kesleyelectric(at)chooseb Guest
Posted: Fri Nov 28, 2008 4:23 pm Post subject: RFI problem |
Bob and all,
I recently upgraded the lighting in the shop where my airplane is under construction from the 20+ year old, 8 foot fluorescent fixtures to the newer, more energy efficient type with electronic ballasts. The light is much better, and that irritating audible hum that the old lights made is gone. However, all radio reception and the lower TV channels are gone too, now nothing but static. Both the radio and TV are connected to an outside antenna via RG6 coax. Someone at an electronics store suggested that replacing the existing coax with RG6 Quad Shield in from the antenna would solve the problem. I am not familiar with this product. Any thoughts? I rather miss having the radio on while working on the plane.
Tom Barter
Kesley, IA
Avid Magnum - wiring
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 28, 2008 5:27 pm Post subject: RFI problem |
At 06:19 PM 11/28/2008, you wrote:
| Quote: | Bob and all,
My best guess is that the ballasts were not filtered
to control the effects of radiation from the tubes.
I've heard of this before. The 8' tubes make really
good antennas for radiating the noise. Additional
shielding of the feedline to your radios is unlikely
to make any difference. Try a hand-held AM/FM radio
and see how far you have to move away from the lights
to get unaffected reception.
( -Thomas Paine 1776- )
Posted: Sat Nov 29, 2008 8:16 am Post subject: RFI problem |
I need to get 5-10 feet outside of the building before the reception clears
up.
Tom Barter
Posted: Sun Nov 30, 2008 9:01 am Post subject: RFI problem |
At 10:13 AM 11/29/2008, you wrote:
<kesleyelectric(at)chooseblue.coop>
up.
Hmmm . . . assuming it's a metal building, it seems
likely that the noise is radiating directly into
the radio through the enclosure. You stated that the
antenna was outside and would therefore expect to
see a similar benefit of shielding or distance
attenuation.
If you have several fixtures, it's probably easier
to find a radio that is more resistant to local
noises than to figure out how to filter/shield
the lamps.
As a final experiment, can you pull the antenna
coax outside and then operated the radio outside
the building while connected to the antenna coax?
