fvalarm(at)rapidnet.net Guest
Posted: Tue Dec 02, 2008 10:37 pm Post subject: breaker specs |
Bob, et al
I'm trying to educate myself about circuit breakers (Klixon in this case). I can't find any tech info online, nor any sales info from Mouser, Digi-key, Electronic etc. Can you suggest a source?
I'm beginning to think Klixon is not a manufacture's name but just a product name. Still, I should be able to find performance specs online though, no?
Relevance: Due to space and design goals, I am incorporating fuse blocks and some breakers (Klixon) into my panel (RV7A). However, I have just recently discovered another type of breaker that I'm sure you're aware of, namely the switch/breaker, see
http://www.avionicsmall.com/index.php?main_page=product_info&cPath=189&products_id=8161
This nifty puppy will save space by incorporating a switch and circuit breaker into one unit at comparable cost to a switch and klixon breaker. However, when reading the performance specs, (click on the data sheet tab here http://www.mouser.com/Search/Refine.aspx?Keyword=655-W31-X2M1G-5 ) it looks to be very slow acting at the current flows that we are dealing with. I would think that we want an overload to be shut own within seconds not minutes. Even at a response time of 10 seconds, the amount of overload would have to be 150-250% of rated value ( I suppose dependant on ambient temperature). I don't think this is acceptable for an aircraft, do you?
This is why I wonder what the Klixon's response times are. Maybe they are no better. I'm pretty sure that an ATO type fuse will be lightning fast at 150% overload, no? I look forward to you comments.
Bevan
rjquillin
Posted: Wed Dec 03, 2008 7:42 am Post subject: breaker specs |
Try here:
http://www.sensata.com/
Ron Q.
At 22:35 12/2/2008, you wrote:
[quote] Bob, et al
I'm trying to educate myself about circuit breakers (Klixon in this case). I can't find any tech info online, nor any sales info from Mouser, Digi-key, Electronic etc. Can you suggest a source?[b]
jay(at)horriblehyde.com Guest
Posted: Wed Dec 03, 2008 8:02 am Post subject: breaker specs |
Just as a general note on electrical protection; the trip times that you
mention for such an overload (in the region of 150-250%) are perfectly
acceptable; an overload condition should not produce a quick response, but
allow the system time to shed the overload if it is a transient condition
(starting for example). If there is a fault that generates a high current
then the protection element (cct breaker) should trip much faster.
In large power electrical systems this is called an IDMT characteristic
(Inverse Definite Mean Time); in a small CB this characteristic is attained
by use of a bi-metallic strip that heats up slowly during an overload; once
past a certain limit the circuit is opened using clever spring thingie
arrangements.. When a large current is passed the strip heats a lot
faster causing the faster trip.
The circuit that you are feeding should be able to handle the overload
condition for that period of time without damage, it’ll just heat up.
Incidentally, that is why there is an earth (or ground) in electrical
systems- it is there to create a defined return path to the power source
that will create a good solid and DETECTABLE fault. Once detected it can be
cleared. That’s another reason to make sure that metal skins are well
bonded (electrically- that is, they are electrically continuous) in an
aircraft, so that if a positive wire rubs through somewhere it must find a
good return path to the negative terminal of the battery as soon as
possible. That way the fault can be detected and isolated by your cleverly
designed reticulation system and fuses/ breakers
Fuses have similar characteristics; they also rely on heat generated by
conducted current..
Jay
________________________________________
From: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of B Tomm
Sent: 03 December 2008 08:36 AM
Subject: breaker specs
Bob, et al
ucts_id=8161
Bevan
dangerous content by Pinpoint, and is
believed to be clean.
JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
Posted: Wed Dec 03, 2008 9:54 am Post subject: breaker specs |
BEVAN: I don’t know if this is what you are looking for but try this link.
http://www.sensata.com/products/controls/acb.htm
They also have a catalog that you can download.
Hope this helps.
Joe R
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of B Tomm
Sent: Tuesday, December 02, 2008 11:36 PM
Bob, et al
Bevan
012345678901234
Posted: Fri Dec 05, 2008 6:07 am Post subject: breaker specs |
At 12:35 AM 12/3/2008, you wrote:
| Quote: | Bob, et al
I'm beginning to think Klixon is not a manufacture's name but just a product name. Still, I should be able to find performance specs online though, no? |
"Klixon" has been associated with Texas Instruments for
a very long time. I don't know if it originated with TI
or they acquired it. Klixon forte was a slightly dished
disk of homogenous material useful for push-button springs
and the bi-metal versions suited for use as current sensors
in breakers.
You can drink from the firehose of data on Sensata-Klixon
at:
http://www.sensata.com/products/controls/circuitbreakers.htm
This is why I wonder what the Klixon's response times are. Maybe they are no better. I'm pretty sure that an ATO type fuse will be lightning fast at 150% overload, no? I look forward to you comments. |
Don't loose any sleep over it. Studying the response times
of the hundreds of products will not yield satisfying
conclusions. ALL breakers and breaker-switches are suited
to the task of keeping the smoke inside the wires they
feed. The switch-breaker you've cited has a very close
cousin in service on the Beech Bonanza and Baron lines
to the tune of 80,000+ units over the past 25 years or
more.
( -Thomas Paine 1776- )
