longg(at)pjm.com Guest
Posted: Tue Jan 13, 2009 10:57 am Post subject: Z-13 Questions |
I be using an 85 Amp IR alternator with this design. Couple of questions.
<![if !supportLists]>1. <![endif]>For the primary alt, is it ok to go with an 80 Amp Shunt and ANL? I understand they will take 1xx % of rating?
<![if !supportLists]>2. <![endif]>For the secondary alt is it ok to replace the fuse-link in the design for an ANL? Rating 10 amp?
<![if !supportLists]>3. <![endif]>The B & C schematic is slightly different in breaker/wire sizing. Should I adhere to that more closely than Bob’s?
<![if !supportLists]>4. <![endif]>If I understand the instruction the SD-8 indicates the warning light is ON when the switch is off or the OVP has tripped. I’m not sure if I want that big yellow bulb on all the time? What other warning light configurations are folks using?
<![if !supportLists]>5. <![endif]>My ANLs/contactors will be on the firewall. Are there any caveats for protecting them from heat, dirt, oil, water etc?
Glenn
Posted: Tue Jan 13, 2009 12:36 pm Post subject: Z-13 Questions |
At 12:54 PM 1/13/2009, you wrote:
| Quote: | I be using an 85 Amp IR alternator with this design. Couple of questions.
1. For the primary alt, is it ok to go with an 80 Amp Shunt
The shunt is the same size as alternator rating. You
can use an ANL as low as 35A with a 60A alternator.
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
| Quote: | 2. For the secondary alt is it ok to replace the fuse-link in
Sure. Not an ANL but an 20A ATC fuse in an in-line holder.
http://aeroelectric.com/Pictures/Fuses/Fuse_Holders/ifh-2.jpg
| Quote: | 3. The B & C schematic is slightly different in breaker/wire
sizing. Should I adhere to that more closely than Bob's?
His schematic works as advertised. So does mine.
| Quote: | 4. If I understand the instruction the SD-8 indicates the
I'm not sure if I want that big yellow bulb on all the time? What
Don't install it. I presume you have a low voltage warning
that is independent of the alternator(s).
| Quote: | 5. My ANLs/contactors will be on the firewall. Are there any
Cessna, Piper and Beech don't worry about it.
http://aeroelectric.com/Pictures/Wiring_Technique/A36_Firewall_A.jpg
It must not be a big deal.
( -Thomas Paine 1776- )
Posted: Tue Jan 13, 2009 1:12 pm Post subject: Z-13 Questions |
Excellent, thanks Bob.
