Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27562 Location: Livermore CA USA
Posted: Fri Jan 02, 2009 10:41 am Post subject: GPS Serial Data to Garmin GTX-327 Transponder |
Listers,
I've tried sending two different sources of NEMA 0183 data at 4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), and configured for "GPS" input. But I don't get anything on the 327 serial input test display. I have been successful at getting AirData Z-format from the GRT EFIS at 9600 baud into either of the GTX-327 serial ports, so the ports are good. The GTX-327 just won't seem to see the GPS data for some reason.
Am I doing something wrong? Has anyone else tried this successfully?
Thanks!
RV-8 #82880 N998RV
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
_________________ Matt Dralle
GrummanDude
Posted: Fri Jan 02, 2009 12:44 pm Post subject: GPS Serial Data to Garmin GTX-327 Transponder |
Call Jeff at (661) 949-8300
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
douglist(at)macnauchtan.c Guest
Posted: Fri Jan 02, 2009 1:23 pm Post subject: GPS Serial Data to Garmin GTX-327 Transponder |
At 10:39 -0800 1/2/09, Matt Dralle wrote:
| Quote: | I've tried sending two different sources of NEMA 0183 data at
I recently had experience with a Garmin 425 GPS (a tiny one not
really for aircraft use) that claimed to put out RS232 compliant
signals.
What I discovered, with an oscilloscope, was a signal level that was
"low" at about +150 mV and high at about +4.5 V with a fairly high
internal resistance that had problems at 1 mA output levels. Without
careful grounding at the pins of the GPS the +150 mV was even worse.
RS232-C, which is the only official RS232 spec I can afford right now
calls for a negative going level for the low value and Garmin simply
does NOT meet that. There are some newer RS232 specifications around
that might describe Garmin's output level but when I asked all I got
was "RTFM" and the PDF manual simply says RS232 compliant.
I placed a 1.5 volt dry cell in series with Garmin's output with a
polarity that subtracted 1.5 volts from all signals. The resulting
data stream went negative and was acceptable to the old Macintosh I
was working with at the time. Some USB to RS232 converters would
work and others would not.
You seem to be talking about the Garmin as a receiver rather than a
transmitter and I have no idea how well Garmin's "RS232 compliant"
receiver behaves. I do doubt that you will get an authoritative
answer from them.
--> A fair tax is one that you pay but I don't <--
