colleenandbrett(at)comcas Guest
Posted: Sun Oct 19, 2008 7:50 am Post subject: Installing the Vertical Fin on a RV-6AQInstalling the Vertic |
Patrick:
Congratulations on your first engine start!
To locate the vertical fin I placed its rear spar against the rear bulkhead of fuselage, then located the rear spar vertically according to the dimensions on the drawing and finally this spar was orientated 90 degrees to the horizontal stabilizer. The front of the of the vertical stabilizer was positioned to provide good alignment between the rudder and the vertical fin.
I'll trim the trailing edge of the fuselage to match the trailing edge of the vertical fin.
Thanks for your response.
Brett Herrick
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
