Speaking of fuel systems...
naumuk(at)alltel.net
PostPosted: Sat Nov 01, 2008 12:03 pm    Post subject: Speaking of fuel systems... Reply with quote
All-
WW (And others) question whether my header tank was built correctly at the factory. Pictures are attached. The feed line comes from a console mounted Facet. The extra ports are (Supposedly) for a sight gage quantity indicator. He thinks the input should be at the top of the tank, and he's not the only one that has expressed that opinion in the past.
I have an e-mail in to Zenith, but I'd appreciate any input. Mark, if you're monitoring the list, what do you think?
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
 Filesize:  39.6 KB
 Viewed:  760 Time(s)
 Filesize:  50.64 KB
 Viewed:  713 Time(s)
bryanmmartin
PostPosted: Sat Nov 01, 2008 12:25 pm    Post subject: Speaking of fuel systems... Reply with quote
With the feed at the bottom, fuel will leak back into the wing tank possibly causing it to overflow unless a check valve is installed in that line. That is the only issue you might have with that configuration, the pump will feed fuel into the tank just as well either way. Some Facet pumps have a built-in check valve, some are designed to allow a very small amount of back flow (as I recall about 1/2 gallon per hour) in order to allow fuel lines to depressurize after shut-down. If you want to use the Facet pump as your check valve, make sure you get the correct model number.
On Nov 1, 2008, at 3:58 PM, Bill Naumuk wrote:
All-
Bill Naumuk
Townville, Pa.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
jonaburns
PostPosted: Sat Nov 01, 2008 1:15 pm    Post subject: Re: Speaking of fuel systems... Reply with quote
Is there a possibility that that feed goes up to the top of the tank on the inside of the tank?
Plug the output, or hold the hose up and put some liquid in the tank to see if it siphons out the input tube when half full.
I would not trust a check valve if the tank can siphon.
Jon Burns
PostPosted: Sat Nov 01, 2008 3:36 pm    Post subject: Speaking of fuel systems... Reply with quote
Jon-
That's a possibility that's never been brought up before. If one of the
bottom feeds does go to the top of the tank, I have to make sure which of
the bottom 2 it is. I would imagine I could take the cap off and stick an
inspection mirror in thereto find out. You can be sure I'll check.
Bill
grs-pms(at)comcast.net
PostPosted: Sat Nov 01, 2008 3:54 pm    Post subject: Speaking of fuel systems... Reply with quote
My 8 gallon header tank had two inlets on the bottom. I had a welder
relocate one of them to the top and plug the resulting hole at the bottom.
Neither bottom inlet had a tube inside the tank.
George Swinford
PostPosted: Sat Nov 01, 2008 4:26 pm    Post subject: Speaking of fuel systems... Reply with quote
George and all-
The question is, why the hell did Zenith configure the header tank this
way?? You'd think there must be a reason.
Bill
bryanmmartin
PostPosted: Sat Nov 01, 2008 5:01 pm    Post subject: Speaking of fuel systems... Reply with quote
The early Zodiacs had no wing tanks, the header tank was all there
was. In that case, there would be no need to have a fuel line entering
the top. But that doesn't explain the extra port at the bottom.
On Nov 1, 2008, at 8:25 PM, Bill Naumuk wrote:
George and all-
this way?? You'd think there must be a reason.
Bill
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive.
PostPosted: Sat Nov 01, 2008 7:02 pm    Post subject: Speaking of fuel systems... Reply with quote
The early zodiacs had the option of tanks in the wing lockers, so the second
inlet on the bottom was needed. Perhaps they just standardized on that
feature.
George
jlatimer1(at)cox.net
PostPosted: Sat Nov 01, 2008 7:31 pm    Post subject: Speaking of fuel systems... Reply with quote
Bill,
My HDS 8 gallon header tank came with 2 fittings at the top of the tank, a fitting at the bottom, and an output at the bottom that goes to fuel shutoff and engine.
My instructions say to plumb one of the top fittings to my optional wing tanks. The other 2 are for a clear sight glass to be used as a fuel gauge.
I've seen some instructions in the early models that had the top fitting being shared as a feed line and the top of the fuel sight gauge. I can remember 8 or 9 years ago when folks that were flying HDS's and HD's saying they used that feature to know that their pump was working.
By using the bottom as a feed I would worry about leaving the plane with the header and the wing tanks full. Over time the fuel would siphon out of the header through the built in leak in the facet pump to the wing tanks.
Jerry
HDS 912S finally getting close to finishing.
---- Bill Naumuk <naumuk(at)alltel.net> wrote:
All-
Bill Naumuk
Townville, Pa.
PostPosted: Sun Nov 02, 2008 9:03 am    Post subject: Speaking of fuel systems... Reply with quote
Jerry-
Another lister thought that the two bottom inputs were to accomodate
locker tanks. I don't think that's valid, because both would still be
feeding from the bottom.
I thought I had things figured out a couple of months ago after an
earlier posting, but William Wynne stopped me cold in my tracks on two
issues, the header routing and a firewall mounted Facet boost pump from the
header
That's why I wonder whether my tank is built correctly for my
configuration. Locker tanks with individual manual valves gravity fed to a
console mounted Facet which pushes fuel into the header. This is Jeff
Small's setup, which has around 500 hours on it. I can't see anything wrong
to this point, and the manual valves will prevent backwash to the wing
tanks.
As far as the firewall Facet boost pump, WW says he's "Never seen
anything but a gravity feed system from a header". Both Larry Mac and Jeff
have booster Facets, so this is a non-issue.
I guess I'll just have to wait to hear from Zenith.
Bill
PostPosted: Sun Nov 02, 2008 9:26 am    Post subject: Speaking of fuel systems... Reply with quote
Bill (and others interested):
I meant to suggest that the second inlet was to accommodate wing locker
tanks, if those were installed. I think putting the second inlet on the
bottom of the tank was a mistake in design, which was later rectified. As I
said, I had a welder move the second inlet on my tank to the top.
As for the firewall-mounted Facet boost pump, it goes with installation of
the Stratus Subaru which has dual Bing carbs on top of the engine, too high
for gravity feed. I hope this clears things up a little.
George
s.clive.richards(at)homec
PostPosted: Sun Nov 02, 2008 9:32 am    Post subject: Speaking of fuel systems... Reply with quote
Bill
  We have only the bottom outlet to gascolator + near top & bottom outlets which were originally designed for a sight gauge, we blanked the bottom, feed in via top & use an electrical gauge. I note you have the Zenith supplied taper tap ours was very tight to operate, leaked & eventually seized, we used a ball type fuel valve from a motor racing supplier very easy to turn. Another builder at our airfield with a HDS feeds his in via the bottom if you do this beware most facet pumps have a uncalibrated leak to prevent overpressurisation to carb from retained heat or from sun expanding the fuel and will drain into wing tanks over time if not isolated also a leak in this pipe could leak into cockpit
Clive do not archive
Rays G CBDG 260Hrs
Message -----
[quote] From: Bill Naumuk (naumuk(at)alltel.net)
To: zenith list (zenith-list(at)matronics.com)
Sent: Saturday, November 01, 2008 7:58 PM
Subject: Speaking of fuel systems...
All-
Bill Naumuk
Townville, Pa.
PostPosted: Sun Nov 02, 2008 9:46 am    Post subject: Speaking of fuel systems... Reply with quote
Clive-
That's not the Zenith supplied shutoff- I got it from a supplier in Philadelphia. It's meant to switch auxilliary tanks on a truck.
I'm trying to avoid going with an electrical fuel gage- the project is on the heavy side as it is.
Bill
ashontz
PostPosted: Tue Nov 04, 2008 4:18 am    Post subject: Re: Speaking of fuel systems... Reply with quote
Just curious, are these tanks gas welded? I'm in the process of making my tanks and just wondering how they're made at Zenith. Those welds appear to be gas welds, which is what I'm doing, with lots of practice of course. Smile
Brady
PostPosted: Wed Nov 05, 2008 1:52 am    Post subject: Re: Speaking of fuel systems... Reply with quote
Andy,
All the fuel tanks supplied by Zenith are TIG welded.
As are all the weld-ments; steel or aluminum.
Brady McCormick
Poulsbo, WA
www.magnificentmachine.com
