Headset and Mic Connections
Jeff Smith
PostPosted: Sat Mar 18, 2006 10:22 am    Post subject: Headset and Mic Connections Reply with quote
I ordered some headset and mic jacks from B&C Specialty. Are the
connections to these supposed to be soldered? If so, is there a standard practice used
to attach the wire to the solder tabs on the jacks? The solder tabs have a
small diameter hole in them.
nuckollsr(at)cox.net
PostPosted: Sun Mar 19, 2006 9:27 am    Post subject: Headset and Mic Connections Reply with quote
practice used
See:
http://aeroelectric.com/articles/Jack_Tab_Soldering/Jack_Tab_Soldering.html
< with experiment. >
< --Lawrence M. Krauss >
