Desperation is the mother of invention
naumuk(at)alltel.net
PostPosted: Sat Nov 29, 2008 11:49 am    Post subject: Desperation is the mother of invention Reply with quote
All-
The pictures are self explanitory. Now I'll solder the joint just to be on the safe side. After insulating boots come in from ACS, I'll install them over the terminals using silicone grease, then seal the boot/cable insulation juncture with shrink wrap.
You know what? Take a close look at my vise in "After crimp". If I took the regular jaws out to allow further closing travel, I probably could have made the crimp using the vise pipe holders!
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
 Filesize:  46.95 KB
 Viewed:  330 Time(s)
 Filesize:  45.07 KB
 Viewed:  339 Time(s)
tonyplane(at)bellsouth.ne
PostPosted: Sat Nov 29, 2008 11:58 am    Post subject: Desperation is the mother of invention Reply with quote
FWIW: I used my nicropress crimper (the handheld one used for swaging nicropress cable sleeves) to swage on my battery terminal ends to their cables. Has been working well for almost 3 1/2 years.
Tony Graziano
larry(at)macsmachine.com
PostPosted: Sat Nov 29, 2008 1:38 pm    Post subject: Desperation is the mother of invention Reply with quote
Bill,
Before you get the other end done, perhaps a short length of shrink wrap
would be advisable to minimize the exposed copper and insulating end.
Larry McFarland
Bill Naumuk wrote:
All-
Bill Naumuk
Townville, Pa.
PostPosted: Sat Nov 29, 2008 2:07 pm    Post subject: Desperation is the mother of invention Reply with quote
Tony-
Never thought of it. Very good idea, because the tool can go to the wire rather than the wire going to a vise.
Little hints like this are what deserve to be archived. Too bad we couldn't filter out all the negative crap in the database. Thanks.
Bill
