Strange goop in the overflow bottle
larry(at)macsmachine.com
PostPosted: Sun Nov 02, 2008 4:15 pm    Post subject: Strange goop in the overflow bottle Reply with quote
Hi Guys,
This week begins the Annual Inspection of my 601HDS and one of the first
things was a coolant leak that dripped ever so slightly from the coolant
overflow bottle. Large filler hoses were moved out of the way. I tried
to siphon the last half-inch of coolant, but goop on the bottom
prevented it. The coolant bottle was removed and the last half-pint of
coolant was poured into another bottle. The bottom goop was very
different from the clean and transparent coolant. It was gray-black and
didn’t act or feel like oil. After flushing the goop out of the bottle
in two level chunks, I put the goop on paper and it dried to a
gray-black cake. Rubbed between the fingers, it felt like an extremely
fine compound. The bottle was refilled and set on a shelf to check it
again for leakage. There was a leak spot on the back firewall side where
the bottle contacts a rivet head. I've another bottle to install but was
very curious about the accumulated 1/8-inch of goop on the bottom of the
coolant bottle. Any ideas of what it might be? I've never encountered
this before. It's not oil, nor does it leave a carbon trace on the
fingers. It washes off like regular soil. Volume was 1/8 x 2 x 3 lg. The
coolant bottle has never been changed or cleaned, but my coolant has
been changed twice at 60 hours. Any ideas?
Thank you for your response,
Ron Lendon
PostPosted: Sun Nov 02, 2008 7:37 pm    Post subject: Re: Strange goop in the overflow bottle Reply with quote
Larry,
We Ionize the water in production at GM to eliminate electrolysis. That or a chemical reaction between the aluminum and the coolant itself can cause erosion of the aluminum. It sounds like it might be that type of a thing or its getting dirt from somewhere. If coolant can get out dirt can get in.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
jimandmandy(at)yahoo.com
PostPosted: Mon Nov 03, 2008 10:35 am    Post subject: Strange goop in the overflow bottle Reply with quote
You didnt say, but can we assume it is a Rotax 912 of some sort?
If so, did you use Evans waterless coolant or an automotive coolant and water mixture?
--- On Sun, 11/2/08, LarryMcFarland <larry(at)macsmachine.com> wrote:
Subject: Strange goop in the overflow bottle
To: zenith601-list(at)matronics.com, "stratus-list" <stratus-list(at)matronics.com>
Date: Sunday, November 2, 2008, 4:14 PM
--> Zenith601-List message posted by: LarryMcFarland<larry(at)macsmachine.com>Hi Guys,This week begins the Annual Inspection of my 601HDS and one of the first things was a coolant leak that dripped ever so slightly from the
coolant overflow bottle. Large filler hoses were moved out of the way. I tried to siphon the last half-inch of coolant, but goop on the bottom prevented it. The coolant bottle was removed and the last half-pint of coolant was poured into another bottle. The bottom goop was very different from the clean and transparent coolant. It was gray-black and didn˘t act or feel like oil. After flushing the goop out of the bottle in two level chunks, I put the goop on paper and it dried to a gray-black cake. Rubbed between the fingers, it felt like an extremely fine compound. The bottle was refilled and set on a shelf to check it again for leakage. There was a leak spot on the back firewall side where the bottle contacts a rivet head. I've another bottle to install but was very curious about the accumulated 1/8-inch of goop on the bottom of the coolant bottle. Any ideas of what it might be? I've never
encountered this before. It's not oil, nor does it leave a carbon trace on the fingers. It washes off like regular soil. Volume was 1/8 x 2 x 3 lg. The coolant bottle has never been changed or cleaned, but my coolant has been changed twice at 60 hours. Any ideas?Thank you for your response,Larry McFarland 601HDS at www.macsmachine.com
PostPosted: Mon Nov 03, 2008 3:46 pm    Post subject: Strange goop in the overflow bottle Reply with quote
Hi Jimbo,
I fly a Stratus Subaru and use 50/50 de-ionized water and anti-freeze.
I've never tried the waterless stuff.
The goop when burned, smelled like rubber, so I must presume the residue
is hose material that gets worn
off the inside diameter by the fast moving coolant. Then it gathers up
at my overflow when the engine is
shut down and collects in the bottom of my coolant bottle.
and water mixture?
Hi Guys,
coolant
encountered
K Dilks
PostPosted: Tue Nov 04, 2008 3:46 am    Post subject: Re: Strange goop in the overflow bottle Reply with quote
The gloop is often formed over time when some one has use a little grease or spray ( WD40) to put the pipes on or off with. with the heat and glycol a small amount of the the rubber tubeing is dissolved.
Never spray wd 40 type of lube in the hose as this softens the rubber.
Hope this is of use
Kev
Back home .................
brianrobertwood(at)gmail.
PostPosted: Tue Nov 04, 2008 4:02 am    Post subject: Strange goop in the overflow bottle Reply with quote
What are the water pump impellers made of?
Brian
Em Tue, 04 Nov 2008 09:46:48 -0200, K Dilks <kevin.dilks(at)liwest.at>
escreveu:
Hope this is of use
Kev
Austria ...guess where I work!
http://forums.matronics.com/viewtopic.php?p 12212#212212
Usando o revolucionário cliente de e-mail do Opera:
http://www.opera.com/mail/
K Dilks
PostPosted: Tue Nov 04, 2008 4:18 am    Post subject: Re: Strange goop in the overflow bottle Reply with quote
Impeller is Aluminium or Aluminum.......
Oil seals are a ceramic rotary type.
Or light shiny metal if your a hobbit .
Kev
PostPosted: Tue Nov 04, 2008 4:24 am    Post subject: Strange goop in the overflow bottle Reply with quote
How often should the coolant be changed?
Brian
Em Tue, 04 Nov 2008 10:18:51 -0200, K Dilks <kevin.dilks(at)liwest.at>
escreveu:
Kev
http://forums.matronics.com/viewtopic.php?p 12216#212216
K Dilks
PostPosted: Tue Nov 04, 2008 4:48 am    Post subject: Re: Strange goop in the overflow bottle Reply with quote
Normally recommend 2 years. try and use 40 to 50% mix with de ionised water. too much glycole reduces the flow around the system and also not so good at removing the heat.
Evans coolant is the worst if you run hot as this increases the temp by up to 20c.
Run normal coolant but DO use the 1.5 bar pressure cap to stop boile off.
Kev
PostPosted: Tue Nov 04, 2008 4:55 am    Post subject: Strange goop in the overflow bottle Reply with quote
Thanks for the informed replies. Can you help out a little more and
explain de-ionized water? If it is not available commercially, can it be
"made"?
Brian in Brazil
Em Tue, 04 Nov 2008 10:48:22 -0200, K Dilks <kevin.dilks(at)liwest.at>
escreveu:
up to 20c.
off.
Kev
http://forums.matronics.com/viewtopic.php?p 12222#212222
K Dilks
PostPosted: Tue Nov 04, 2008 5:04 am    Post subject: Re: Strange goop in the overflow bottle Reply with quote
Water they sell for batterys is the stuff,or for irons.
Coolant for Toyota, BMW, and Merc all good as the only have aluminium compatable stuff. look out for some GM stuff as not good, for iron block motors only.
or if into making hooch just distille some in your rig.....
Kev
PostPosted: Tue Nov 04, 2008 6:02 am    Post subject: Strange goop in the overflow bottle Reply with quote
Hi Brian,
Cast iron centrifugal type.
Brian R. Wood wrote:
<brianrobertwood(at)gmail.com>
Brian
escreveu:
> Hope this is of use
> Kev
ca
z601(at)anemicaardvark.co
PostPosted: Tue Nov 04, 2008 6:34 am    Post subject: Strange goop in the overflow bottle Reply with quote
In the U.S., the stuff you're describing is sold as "distilled water." Even my
grocery store carries it.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
K Dilks
PostPosted: Tue Nov 04, 2008 6:49 am    Post subject: Re: Strange goop in the overflow bottle Reply with quote
........and further down the page it said,
Kev
LOL
Jim B. Belcher
A&P/IA
bryanmmartin
PostPosted: Tue Nov 04, 2008 8:46 am    Post subject: Strange goop in the overflow bottle Reply with quote
Distilled water works just as well and should be commonly available.
Deionized water is just water that has been passed though a device
that removes the dissolved ionic compounds using electrically charged
plates and permeable membranes. The process is nearly as effective at
purifying water as distillation but requires less energy and can
quickly produce large quantities of purified water.
it be "made"?
Brian in Brazil
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
PostPosted: Tue Nov 04, 2008 8:55 am    Post subject: Strange goop in the overflow bottle Reply with quote
Thanks, that clears things up for me. All the gasoline stations here have
distilled water, but I don't recall seeing "de-ionized" water.
Brian in Brazil
Em Tue, 04 Nov 2008 14:45:08 -0200, Bryan Martin
<bryanmmartin(at)comcast.net> escreveu:
Deionized water is just water that has been passed though a device that
removes the dissolved ionic compounds using electrically charged plates
and permeable membranes. The process is nearly as effective at purifying
water as distillation but requires less energy and can quickly produce
> be "made"?
> Brian in Brazil
ggower_99(at)yahoo.com
PostPosted: Tue Nov 04, 2008 12:58 pm    Post subject: Strange goop in the overflow bottle Reply with quote
Agua bi-destilada in spanish.
Saludos
Gary Gower.
do not archive.
--- On Tue, 11/4/08, K Dilks <kevin.dilks(at)liwest.at> wrote:
Subject: Re: Strange goop in the overflow bottle
Date: Tuesday, November 4, 2008, 8:04 AM
--> Zenith601-List message posted by: "K Dilks"
only.
Kev
http://forums.matronics.com/viewtopic.php?p 12224#212224
