Electrical Power requirements.
Float Flyr
PostPosted: Sat Nov 08, 2008 6:41 am    Post subject: Electrical Power requirements. Reply with quote
The strobe unit you have, should have a plate on it with the info on how many Amperes it draws. Your radio should have the same thing. Nav lights, not LED, are usually less than 1 Amp.
Simply add up all the amps marked on your equipment or in the manuals and make sure the total is no more than 80% of the output of the 582 lighting coil. (16 * .8 = 12.8A) If you wire in a load meter which reads the amps being used by the system then you wi8ll be safe to go to the full 16 Amps.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: Friday, November 07, 2008 4:10 PM
To: kitfox matronics
Subject: RE: Kitfox-List:
Noel, OK, Leonard said I should haave no problem. I do have older 1996 Aeroflash strobes. I'll see how much power they use, but it sounds like I'm OK. Thanks for info.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Subject: RE:
Date: Fri, 7 Nov 2008 00:49:01 -0330
Newer Strobes ~ 1A
Nav lights ~ 1A if that much
Radio ~ 500 ma receive / up to 5A Tx. You should have plenty of power!
Noel
Sent: Thursday, November 06, 2008 11:38 PM
Subject:
582 Drivers, I am rebuilding a Mod 3 that was originally equiped with a 912 that I am installing a 582 in. the plane has strobes, nav lights and a radio. I fear that my lighting coil will not put out enough power to handle all those electrics. I remember seeing a set up for an auxillary alternator belt drive off of the prop hub., maybe from CPS, I don't know. I remember that it seemed to cost 3 X what I thought it should. Anyone out there have experience with one or have designed one yourself.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.com ww.matronics.com/contribution>http://www.matronics.com/Navigator?Kitfox-Listronics.com
5
6
7
8
9
 Filesize:  7.29 KB
 Viewed:  1556 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
