European ULM ( Ulralight ) 601xl
bryanmmartin
PostPosted: Wed Oct 29, 2008 6:33 am    Post subject: European ULM ( Ulralight ) 601xl Reply with quote
The Euro planes have a 125 KG lower gross weight than the US planes,
so the same 4 G loading will result in a 500 KG less load being
carried by the wings for the Euro plane.
On Oct 29, 2008, at 2:36 AM, K Dilks wrote:
So to summerise I think maybe there are two planes here and two
differing potential aeres of concern.
If the Euro plane has such thin skins to get the empty weight down
I cant see why they say it can be +4 -2 g limit, the same as the
more beefy US planes. This area has to be explain by Zenair.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
LHusky
PostPosted: Wed Oct 29, 2008 8:26 am    Post subject: European ULM ( Ulralight ) 601xl Reply with quote
I went out to my parts pile and remembered I had cut out some of the skin on the wing and the forward fuselage from the CZAW plane I parted out. It all measures .025. The front fuse is the air duct that I cut out for a pattern and the wing skin is from the hole where the fuel filler is. So, I can confirm that the CZAW plane that I had my hands on, had thicker skin than .016.
Larry Husky
Madras, Oregon
In a message dated 10/28/2008 11:37:26 P.M. Pacific Daylight Time, kevin.dilks(at)liwest.at writes:
--> Zenith601-List message posted by: "K Dilks" <kevin.dilks(at)liwest.at>
Until earlier this year worked in France. At that time I did not know I was going to build a 601.
A few things to point out.
1. ULM planes in Europe have a max EMPTY weight of 275KG and max TO of 475kg. The licence to fly these is less demanding .
2. What I have learnt before buying my kit ...arrives soon I hope is that the Euro plane has .16" wing skins not .25" like the US planes, lighter landing gear, the CH650 wing incedence, no anti oil canning stuff in the fuzz or wings.
Now it would be nice for Nic Heniz to tell everyone about this and to confirm the CZAW planes were built this way as I have no concrete evidence..
3. While in France I notice the zodiac skins to be very loose and suffering badly from oil canning, I also remember the rivet spacing on those thin skins was very wide , it just did not look right.
So to summerise I think maybe there are two planes here and two differing potential aeres of concern.
If the Euro plane has such thin skins to get the empty weight down I cant see why they say it can be +4 -2 g limit, the same as the more beefy US planes. This area has to be explain by Zenair.
Second is that of flying aerobatics and flying well over gross in the US spec planes planes is a major cause for over stressing that design.
I think that the Euro planes should be called different to distance that plane from the US version as suggest elswere on this list.
I ordered the US kit because of these factors.
Kit in Mid Atlantic.........
Kevin
Austria ...guess where I work!
http://forums.matronics.com/viewtopic.php?p=210918#210918
Plan your next getaway with AOL Travel. [url= http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001 ]Check out Today's Hot 5 Travel Deals![/url]
