cabin exhaust/ extension to exhaust pipe?
cookflys(at)yahoo.com
PostPosted: Tue Oct 28, 2008 9:00 am    Post subject: cabin exhaust/ extension to exhaust pipe? Reply with quote
I read in the archives some 582 drivers added a small extension to the exhaust pipe. Any comments?
How did you seal around bungees?
Charles Cook
N363KF Mod ll 582
matronics(at)bob.brennan.
PostPosted: Tue Oct 28, 2008 10:10 am    Post subject: cabin exhaust/ extension to exhaust pipe? Reply with quote
My 582 model 2 appears to have an exhaust extension, there is an obvious weld near the cowling. The pipe looks like and auto exhaust with a J bend at the bottom, and it extends a good 10" down, back, and away from the cowling; you can just see it in the attached picture.
I have never had any exhaust smell in the cabin and have a CO2 monitor that I change as prescribed, never a hint of discoloration. In fact the only problem I have is discoloration of the lower gear strut fairings from the exhaust, but that wipes off easily enough. The bungee hole is big enough to slip a hand through and in fact I recently added window vents to add more ventilation, the scoop kind that can be closed.
The configuration works very well, more details or better pix if anyone wants.
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of charles cook
Sent: 28 October 2008 12:59 pm
Subject: cabin exhaust/ extension to exhaust pipe?
Charles Cook
N363KF Mod ll 582
href='3D"http://www.matronics.com/Navigator?Kitfox-List"'>http://www.matronics.com/Navigator?Kitfox-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
 Filesize:  68.11 KB
 Viewed:  492 Time(s)
PostPosted: Tue Oct 28, 2008 10:44 am    Post subject: cabin exhaust/ extension to exhaust pipe? Reply with quote
Wrightsville Pa
Charles Cook
N363KF Mod ll 582
 Filesize:  68.11 KB
 Viewed:  486 Time(s)
