naumuk(at)windstream.net Guest
Posted: Sat Jan 10, 2009 7:30 pm Post subject: It works, but it doesn't |
All-
Attached is a picture (Using my new camera, the old one died) of a late-in-the-process heartbreak. The last hole I had to drill for my Dynon frame shattered the laminate.
The downside is, I blew 3 hours wet sanding out the big scratches from cutting the holes. The upside is, I should be able to remove the laminate using a heat gun and have a cleanly cut panel. Everything is square to within .1 degree according to my new laser level- anything that looks out of whack is parallax.
Hey, they call this Experimental for good reason. I just have to keep telling myself that. You are experimenting. You are experimenting. You are...
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
225.6 KB |
341 Time(s) |
