELT in the
event of a crash. The aviation groups in Canada are still actively lobbying
the DOT to allow the PLB and SPOT type instruments to be acceptable in small
acrft such as ours rather than the expensive 406MHz ELT.
This story still has some legs and no legislation has been enacted yet to
make the 406MHz mandatory. Currently our Fed Gov't is not sitting and will
not be sitting till the later part of this month. I personally think that
this issue will take a back seat to the economy and won't be acted on for a
number of months. I will try getting you some further info on this issue in
Canada.
Ted Palamarek
Edmonton, Ab
Kitfox 4-1200/912ul
Paul A. Franz, P.E.
Posted: Thu Jan 15, 2009 2:47 pm Post subject: ELT - 406 MHz or 121.5 standard? |
On Thu, January 15, 2009 7:49 am, akflyer wrote:
| Quote: | The 406 is only REQUIRED if you plan on flying into Canada or another country. 121.5
In an article by the EAA;
A note to those flying outside the U.S.: While 406 MHz ELTs are not mandatory for
operating in the U.S., pilot’s who fly internationally - to Canada, Mexico, etc. -
after February 1, 2009, will be required to upgrade their ELTs to the new ICAO
standard 406 MHz units. EAA is working with Transport Canada to obtain an exemption to
this regulation for aircraft transitioning through Canada to Alaska, or flying from
the northeastern part of the U.S. to the west where the most direct flight route
requires a short transition through Canadian airspace.
<http://www.eaa.org/news/2008/2008-09-04_elt.asp>
They have further comments intended to clarify here:
<http://www.eaa.org/news/2008/2008-09-04_elt_info.asp>
The problem I see is practical. It would appear that getting a 406.28 MHz compliant
ELT will cost around $4k with the interface to the NAV system for GPS coordinates.
Using the pricing for the unit I originally mentioned from Aircraft Spruce:
<http://www.aircraftspruce.com/menus/av/elt_kannad.html>
With accessories and the interface kit, this is around $4k. That's pretty expensive.
Whereas a more reasonable ELT would be around $200. This one looks pretty good.
<http://www.aircraftspruce.com/catalog/avpages/ack_tech.php>
Since there is no requirement in the US for any update, just that the satellite
detection system is going down the end of this month. Maybe using a PLB such as this
Ameri-King unit would be more affordable as an add - on.
<http://www.aircraftspruce.com/catalog/avpages/ak451PLB.php>
However there are many SPOT devices. This one requires an annual subscription. I don't
think any of them meet the requirements for 406 compliance in say Canada or Mexico.
<https://mysattracker.com/>
Since there will be no more satellite tracking of 121.5 ELT signals, I feel I should
do something more but not $4k worth of something.
Anybody have an opinion on using this one?
I don't see anything about crash detection. Maybe that's why it is less money.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Bellevue WA
425.241.1618 Cell
Float Flyr
Posted: Thu Jan 15, 2009 5:34 pm Post subject: ELT - 406 MHz or 121.5 standard? |
I have to call a TC inspector tomorrow.... I'll bounce this question off
him.
It is however my understanding that unless an imminent threat is encountered
by allowing an aircraft to fly, the plane in question has to meet the
specifications for flight authority in the country of registration. It is
then allowed to fly in Canada. That means not only the crowd that passes
through on their way to and from Alaska are legal but the folks form the
eastern seaboard that summer in Labrador are also legal. I think a plane
and pilot has 180 days before any requirement to get a Canadian registration
or license. In that 180 days I don't think TC even has the right to ramp
check a foreign registered plane without a request from the home country.
They do have the right to examine documents.
As far as I know the exceptions are... PP-UL and PP-Rec (Pilot
Permit-Ultralight, Pilot Permit-Recreational, Canada)are not allowed to fly
any Canadian aircraft, not registered UL in Canada, south of the border.
Holders of U.S. LSA licenses are not permitted to fly in Canada. The
excuses, not reasons, are the same in both cases... Incompatibility of the
medical requirements.
Canadian Ultralight specifications are currently that an ultralight aircraft
has to be under 1200Lb.(Basic) 1232Lb. for the "Advanced Ultralight" MTOW.
They must also have a stall speed, in the landing configuration, of no more
than 45 mph. At MTOW. This potentially puts Canadian ultralight aircraft
far above the weight characteristics of the US ultralight.(254 lb dry) In
Canada if it flies and carries any living body it must be registered. Even
our balloons are registered and their pilots are licensed.
Another difference is; in Canada an ultralight is defined by the aircraft
not by the registration. My 'Fox is registered Amateur built but I can fly
it as an ultralight, which I do on floats (no UL endorsement for floats) and
with the 121.5 ELT. Another difference in regulations which you guys may
find interesting is in Canada there is no endorsement for conventional
landing gear. Anyone with half a brain will get tail wheel training but it
is not a requirement. Funny we don't have thousands of tail draggers
plummeting out of the skies like rain in a thunderstorm.
I hope that the new President and the old PM will take a group of people
(FAA and TC lords) and lock them in a small basement somewhere, with bad
plumbing, no air conditioning and nothing but baked beans and prunes. Leave
them there until they get a reciprocal agreement. They can do the same
thing the Cardinals do... Send up white smoke to notify an agreement. What
are the bets they would have an agreement before supper the first day
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
infow(at)mts.net Guest
Posted: Thu Jan 15, 2009 6:05 pm Post subject: ELT - 406 MHz or 121.5 standard? |
Hey... Hey there Noel,
Kind of makes you wonder where there coming from!
Word out is that it may happen this year...
Ron Leclerc
Winnipeg, BRRRRR(-49 here this morning) Mb
CH701 #7-6699 Scratch Build
question off him.
encountered by allowing an aircraft to fly, the plane in question
has to meet the specifications for flight authority in the
country of registration. It is then allowed to fly in Canada.
That means not only the crowd that passes through on their way to
and from Alaska are legal but the folks form the eastern seaboard
that summer in Labrador are also legal. I think a plane and
registration or license. In that 180 days I don't think TC even
has the right to ramp check a foreign registered plane without a
request from the home country. They do have the right to examine
documents.
allowed to fly any Canadian aircraft, not registered UL in
Canada, south of the border. Holders of U.S. LSA licenses are not
permitted to fly in Canada. The excuses, not reasons, are the
same in both cases... Incompatibility of the medical
requirements.
ultralight aircraft has to be under 1200Lb.(Basic) 1232Lb. for
the "Advanced Ultralight" MTOW. They must also have a stall
speed, in the landing configuration, of no more than 45 mph. At
MTOW. This potentially puts Canadian ultralight aircraft far
dry) In Canada if it flies and carries any living body it must be
registered. Even our balloons are registered and their pilots
are licensed.
aircraft not by the registration. My 'Fox is registered Amateur
built but I can fly it as an ultralight, which I do on floats (no
UL endorsement for floats) and with the 121.5 ELT. Another
difference in regulations which you guys may find interesting is
in Canada there is no endorsement for conventional landing gear.
Anyone with half a brain will get tail wheel training but it is
draggers plummeting out of the skies like rain in a thunderstorm.
people (FAA and TC lords) and lock them in a small basement
somewhere, with bad plumbing, no air conditioning and nothing but
baked beans and prunes. Leave them there until they get a
reciprocal agreement. They can do the same thing the Cardinals
do... Send up white smoke to notify an agreement. What are the
Noel
Float Flyr
Posted: Thu Jan 15, 2009 7:01 pm Post subject: ELT - 406 MHz or 121.5 standard? |
Problem as i see it is the new system only adds an ident. to the signal.
That means when they send out the search team they know if they are looking
fo a 2 seater or two hundred seater. The GPS coordinates is an expensive
add on. I think something like the spot with a 121.5 should be enough for
private planes.
Noel
Kitfox III-A
