DwightFrye
Posted: Mon Oct 13, 2008 1:03 pm Post subject: Throttle/Mixture/Prop Firewall Location |
After long last I'm past the worst of my canopy work and am on to doing FWF
work. Finally. I need to order cables (got convinced by someone to go with
Cablecraft instead of the Van's standard cables) and need to build hoses to
fit my configuration. So I'm looking for some info, if I can find it.
I am installing a Superior XP-360 with vertical induction and an Airflow
Performance FI system. Given that this is a non-standard setup (from Van's
point of view) the plans don't speak to this specific configuration. I'm
doing a little head-scratching of my own, and think I know where I want my
throttle/mixture/prop cables to come through the firewall, but thought I
would ask others with a similar setup where they punched their holes.
And ... if you do have a setup like mine, did you -like- where your cables
exited the firewall? Did you hate it? What would you do different given
what you know now? Any information/insights will be welcome.
-- Dwight
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Mon Oct 13, 2008 5:55 pm Post subject: Throttle/Mixture/Prop Firewall Location |
Dwight,
I'm in the same point in my build. I have the same setup except with an ECI
engine. I found that the firewall layout location for penetrations is fine
for the throttle but the mixture location is way too high. I am planning to
use the called-out mixture location to run my Purge valve cable and drop
down about 5-6" and run my Mixture.
I sure hope that others who have gone before will input.
Have you found a supplier for the CableCraft cables?
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
rv9jim(at)juno.com Guest
Posted: Tue Oct 14, 2008 5:58 am Post subject: Throttle/Mixture/Prop Firewall Location |
Dwight,
I used the throttle position given by Van's as it was good. I
used the mixture cable I got from Van's but it was a bit short. I forgot
that you can get a longer one. I did use it and I ran it through the
fire wall inset on the lower left corner and curved it downward past the
fuel pump and down to a custom termination bracket mounted to the upper
mount on the AFP mount. The mount was pieced together with parts from
AFP and welded. Look at my web site and I think I have some pix on the
instillation.
www.websites.expercraft.com/jimn
Jim
Get the sign you need for the impact you want. Click now!
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3oB4gFumvTtfCfboZkLD3DuNRljtPkV9YSjtUYDjLE9u47k3/
