sam.marlow
Posted: Fri Mar 17, 2006 6:18 am Post subject: Panel thickness |
Has anyone added structural members to there instrument paned? Maybe it's just me, but after adding a proposed full complement of IFR instruments and radios, it seams a bit unstable. Looks like it needs more support in the center area.
Sam
Fuse
jesse(at)itecusa.org Guest
Posted: Fri Mar 17, 2006 8:31 am Post subject: Panel thickness |
I am cutting a hole in the subpanel and rimming it with angle like the plans suggest. Then I am going to support the back of the radio stack from there as well. I know some people like to put in stiffeners and then cut the panel to allow it to be removed in pieces instead of the whole panel at once. Angle or thick stock like the panel itself would probably do the trick there. I think finding a way to help support the heavy instruments behind the panel is probably the best way to relieve stress on the panel. With all that leverage, it would probably be lighter to do it this way as well.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Friday, March 17, 2006 9:16 AM
Subject: Panel thickness
Sam
Fuse
sam.marlow
Posted: Fri Mar 17, 2006 7:22 pm Post subject: Panel thickness |
That's what I was thinking, maybe a brace to the radio stack.
Jesse Saint wrote:
Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Jesse Saint
I-TEC, Inc.
www.itecusa.org
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Sam Marlow
Subject: RV10-List: Panel thickness
Sam
Fuse
