a.s.elliott(at)cox.net Guest
Posted: Mon Nov 24, 2008 3:15 pm Post subject: Alternator noise |
I am getting a lot of what is clearly alternator or voltage regulator noise on my radio. (No noise on battery, increasing noise in volume and frequency as RPM increases. Radio is a Terra 760D fed from the main bus.
I have a small permanent magnet alternator (18 amp John Deere) feeding a motorcycle voltage regulator (Crane Fireball), connected to the main bus using the B&C relay/overvoltage protection kit which already includes a big filter capacitor.
One strange thing I have noticed is that when I turn on the battery, the alternator fail light comes on, but when I switch on the alternator relay (even with the engine not running), the light goes out. Perhaps I wired it incorrectly? Charging seems to work fine.
Anyone had a similar problem and found a fix?
Andy Elliott, Mesa, AZ
N601GE,601XL/TD,Corvair
nuckolls.bob(at)cox.net Guest
Posted: Tue Nov 25, 2008 10:58 am Post subject: Alternator noise |
At 05:13 PM 11/24/2008, you wrote:
| Quote: | I am getting a lot of what is clearly alternator or voltage
from the main bus.
It would be helpful to see your power distribution diagram.
Did you use a z-figure? Can you describe your ground system
to us too?
( -Thomas Paine 1776- )
