GPS Serial Data to Garmin GTX-327 Transponder
Site Admin
PostPosted: Fri Jan 02, 2009 10:45 am    Post subject: GPS Serial Data to Garmin GTX-327 Transponder Reply with quote
Listers,
I've tried sending two different sources of NMEA 0183 data at 4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), and configured for "GPS" input. But I don't get anything on the GTX-327 serial input test display. I have been successful at getting AirData Z-format from the GRT EFIS at 9600 baud into either of the GTX-327 serial ports, so the ports are good. The NMEA 0183 data registers correctly on other devices reading it so the GPS serial output seem fine. The GTX-327 just won't seem to see the GPS data for some reason.
Am I doing something wrong? Has anyone else tried this successfully?
Thanks!
RV-8 #82880 N998RV
Kellym
PostPosted: Fri Jan 02, 2009 1:13 pm    Post subject: GPS Serial Data to Garmin GTX-327 Transponder Reply with quote
Why would you send GPS data to a Mode A/C transponder? It only transmits
a reply with altitude data from encoder. Just wondering if there is some
feature to the GTX327 that is unique besides acting as a backup up
altimeter and timer? Guess I am clueless about what you are trying to do.
Matt Dralle wrote:
Listers,
Thanks!
RV-8 #82880 N998RV
Kelly McMullen
KCHD
stein(at)steinair.com
PostPosted: Fri Jan 02, 2009 2:54 pm    Post subject: GPS Serial Data to Garmin GTX-327 Transponder Reply with quote
Because you can have the Txpdr automatically go from STBY into ALT and back
to STBY when it has a GPS signal to it...which is what I missed in Matt's
first post (Sorry Matt - I thought you were only looking for the AltEnc
data, not the GPS data). I don't know as you'll see anything in test mode
though, even if it is hooked up right.
So, in your setup you should have a line running from the GRT to the Txpdr
RS-232 channel for AltEnc data and another line RS-232 line for GPS
data....sorry about the missed replay earlier!
Stein
[quote]--
