jcumins(at)jcis.net Guest
Posted: Sat Dec 20, 2008 8:28 pm Post subject: HS attach bracket issue |
BODY { font-family:Arial, Helvetica, sans-serif;font-size:12px; } Well all you rv10 buikders out there. Looks like i finally mide my first big boo boo. And I will call Vans Monday morning.
When i final drilled the left and rt horv. stab fwd spar attach brackets i made sure to clamp both of them to a piece of angle stock so that they were final drilled parrallel to each other.
Well when i went to rivit them on today all looked well and i did not think to reclamp them to a piece of angle stock. Now here comes the probelm. The Left bracket is about 1/32 of a inch oft of parallel to the other. When i clap the angle stock to the rt bracket it contacts the inboard edge of the left bracket like it should.
When i clamp the angle stock to the left bracket it misses the rt bracket by a bunch. so this telles me the left bracket is not parallel.
I do think that it probable should be fixed, to prevent a twisting force on the bracket, rivits and HS fwd spar.
My question is can i just shave a very small amount off the inboard side of the left bracket bottom to get them back parallel, would this be a ok repair or should i make new bracket and redo it.
I do think i will order the material to make a new on or order one already made from the company that makes them on a cnc machine.
Boy was this very upsetting to find when i was finished with the front spar.
Word of advice would be greatly appreciated,
Thanks.
Horz Stab build mode
SN 40864
pascal(at)rv10builder.net Guest
Posted: Sat Dec 20, 2008 8:44 pm Post subject: HS attach bracket issue |
send me the plans page and step so I can see where you are and try to remember what I did at that point.
Pascal
Sent: Saturday, December 20, 2008 8:26 PM
Subject: HS attach bracket issue
Thanks.
SN 40864
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
rene(at)felker.com Guest
Posted: Sat Dec 20, 2008 8:50 pm Post subject: HS attach bracket issue |
Just an Idea, but since it looks like they were parallel when you drilled them, just drill out the rivets…..clamp them down and re-rivet.
Rene'
801-721-6080
tsts4
Posted: Sun Dec 21, 2008 4:23 pm Post subject: Re: HS attach bracket issue |
Another option would be to shim it back to level. When you attach the HS to the tailcone, two 1/8 shims get match drilled and placed under each bracket anyway. So adding a 3rd, thin shim to the stack shouldn't be a problem.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Posted: Sun Dec 21, 2008 10:32 pm Post subject: HS attach bracket issue |
Rene
I did just that this afternoon and it looks like i am good to go. Bracket is re-rivited and parralel to the other.
thanks so much
On Sat 20/12/08 8:50 PM , "Rene" rene(at)felker.com sent:
Rene'
801-721-6080
Posted: Mon Dec 22, 2008 4:38 pm Post subject: HS attach bracket issue |
Rene’
Your idea worked great. Thanks so much. Next time I am in SLC I will look you up.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene
Sent: Saturday, December 20, 2008 8:50 PM
Subject: RE: HS attach bracket issue
Rene'
801-721-6080
