psm(at)att.net Guest
Posted: Sun Oct 19, 2008 2:54 pm Post subject: That %^#$%& canopy molding |
Hi Jay,
Try Loctite Stick n Seal. You can get it at Wal*Mart - a 1 oz. tube
is a couple of bucks. Look in the paint department.
Good Luck,
Paul
At 03:23 PM 10/19/2008, you wrote:
Quote: | The rubber molding that goes around the front of the canopy and over
the little piece of metal that covers the canopy arm refuses to stay
stuck down on my airplane. I've attached a picture. The airflow gets
under the leading edge at the left end, and lifts it up. I tried
sticking it down with contact cement, but it came loose on my last
flight. Suggestions?
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sun Oct 19, 2008 2:58 pm Post subject: That %^#$%& canopy molding |
Jay
Zenith recommends Loctite Stick'N Seal Waterproof adhesive P/N 23782
availabe at Wal-Mart and I have seen it at Home Depot. (Cheaper at Wal-Mart)
I used that and also E6000. I think the E6000 works better.
Floyd Wilkes
601XL O-200 Flying
_________________ Floyd Wilkes |
bryanmmartin
Posted: Sun Oct 19, 2008 3:14 pm Post subject: That %^#$%& canopy molding |
Your setup is a little bit different from mine, but I used 3M
weatherstrip adhesive and have had no problem. Funny thing is, most of
the pictures of planes I see on the Zenith website don't have the
rubber going down that far. And this picture ( http://www.zenithair.com/zodiac/608/60935.jpg
) of the CH 650 from Oshkosh appears to have the lower end of the
molding held down with screws. Since there no need for the molding to
separate from aluminum in that area, I would suggest that you glue
down the leading edge of the molding to the aluminum so that the
airflow can't lift it.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
