hcourier(at)cox.net Guest
Posted: Sun Oct 26, 2008 5:17 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM Conversion). Takeoff is fine but on climb out the left engine RPM is unsteady, somewhat like a prop that won't stabilize. Here's some info:
1. The problem seems to occur primarily during climb as I bring the
turbos up (I've got manual turbos)
2. The fluctuation is random as to when it occurs and how much the RPM
fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the
aircraft yaws, sometimes it's not noticeable.
3. Sometimes it seems that leaning the mixture helps a bit but not
always
4. I've also noticed that sometimes when the problem has occured on a
flight that on shutdown of the engine after landing, it doesn't want to
stop running with the mixture pulled all the way to lean/idle-cutoff.
5. Sometimes I the lean the mixture during the 1500 RPM ground check
and the RPM goes up 50 RPM or so, sometimes it doesn't
6. Once I level off the problem seems to disappear or be almost
un-noticeable. Although tonight I applied full rich mixture while in level
flight at 4,500' and I could notice a slight RPM fluctuation if I paid close
attention.
7. Fuel pressure is normal and turning the fuel pump on or off has no
affect on the engine
My thoughts:
1. I think the problem is in some fuel metering mechanism in the
carburetor that is unsteady
2. At one point I thought there might be a leak in the turbo pressure
lines causing a fluctuation in turbo air to the engine
3. Now, with the engine shut down problem (doesn't happen every time)
I think there is a link between the turbo air (as I bring it up on climb)
and fuel metering. They are probably interrelated.
I've received help from many of you out there before. Has anyone had this type problem occur and if so what might be the problem?
Thank you,
Ray Mansfield
N91ES
850-217-5185
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
cschuerm(at)cox.net Guest
Posted: Sun Oct 26, 2008 6:03 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
Ray Mansfeld wrote:
| Quote: | I've received help from many of you out there before. Has anyone had this type problem occur and if so what might be the problem?
Do you have a multi-channel EGT/CHT system? If so, what are the EGT's
doing when this occurs.
There are several possible problems which could cause this, but it does
sound like you're looking in the right area. Have you carefully
inspected the upper deck reference lines? That would be my first guess
before digging into the injection body. I think those were all hand
fabricated by mrrpm since a normal io-720 wouldn't have them. Look for
a cracked line at the solder joint on the injector.
chris
tfisher(at)commandergroup Guest
Posted: Mon Oct 27, 2008 6:35 am Post subject: AC-680 FLP Engine RPM Fluctuation |
I had the same surging problem on mine.
I replaced all the upper deck lines with new stainless steel lines, the new
lines also had to be welded in two places, this resolved the surging
problem.
Tom
C-GISS
680FLP (Mr.RPM)
drwer2
Joined: 24 Sep 2008 Posts: 41 Location: Squaw Valley, CA
Posted: Mon Oct 27, 2008 7:00 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Tom, did
--- On Mon, 10/27/08, Tom Fisher <tfisher(at)commandergroup.bc.ca> wrote:
[quote]From: Tom Fisher <tfisher(at)commandergroup.bc.ca>
Subject: Re: AC-680 FLP Engine RPM Fluctuation
Date: Monday, October 27, 2008, 7:34 AM
[quote]--> Commander-List message posted by: "Tom Fisher" <tfisher(at)commandergroup.bc.ca> I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ---
_________________ No Generality is worth a damn....including this one.
cogito ergo aero-geek |
drwer2
Tom,
drwer2
Posted: Mon Oct 27, 2008 7:05 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo?
wer
problem.
Tom
C-GISS
680FLP (Mr.RPM)
Posted: Mon Oct 27, 2008 9:59 am Post subject: AC-680 FLP Engine RPM Fluctuation |
I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders.
Tom.
C-GISS
drwer2
Posted: Mon Oct 27, 2008 10:56 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Thanks Tom.
Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume.
Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream.
As Ive seen it.
1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero...
2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck).
3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles.
Just some thoughts.
wer
former Pratt-Whitney and Ham-STD
Date: Monday, October 27, 2008, 10:57 AM
Tom.
C-GISS
Posted: Mon Oct 27, 2008 1:19 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
Well, I am that much more informed, thanks for the info.
Tom
C-GISS
drwer2
Posted: Tue Oct 28, 2008 7:14 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Well, Next time you fly, once youve leaned for cruise, check the EGTs for those cylilnders that had the new lines welded. If they are running within a few degrees of the others, then he did a good job welding. SS lines with anything less than 130 thou. diam are extremely hard to weld without causing an "orifice" at the weldsite.
Also, I doubt that he annealed the new weld, which will make the heat affected zone more brittle than the rest. Ask him how he treated the weld. (a smoky acetylene torch for 2 minutes would be sufficient.
Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC.
wer
Date: Monday, October 27, 2008, 2:17 PM
Tom
C-GISS
Posted: Tue Oct 28, 2008 7:48 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
I do not yet have engine monitors but they are on the wish list.
Well he was out of the business and already sold the STC and as far as I was concerned I was happy to receive the lines from him even if they had to be tweaked by an expensive AME who did in fact anneal the welds, good point.
Tom.
C-GISS
don.barry(at)sbcglobal.ne Guest
Posted: Tue Oct 28, 2008 8:05 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
MR. RPM is out of business?? I wonder whatever happened to that AC they were playing around with the water-cooled Orenda engines…
Don
Houston TX
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher
Sent: Tuesday, October 28, 2008 10:46 PM
Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation
Tom.
C-GISS
nico(at)cybersuperstore.c Guest
Posted: Tue Oct 28, 2008 9:26 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
I am not sure that I remember the Orenda story correctly, Don, but folks on this list know a lot more about it than I do. Apparently it ran out of money and / or there wasn't enough push in Canada at the time to complete the job to certification. Perhaps someone could enlighten us, but it is a topic that has been discussed until there was a grove in the ground.
Nico
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Barry Home
Sent: Tuesday, October 28, 2008 9:00 PM
Subject: RE: AC-680 FLP Engine RPM Fluctuation
Don
Houston TX
Tom.
C-GISS
craigk391(at)sbcglobal.ne Guest
Posted: Tue Oct 28, 2008 11:07 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
The STC's were picked up by a guy in FL. The link still workscraig
Sent via BlackBerry by AT&T
From: "Don Barry Home" <don.barry(at)sbcglobal.net>
Date: Tue, 28 Oct 2008 23:00:26 -0500
To: <commander-list(at)matronics.com>
Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation
MR. RPM is out of business?? I = wonder whatever happened to that AC they were playing around with the = water-cooled Orenda engines…
Don
Houston TX
Sent: Tuesday, October = 28, 2008 10:46 PM
Subject: Re: = Commander-List: AC-680 FLP Engine RPM Fluctuation
I do not yet have engine monitors but they are on the = wish list.
Well he was out of the business and already sold the = STC and as far as I was concerned I was happy to receive the lines from him even = if they had to be tweaked by an expensive AME who did in fact anneal the = welds, good point.
Tom.
C-GISS
[quote]=
Peter Bichier
Joined: 25 Aug 2008 Posts: 103 Location: Toledo, Ohio
Posted: Wed Oct 29, 2008 1:32 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Dick MacCoon's old site is still available (actually the domain is for sale)
http://www.mrrpm.com/
it still has a video on the "promissing" (2002) new aluminum V8 water cooled engines which were supposed to be cheaper and fuel efficient...
RPM Commander LLC is still in business and selling a couple of 560Fs
http://www.rpmcommander.com/
To reach: RPM COMMANDER LLC (For STC services)
c/o Paul Gendron
1401 N. Riverside Drive Suite 607
Pompano Beach, FLorida, USA 33062
_________________ 560 Dreamer |
rsrandazzo(at)precisionma Guest
Posted: Wed Oct 29, 2008 5:20 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Don-
The engine technology was picked up by an outfit called Trace Engines. (www.traceengines.com)
They had a stand set up at the races this year at Reno. We stopped by to chat with them- and they brought around a fellow who has purchased the original Orenda certification test airplane. He has a second outfit that he explained was working to STC the 685 with these engines mounted. He claimed that they were “months away from an STC” to hang the V8s on 685s….
That Mr. RPM test bed commander is currently on the ground in Midland TX and according to some sources I checked with- it hasn’t been flying in some time..
Like all things in GA- seems to be more heat than energy being generated on that project.
Robert S. Randazzo
N414C
Don
Houston TX
Tom.
C-GISS
----- Original Message -----
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Sent: Tuesday, October 28, 2008 8:11 AM
wer
Tom
C-GISS
Sent: Monday, October 27, 2008 11:54 AM
Thanks Tom.
As Ive seen it.
Just some thoughts.
wer
Tom.
C-GISS
Sent: Monday, October 27, 2008 7:59 AM
wer
--- On Mon, 10/27/08, Tom Fisher <tfisher(at)commandergroup.bc.ca (tfisher(at)commandergroup.bc.ca)> wrote:
From: Tom Fisher <tfisher(at)commandergroup.bc.ca (tfisher(at)commandergroup.bc.ca)>
Date: Monday, October 27, 2008, 7:34 AM [quote]--> Commander-List message posted by: "Tom Fisher"<tfisher(at)commandergroup.bc.ca> I had the same surging problem on mine.I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem.TomC-GISS680FLP (Mr.RPM)---
Posted: Wed Oct 29, 2008 6:48 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Well I do hope that they get some traction with this. Adams shutting down, Eclipse not going anywhere fast, are all bad news for GA. A success story would be a nice change. I, for one, would be very hesitant to load up a 685 with family and launch them with Orendas into the night over the Rockies but their STC with the ag planes do show that it can be a reliable powerplant. Having a couple of successful races under their belt can do wonders.
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Robert S. Randazzo
Sent: Wednesday, October 29, 2008 6:18 AM
Don-
Robert S. Randazzo
N414C
Don
Houston TX
Tom.
C-GISS
wer
Tom
C-GISS
Thanks Tom.
As Ive seen it.
Just some thoughts.
wer
Tom.
C-GISS
wer
Date: Monday, October 27, 2008, 7:34 AM[quote]--> Commander-List message posted by: "Tom Fisher"<tfisher(at)commandergroup.bc.ca> I had the same surging problem on mine.I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem.TomC-GISS680FLP (Mr.RPM)---
BobsV35B(at)aol.com Guest
Posted: Wed Oct 29, 2008 10:40 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Good Afternoon Robert,
I have a friend who was involved as a mechanic with that project. He said it was a beautiful running engine and that everything worked just as they had expected it would.
Unfortunately, the interest in converting from a Turbine to a piston was just not there.
I asked many of my King Air driver friends what they thought. Everyone of them said there was no way they would ever go back to flying a piston. I got the impression that it was an ego thing. They had no interest at all in the economy or performance gains that might be achieved. They just wanted to arrive in a turbine powered flying machine!
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 10/29/2008 8:22:04 A.M. Central Daylight Time, rsrandazzo(at)precisionmanuals.com writes:
That Mr. RPM test bed commander is currently on the ground in Midland TX and according to some sources I checked with- it hasn't been flying in some time..
Robert S. Randazzo |
Plan your next getaway with AOL Travel. [url= http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001 ]Check out Today's Hot 5 Travel Deals![/url]
Posted: Wed Oct 29, 2008 11:36 am Post subject: AC-680 FLP Engine RPM Fluctuation |
Well, Old Bob, there is the safety of having much less moving parts in a turbine, too. And the moving parts in a turbine just spin, they don't accellerate, stop, turn around, accellerate, stop, turn around, accellerate thousands of times a minute either. Seems to me they have my vote on that. However, going from an ageing Lycoming or Continental to an Orenda would be a favorite for me. Provided they can last and win some races and endurance rallies to increase their knowledge and capabilities of the engines.
Nico
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Wednesday, October 29, 2008 11:38 AM
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Plan your next getaway with AOL Travel. [url= http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001]Check out Today's Hot 5 Travel Deals![/url]
href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
drwer2
Posted: Wed Oct 29, 2008 12:15 pm Post subject: AC-680 FLP Engine RPM Fluctuation |
While there may be a certain amount of ego associated with transitioning to Turbines, Owners will always go with what is most efficient and affordable. The exception to this was the market shift from turbo-props to light jets. None of the operators wanted to trade the efficiency of thier turbo props for the high initial and recurring costs of operating twin jets. But, given the choice, people (not just pilots) loved flying in Jets! Who cares if the cost of travel went up 20%. You no doubt have noticed that all the regionals (in the black) are running Props again.
If you have an engine that has a TBO of 3500 to 5400 hrs, it could be made by Briggs and Stratton and would still find a home. The pilot is the last opinion heard.
Personally, I prefer a nice Big-Displacement, Geared, slow turning Piston. (560Fis my favorite) why? Efficiency. There isn't a law that says you have to fly full throttle. Use your propeller performance curve and POH to tell you your best cruise altitude and airspeed, and trim for that. Use MRCP to get in and out effectively and then rein-in your ego. There's nothing sexy about straight and level flight.
Hoover was cool....but he didnt pay for the plane or the gas.
wer
--- On Wed, 10/29/08, nico css <nico(at)cybersuperstore.com> wrote:
| Quote: | From: nico css <nico(at)cybersuperstore.com>
Date: Wednesday, October 29, 2008, 12:33 PM
Nico
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Robert S. Randazzo
Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals!
