lowandslow1(at)hotmail.co Guest
Posted: Sun Oct 26, 2008 12:59 pm Post subject: Corrosion Protection for Kitfox |
If you were going to do some corrosion protection I would do just the bottom longerons. Primarily because they see the most abuse from sticks C stones C and whatever else may hit the lower tube C plus the stress of the tail wheel attach points and bottom of the rudder post. I would not worry about the other tubes unless a hole was drilled into it. Some of the older Kitfox's had a hole drilled in the square tube forward door frame for a pin to hold the door closed. This is where moisture can get in and start the corrosion process.
Andy
Stay organized with simple drag and drop from Windows Live Hotmail. Try it [quote][b]
