Tack generator
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
HBaker
PostPosted: Mon Dec 29, 2008 5:28 pm    Post subject: Tack generator Reply with quote
I have just bought a tack generator, for the M14 but cannot find out where it goes, must be another adapter or something, any one have a pic, also where is a good place to mount the water separator. Confused
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Currently building a Murphy Moose - any help would be appreciated.
dsavarese0812(at)bellsout
PostPosted: Tue Dec 30, 2008 6:17 am    Post subject: Tack generator Reply with quote
See attached.
Dennis
 Filesize:  114.29 KB
 Viewed:  976 Time(s)
eddiemoranii(at)yahoo.com
PostPosted: Tue Dec 30, 2008 1:46 pm    Post subject: Tack generator Reply with quote
To all,
I tell you what, guys like Dennis, Steve, George, Doug, etc. are an invaluable asset to us. I could NOT have installed my M14 into my Moose without them.
If you have not contributed to Matronics then you need too.
Eddie
--- On Tue, 12/30/08, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
[quote]From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Subject: Re: Tack generator
To: m14pengines-list(at)matronics.com
Date: Tuesday, December 30, 2008, 9:16 AM
See attached.
Dennis
yakplt(at)yahoo.com
PostPosted: Tue Dec 30, 2008 4:28 pm    Post subject: Tack generator Reply with quote
Just a word of caution. If the original thread on mount for the tach generator is still there, no problem. It's easy to install. If the outer plate had been removed, be very cautious. If you remove the wrong plate at that tach gen attachment point, you can disturb the air start distributor timing which is one of the worst things to get working again on the entire aircraft. Ask me how I learned all about THAT. That's the big green thing with all those metal lines attached in the photo. Just looking at that monster makes me cringe.
Second, the tach generator cannon plug. Most problems with incorrect reading tach's is because of a broken wire in this plug. They break VERY easily. The wire is brittle and the solder flux the Russians use corrodes much easier than does our stuff.
Lastly, these three wires in the tach gen plug are shielded. If the shield wire to this plug breaks, or if the shield is not connected properly, the noise from the tach generator can become so extreme that it will actually damage a stock Russian radio. Hard to believe, but I saw it happen with my own eyes. I also fixed the radio. The first stage broad band amplifier transistor shorted base to collector. Now THAT is serious noise!
Just thought I would pass along lessons regarding this little device that I had to learn about the hard way.
Mark Bitterlich
Sent: Tuesday, December 30, 2008 4:45:06 PM
To all,
Eddie
See attached.
Dennis
cattoni(at)glastar.ca
PostPosted: Tue Dec 30, 2008 6:16 pm    Post subject: Tack generator Reply with quote
Hi Mark,
We are building a Moose. In Kelowna BC Canada. As soon as we get the engine mount from Murphy, we will hang the engine. I would like to ask you for your private e-mail address, so that I could contact you off list.
Thank you so much !
Peter Cattoni
PostPosted: Tue Dec 30, 2008 6:18 pm    Post subject: Tack generator Reply with quote
Thank you Eddie.
We are just getting to that stage ( engine installation M14PF ) ! Your post is very helpful to us, because we know now whom to ask.
Happy New Year to all !
Peter Cattoni
george(at)gesoco.com
PostPosted: Wed Dec 31, 2008 5:35 am    Post subject: Tack generator Reply with quote
We at Motorstar NA have a FREE disc with the maintenance manuals, the service manuals and a lot of instillation information. We expect to also have all the data up on our new Motorstar NA web site for download or reference. If you need a disc then contact me offline and we will send one.
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Yak Pilot
Sent: Tuesday, December 30, 2008 7:27 PM
Mark Bitterlich
To all,
Eddie
See attached.
Dennis
----- Original Message -----
To: m14pengines-list(at)matronics.com (m14pengines-list(at)matronics.com)
Sent: Monday, December 29, 2008 7:28 PM
Subject: Tack generator
--> M14PEngines-List message posted by: "HBaker" <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)>
http://forums.matronics.com/viewtopic.php?p=221737#221737
http://www.matronics.com/c Thank you for your generous
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
href='3D"http://www.matronics.com/Navigator?M14PEngines-List"'>http://www.matronics.com/Navigator?M14PEngines-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
PostPosted: Wed Dec 31, 2008 5:44 pm    Post subject: Tack generator Reply with quote
Have fun.... The Doug I mentioned was Doug Sapp of Omak, Wa. The other Doug is Doug Franklin who used to work for Murphy Aircraft and has installed about 15 M14s in various aircraft.
Doug Sapp has a great air system if you have not already gone down that road.
Eddie Moran
--- On Tue, 12/30/08, Peter Cattoni <cattoni(at)glastar.ca> wrote:
[quote]From: Peter Cattoni <cattoni(at)glastar.ca>
Subject: RE: Tack generator
Date: Tuesday, December 30, 2008, 9:18 PM
Message Thank you Eddie.
Peter Cattoni
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
