Removing Paint Residue
dvonruden(at)generalequip
PostPosted: Fri Nov 14, 2008 2:34 pm    Post subject: Removing Paint Residue Reply with quote
During the course of restoring my CJ, I stripped and removed the original Chinese paint. Gear wells and other appropriate areas were repainted before final assembly. Now I’m planning to have the aircraft repainted in the spring of 2009. Does anyone have a really fast and good method to remove the last bit of paint that is remaining around the circumference of some of the rivet heads? I plan to do as much of the prep work as possible before dropping it off to a paint shop.
<![if !mso]> <![endif]>
<![if !mso]> <![endif]> <![endif]--><![if !vml]>[img]cid:image003.gif(at)01C94676.B1788280[/img]<![endif]>Dennis Von Ruden
General Equipment Company
507.451.5510 (P)
507.451.5511 (F)
dvonruden(at)generalequip.com
ALL INFORMATION IN THIS EMAIL, AND/OR ATTACHMENT(S) IS CONFIDENTIAL. If you received this e mail in error, and are not the recipient(s) or responsible for receiving this e mail for the recipient, please inform the sender immediately, delete the e mail and any attachment(s) associated.
This email has been scanned by Barracuda - Email Security System.
 Filesize:  3.26 KB
 Viewed:  1740 Time(s)
 Filesize:  77.91 KB
 Viewed:  347 Time(s)
dougsappllc(at)gmail.com
PostPosted: Fri Nov 14, 2008 4:01 pm    Post subject: Removing Paint Residue Reply with quote
