hammer408(at)comcast.net Guest
Posted: Thu Dec 18, 2008 4:08 pm Post subject: Ignition Switch |
Bob:
I just purchased an ACS Ignition Switch (A-510-2) [ Off-Right-Left-Both-Start] and was looking at their wiring instructions. I then downloaded your Z-26 diagram for Ignition Switch Options - Magento. Both wiring diagrams are basically identical with a few differences:
Both diagrams jumper GRD &R for impulse coupling to Right Mag - shielded wire
Both depict L to Left Mag - shielded wire
Both depict B to Main Bus (7amp)
Both diagram S to Starter Seleniod
The differences are:
ACS has shielded wire grounded at the right & left mag only, and the GRD terminal grounded at the grounding block or nearest structure.
whereas your Z-26 have these wires shielded at both ends with the shield closest to the ignition switch wired to the GRD, but your GRD is NOT grounded to a grounding block or nearest structure....
ACS also says to use all shielded wire....I personally think that is overkill...
So, would you recommend grounding at both ends of the shielding wire, but why not ground at the switch, or was this accidently omitted by you?
Comments, suggestions appreciated.
Henry
Posted: Fri Dec 19, 2008 6:38 pm Post subject: Ignition Switch |
Posted: Sat Dec 20, 2008 11:01 am Post subject: Ignition Switch |
