Corrosion Protection for Kitfox... Any ideas ????
Float Flyr
PostPosted: Sat Oct 25, 2008 2:50 pm    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
The two part epoxy primer should be ok for the inside of the spars. Actually if your plane is kept in a hanger out of rain I doubt you would need anything in the spars. Aluminium will form its own oxide coating which protects it as long as it doesn't get wet. For the weight that is involved prime it if it makes you feel happier. The nice thing about the two part primer is it won’t dissolve with the other finishing chemicals.
As for the fuselage that's a different quintal of fish. I recommend drilling one small hole 1/16 " close to the top of the frame on the inside. Use a small syringe to inject about a cup or two of double boiled linseed oil into the frame. Put a small screw into the hole and then rotate the frame in every possible direction for about a week. (change the rotation daily) Then drain the linseed oil out the same hole into a can. (Turn the frame upside down). Replace the screw with a little epoxy around it to seal the hole. There are a few things to know about linseed oil. One is it will never dry until it comes in contact with air. The driest it will get inside your frame is the consistency of a gel so you don't need to re inhibit your frame at a later date.
Linseed oil likes to migrate... it will on its own wick into every nook and cranny of the frame from the inside and inhibit any corrosion that can form in there. The biggest thing to remember about using linseed oil is it will spontaneously combust if you allow it to drip on a floor and then wipe it up with a rag. It usually takes about fifteen minutes to break into fire (from a wet/damp rag) and I can guarantee you it will produce a lot of white smoke. If you have to wipe up any drips put the rag outside in a fire proof rag bin. Funny thing is in a dish or can it will not spontaneously combust. It needs the larger surface area a cloth gives.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
 Filesize:  7.29 KB
 Viewed:  7352 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
JetPilot
PostPosted: Sat Oct 25, 2008 5:10 pm    Post subject: Re: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
Thanks for the suggestion Noel, that brings a question to mind... Is there a place in all the joints in the fuselage for oil to flow through ? I thought that many of them might be closed off with metal. Would I not have to drill a hole in almost every other tube vertical tube in the fuselage to get this stuff in there ? I have this stuff from Aircraft Spruce called Tube Seal that is made for corrosion protection of aircraft tubing. More expensive than linseed oil, but I'm hoping it will work better.
There will most definitely be times when my plane is out in the weather... I hope just during cross countries, and rainstorms, but it may turn into longer than that. Hangers here in Miami cost 650 a month at the small GA airport, that is after you do the three year wait for one Evil or Very Mad
Thanks for the warning on Spontaneous Combustion, that would have really sucked to burn down my house Sad But then again, this new knowledge could also lead to hours of entertainment Wink
Mike
Kolb MK-III Xtra, 912-S
lcfitt(at)sbcglobal.net
PostPosted: Sat Oct 25, 2008 6:21 pm    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
Having welded on a fuselage frame, I strongly believe that if you drill one
small hole in one portion of the frame for introducing the oil, that tube
and that tube only will be protected. Every tube has it's own welded end,
that is every tube is separated by the joint weld - almost all are butt
welded. The longerons might be continuous on their length but the cross
braces are entirely separate. How do I know? I moved the shoulder harness
attachment points to a position I liked a bit better and if I didn't drill a
hole at the weld point, the heated air within the tube would blow a hole in
the tube near the weld. For my money, especially if the frame is well
coated - epoxy primer, or powder coat - I would leave that part alone.
That said, though, there have been reports in the past of the powder coat
lifting, blistering or light dustings of corrosion on the surface as if
pinpoint defects were in the powder coat. This was years past and I suspect
the factory has addressed this issue with better surface prep before the
powder coating, but, to put it succintly, I wish my new old kit was not
powder coated.
Lowell
Lynn Matteson
PostPosted: Sat Oct 25, 2008 7:48 pm    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
I wonder if any thought has been given to drilling a small hole into
the main tube right where the "to-be-added" tube will intersect it?
This would insure that the flow of the rust/corrosion inhibiter would
be able to flow freely throughout the entire airframe. Maybe this is
standard practice, I don't know...if not, why not?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 579.1hrs
Sensenich 62x46
flying again (17 hrs) after rebuild, and new Electroair direct-fire
ignition system
On Oct 25, 2008, at 10:17 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
drill one small hole in one portion of the frame for introducing
the oil, that tube and that tube only will be protected. Every
tube has it's own welded end, that is every tube is separated by
the joint weld - almost all are butt welded. The longerons might
be continuous on their length but the cross braces are entirely
separate. How do I know? I moved the shoulder harness attachment
hole in the tube near the weld. For my money, especially if the
frame is well coated - epoxy primer, or powder coat - I would leave
that part alone.
powder coat lifting, blistering or light dustings of corrosion on
the surface as if pinpoint defects were in the powder coat. This
was years past and I suspect the factory has addressed this issue
with better surface prep before the powder coating, but, to put it
succintly, I wish my new old kit was not powder coated.
Lowell
Lynn
Kitfox IV-Jabiru 2200
N369LM
Jim Shumaker
PostPosted: Sat Oct 25, 2008 8:51 pm    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
Lynn
I understand that Sean D Tucker (acro pilot) has all the tubes (in the Oracle Challenger) drilled at the intesection and then the inhibitors are introduced and then nitrogen under pressure is introduced. Then a pressure gauge in installed. Any loss of pressure is a cause for concern. So yes it is done.
Jim Shumaker
Jim Shumaker
Float Flyr
PostPosted: Sun Oct 26, 2008 5:55 am    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
I own a Grumman canoe it has been in the water, mostly fresh, but with several trips on the briny blue. I think it's a '47 or '48. The only mark on it wis where my father didn't pull it completely out of the water on one occasion. This canoe built of aircraft grade aluminium has been left in the woods for years at a time and basically abused but at close to 60 years it is still nto leaking a drop and I'll put it up against any of the plastic canoes or other aluminium canoes on the market at this time. In fact it appears to be better built than some of the newer Grummans. My point is it takes some doing to corrode aluminium. That being said I’ve also had to replace lots of aluminium in planes. Surprisingly most of it was at one time or the other protected with zinc chromate, Alumiprep or Alodine. The job I’m not loking lorward to is having to change out the washroom in any jetliner... that is a known high corrosion area.
If you are going to protect the interior of the spars a two part epoxy zinc chromate is not necessary because nothing has to stick to it. Sloshing with a regular zinc chromate will give ample protection to the interior of the spars. The exterior of the spars is another question. The wing covering has to be able to have a strong bond with the spars. This means a two part epoxy is required because it is not dissolved by the fabric adhesive. Zinc chromate will actually protect the aluminium at a molecular level. Apply it sparingly and be sure to wear rubber gloves when working with any zinc chromate.
I put out a fire once in the iron ore concentrator plant in Labrador City. A painter had dropped a rag damp with linseed oil in a garbage can. The garbage was dumped into a dumpster which was right beside the oil reservoir in the plant. I happened to notice the smoke as I walked past and before I could get the extinguisher out and ready to operate flames were coming out of the dumpster ten to fifteen feet high... inside the plant. I put out the fire and shortly afterward I had to explain why I had used the extinguisher. It was a large one on a dolly with fifty feet of hose. When the safety technicians looked in the dumpster and the blisters on the paint of the oil reservoir I was considered the hero of the moment.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sun Oct 26, 2008 6:10 am    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
All cluster joints should be open inside. The strength is in the tube not the interior. One hole in the frame should give access to the interior of the whole frame. The only exceptions will be any brackets which may be welded to the frame.
One thing about any resin or powder coat finish is that if there is ine little abrasion in the finish then it is possible to have a filliform corrosion to develop under the finish. This type of corrosion can usually be repaired by sanding the affected area to remove corrosion and re-finishing. There is a good section in AC43 on corrosion and anti corrosion methods. Download a copy and have a read.
Noel Loveys
 Filesize:  7.29 KB
 Viewed:  7348 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Sun Oct 26, 2008 6:20 am    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
Now that you mention it, I've heard that too. In that application,
the reason is to keep track of any cracks that might appear due to
stress, and he sure puts 'em under stress, but I was wondering if any
of the "common folk" airplanes...those that are tube frames, get the
"drill and weld" procedure to insure oil flow throughout. To be more
to the point of this Kitfox list, I wonder if Kitfoxes are done this
way. John?
Lynn Matteson
Kitfox IV Speedster
Sensenich 62x46
ignition system
On Oct 26, 2008, at 12:50 AM, James Shumaker wrote:
[quote] Lynn
Jim Shumaker
Lynn
N369LM
Lynn Matteson
PostPosted: Sun Oct 26, 2008 6:28 am    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
Download it hell, buy the book! It's a good "bible" to have on hand
when you want to know how to build your plane. : )
Lynn Matteson
Kitfox IV Speedster
Sensenich 62x46
ignition system
Lynn
N369LM
Float Flyr
PostPosted: Mon Oct 27, 2008 12:18 pm    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
I have a printed copy and one on my PDA and of course one here... they all
get well used. Some guys just won't buy one until they see what's in it.
It is the basis for all aircraft maintenance and it goes into some depth as
to why, not just do it this way.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Tue Oct 28, 2008 2:36 am    Post subject: Corrosion Protection for Kitfox... Any ideas ???? Reply with quote
When I first got started building, I bought one, and every now and
then I just look through it to learn something new.
I couldn't have successfully built my skis without it, for instance.
And for running wires, wires in bundles, wires near liquid
lines....it just goes on and on.
Lynn Matteson
Kitfox IV Speedster
Sensenich 62x46
ignition system
they all
in it.
depth as
Noel
Lynn
N369LM
