Paul A. Franz, P.E.
Posted: Wed Dec 24, 2008 10:38 am Post subject: use of HDPE as ski base material |
On Wed, December 24, 2008 9:23 am, Lynn Matteson wrote:
Jim-
I just bought 3/16" HDPE for my temporary ski bottoms. When I've
proved the design, I may or may not go with the laminated ply bottoms.
The HDPE is half the cost of UHMW, but a little more friction, I'm
told. Have you heard of it?
I'm very familiar with HDPE. I have used it for dredge pipelines. The stuff is very
tough and you can easily drag thousand foot sections across the frozen tundra. It is
even resilient to damage. When the eskimo kids shot holes in the 12" pipeline at Pt
Hope, they heal enough so that no repairs were needed.
It has a rather serious downfall though. You cannot glue anything to it. It can only
be welded. Even compression fittings are difficult because the stuff creeps and
relaxes.
The only way you're going to be able to use it on skis is with some kind of mechanical
attachment like screws. No glue will stick to it. Pipe sections are joined via a
welding process. The ends are first machined square then the two sections are squeezed
against a hot plate until they just start to melt, the hot plate is removed and the
two sections are jammed together.
I don't think you're going to like it much since you can't bond anything to it except
more HDPE and that has to be done quickly and the temperature varies for fusion
depending on the molecular length of the HDPE batch you've got. If you bend it, then
leave it alone, it'll just return to its original shape unless you get it hot in the
bend.
Since you're only planning it temporarily to get your design shape right, maybe screws
through it won't be much of a problem. Forming it is not too difficult, but it just
returns to it's original shape when the load is removed.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Lynn Matteson
Posted: Wed Dec 24, 2008 12:06 pm Post subject: use of HDPE as ski base material |
Thanks for the heads up regarding bending it...I was going to try for
a slight bend up on the sides, but I'll forget about that. My method
of attachment...like my present skis...is with rivets, but this time
I'm going to go with flat head screws through rosette-welded tubes in
the 6 corner locations. I've had a few of the rivets pop (no pun
intended) loose before. Like now, the fronts will have as a cable
attachment, at least one AN-42 eye bolt to insure a through-the-
bottom attachment, which will also serve to bolt the bottom at that
location.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Dec 24, 2008, at 1:36 PM, Paul Franz - Merlin GT wrote:
<paul(at)eucleides.com>
> Jim-
> bottoms.
The stuff is very
12" pipeline at Pt
to it. It can only
stuff creeps and
relaxes.
kind of mechanical
joined via a
removed and the
varies for fusion
you bend it, then
get it hot in the
bend.
right, maybe screws
Paul A. Franz
Bellevue WA
425.241.1618 Cell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Wed Dec 24, 2008 1:44 pm Post subject: use of HDPE as ski base material |
You should use something with an anvil lock like cherry max for that.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Wed Dec 24, 2008 2:44 pm Post subject: use of HDPE as ski base material |
I think the ones that popped on my skis was due to the head being
pulled...like an umbrella in a windstorm. I used aluminum rivets
because I didn't want to use the much stronger steel, which would
have crushed the UHMW, I thought. But I used enough rivets to
compensate for loosing a few. I may try a few steel rivets in a test
to see how much the countersunk HDPE will crush.
I think that with the through-bolts, (machine screws actually), the
rivets will be merely holding the material flush, and not so much
subjected to side loads, etc.
Lynn Matteson
Sensenich 62x46
system;
On Dec 24, 2008, at 4:43 PM, Noel Loveys wrote:
Noel
N369LM |
