dongirod
Posted: Thu Oct 09, 2008 6:48 pm Post subject: HHO |
Commanderland;
Have any of you been reading or viewing on www.youtube.com anything on the HHO, which is the process of electrolysis to break down water into H & O and feeding it into the air intake. Some make claims of 30% up to several hundred per cent increase in gas mileage including using it on an 18 wheeler to double the mileage. I was talking to my Commander and my Credit Card and both thought it would be a good idea. Has anyone looked into this in the auto industry and other than the FAA, would it work in Commanders, probably take several units. Just thinking out loud.
Don
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
V-Man(at)v-man.net Guest
Posted: Thu Oct 09, 2008 7:21 pm Post subject: HHO |
Most of the stuff on YouTube is crap… The in Japan and Canada truckers use a commercial version that is about $3000 for and all stainless unit capable of running enough Brown’s gas for a decent fuel supplement. The complicating factor with engines since the first 70’s gas crunch is O2 sensors and computers. To appreciate the benefit of the gas you must add a couple hundred millivolts boost to the signal going to the computer to compensate for the cleaner burning.
Two other important issues. DO NOT hook to the intake as all that happens is you create a vacuum and you get steam with is already expanded water and hurts mileage. Hook to the aircleaner on the side before the aircleaner. This helps to diffuse the Hydroxy gas and does not create the vacuum.
I am anal about monitoring and have replaced the cassette area in my ’02 Suburban with a custom instrument panel. It has…
4 air/fuel ratio gauges. Two that show what is actually going on in the exhaust and two that show what the computer is seeing after the circuit board that I made… ( two because you must cheat both O2 sensors in front of the cat converters ) and I have the all important EGT gauge which is the most important to prevent over leaning… At 80% or more throttle it is not important as the computer goes to closed loop and dumps full rich fuel in anyway. Only on the highway is this important. Then I have a ammeter to monitor the DC motor controller as you have to adjust the current going to the hydrolyzer. (( as it heats up resistance reduces ( unlike an ordinary electric circuit where resistance increases)) You can have thermal runaway.
The most important is don’t be a dumbass like the morons selling the crap on eBay and use baking soda. It becomes part of the chemical process during hydrolysis and you end up with chlorine gas coming out the tailpipe. Use potash or (LYE for making soap) it stays in solution and you must only replace the water in the booster.
Hope this answers a few questions…
Victor
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don
Sent: Thursday, October 09, 2008 9:48 PM
To: Commander-list(at)matronics.com
Subject: HHO
Commanderland;
Don
| Quote: | | http://www.matronics.com/Navigator?Commander-List | 0123456789
12.58 KB |
429 Time(s) |
jtaddington(at)verizon.ne Guest
Posted: Thu Oct 09, 2008 8:17 pm Post subject: HHO |
Don,
A friend of mine and I were talking about it and he says it is 34 times as efficient
as gas and it did not sound that hard to do. He was interested in getting a car to run on it. One problem is if the Hydrogen leaks past the rings it gets into the crank case and can cause a really big explosion. I talked to one of my late wife’s cousins and he said he and some of his friends got a lawn mower to work on it. I was very surprised at how simple it is and wonder why some one is not really pushing hard for it. The friend is really good at electronics and said it could be done for less than $100. He has a certain amount of BS to him but he is a very smart person.
Jim
Subject: HHO
Commanderland;
Don
0123456789
drwer2
Joined: 24 Sep 2008 Posts: 41 Location: Squaw Valley, CA
Posted: Fri Oct 10, 2008 6:04 am Post subject: HHO |
And you wonder why they dont let pilots work on aircraft......
--- On Thu, 10/9/08, Jim Addington <jtaddington(at)verizon.net> wrote:
| Quote: | From: Jim Addington <jtaddington(at)verizon.net>
Subject: RE: HHO
Date: Thursday, October 9, 2008, 9:17 PM
Don,
as gas and it did not sound that hard to do. He was interested in getting a car to run on it. One problem is if the Hydrogen leaks past the rings it gets into the crank case and can cause a really big explosion. I talked to one of my late wife˘s cousins and he said he and some of his friends got a lawn mower to work on it. I was very surprised at how simple it is and wonder why some one is not really pushing hard for it. The friend is really good at electronics and said it could be done for less than $100. He has a certain amount of BS to him but he is a very smart person.
Jim
Subject: HHO
Commanderland;
Don
| Quote: | | - The Commander-List Email Forum - - MATRONICS WEB FORUMS ---> http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. | 01
_________________ No Generality is worth a damn....including this one.
cogito ergo aero-geek |
cschuerm(at)cox.net Guest
Posted: Fri Oct 10, 2008 7:16 am Post subject: HHO |
Don wrote:
<http://www.youtube.com> anything on the HHO, which is the process of
air intake.
I never cease to be amazed at the number of people who think this will
work (no personal insult intended Don).
Let's take as a given that "burning" a fuel releases energy. In a
piston engine, some of this energy is turned into mechanical motion, but
a lot is lost to heat. Net loss in the energy conversion - agreed? Now
we take that mechanical motion and generate electricity. Quite a bit of
energy lost in that conversion as well. Now we take the electricity and
via electrolysis, split a molecule. Certainly a net loss of energy
there as well, not to mention that even a huge electrolysis cell
generates a tiny amount of hydrogen unless fed *huge* amounts of
electricity. Next we're going to take that fuel we created by so many
lossy steps, burn it, and get more energy out than we put into it's
creation ?????
chris
ps: I have some "carbon offsets" I'm willing to sell cheap. I'll take
$45/flight hour for them. Less than 75 hours available, so get 'em quick.
dongirod
Posted: Fri Oct 10, 2008 8:55 am Post subject: HHO |
Chris;
I have read a great deal of the arguments, and I realize there is no such
thing as 'perpetual motion', this said, I have also read many things that
were quote 'impossible' until, something was changed and then it worked,
Mr. Firestone comes to mind with I believe it was sulfur, as well as Mr.
Edison and carbon. So I usually don't just 'write something off', just
because so far it hasn't worked. I also read that God probably made the
perfect compressed hydrogen, its call H2O, something like 1,800 to one
compressions. I try and keep and open mind, one day I firmly believe, a
revolutionary change will happen to greatly improve our internal combustions
engine.
No thanks on the 'carbon credits', I can just put the money in the NYSE, but
I prefer gold.
Don
dongirod
Posted: Fri Oct 10, 2008 9:03 am Post subject: HHO |
I thought they did, have lots of pilot friends who are also A&P and also AI's.
John Vormbaum
Joined: 21 Aug 2006 Posts: 273 Location: SF Bay Area, CA
Posted: Fri Oct 10, 2008 9:16 am Post subject: HHO |
Don,
I love your sense of optimism, and yes, things thought impossible have
been conquered. But sulfur, Firestone, Edison and carbon didn't violate
the First Law of Thermodynamics. The HHO thing is the worst sort of
pathological science. You can't generate MORE energy by recombining H &
O2 (combusting) than you used when splitting the H2O in the first place.
If you had a 100% efficient (as in, no loss to heat or mechanical
inefficiency) method of both splitting & recombining them, you'd end up
with exactly a net-Zero energy production.
I think, if this actually worked, that you could just plug a couple of
electrodes into the ocean and turn the world into a small sun, right?
Perhaps someone will come up with a nice, simple Cold Fusion powerplant.
What ever happened to Fleischmann & Pons anyway?
/John
Don wrote:
Chris;
such thing as 'perpetual motion', this said, I have also read many
things that were quote 'impossible' until, something was changed and
then it worked, Mr. Firestone comes to mind with I believe it was
sulfur, as well as Mr. Edison and carbon. So I usually don't just
'write something off', just because so far it hasn't worked. I also
read that God probably made the perfect compressed hydrogen, its call
H2O, something like 1,800 to one compressions. I try and keep and open
mind, one day I firmly believe, a revolutionary change will happen to
greatly improve our internal combustions engine.
NYSE, but I prefer gold.
Don
rsrandazzo(at)precisionma Guest
Posted: Fri Oct 10, 2008 10:04 am Post subject: HHO |
John-
So this extension chord I'm running over to lake tahoe isn't gonna work
either?????
Robert S. Randazzo
N414C
John Vormbaum
Posted: Fri Oct 10, 2008 10:42 am Post subject: HHO |
Sure, but you gotta plug it into a really BIG wall socket.
Robert S. Randazzo wrote:
John-
either?????
Robert S. Randazzo
N414C
Posted: Fri Oct 10, 2008 11:12 am Post subject: HHO |
John Vormbaum wrote:
John, I purchased the DeLorean used in the movie "Back to the future"
off ebay a few years ago. I've since reversed engineered the "Mr.
Fusion" module and intend to make the design public very soon. Before I
do that, I'm investing heavily in banana peel and empty beer can futures
as that's where I think I'll make my millions. I've also broken the
88mph barrier and am now flying my Aztec entirely on half-empty beer
cans. The only significant technical issue that I've run into is that I
have to drink the first half of the can for it to work right. The eight
hour "bottle-to-throttle" rule has significantly impacted my flying
unfortunately. I'm trying to get an STC for my new designated autopilot
design, but at least one tea-totaling fed at the local FSDO office has
been quite opposed to the whole idea. I'm hoping that if I take him out
to a topless bar and get him highly intoxicated that he'll be more
willing to sign off on the field approval. Always something holding up
progress....
Chris
drwer2
Posted: Fri Oct 10, 2008 11:32 am Post subject: HHO |
Now- now...enough pilot bashing. I think its cute you know enough thermo to order a latte. but if you were really good, you'd figure a way to file STC's without an act of Congress.
Yeah we could use more efficient engines.....but what we really need is a streamlined STC process to put modern engines on some great flying (yet older) air frames. (and I dont mean turbocharged chevy's)
So....Back to the "COMMANDER' list topics.
Bud
--- On Fri, 10/10/08, Chris <cschuerm(at)cox.net> wrote:
| Quote: | From: Chris <cschuerm(at)cox.net>
Subject: Re: HHO
Date: Friday, October 10, 2008, 12:11 PM
| Quote: | --> Commander-List message posted by: Chris <cschuerm(at)cox.net>
the
progress....
Chris
Posted: Fri Oct 10, 2008 12:16 pm Post subject: HHO |
Don wrote:
| Quote: | I try and keep and open mind, one day I firmly believe, a
combustions engine.
Well Don, I applaud your positive outlook. From a purely scientific
perspective, there are very few areas to improve a traditional Otto
cycle engine. Even if some new miracle material were to arrive that
would allow unlimited temperature operation, basic physics still apply.
Small efficiency gains could be had, but there is simply no room for
huge improvement. Energy out equals energy in minus losses. As long as
the "energy in" part involves oxidation of petroleum products, you are
limited by that reaction. Most likely, someone will eventually come up
with an efficient means of directly generating electricity from a
chemical reaction and the next "great advancement" in transportation
will involve electric motors. I'm not aware of any ground-breaking
technology in that arena currently under development though.
cheers,
Chris
drwer2
Posted: Fri Oct 10, 2008 12:44 pm Post subject: HHO |
From an engineering and Thermodynamics standpoint, the internal combustion engine (at least the Otto Cycle) is pretty maxed out. For regular piston-gasoline pushrod or overhead cam engines the total efficiency is dictated by the maximum pressure you can obtain. Lately, higher compression and higher temperatures have pushed the efficiency to the limits obtainable with current materials (aluminum blocks, nitrided steel cylinders etc). computer control of the mixture took it to another level, but noone will allow a micro controller on an AC without going through an extensive Qual process.
Newer High Temperature materials may increase this but absolute "e" is still = [T(high) - T(low)]/T(low).
Diesel's are less dependent on T(high) but are still dependent on the Max pressure. Thats why they are so good at being turbocharged at high altitude. Same goes for Brayton cycle engines (jets). in that case the limits are [P(high) - P(low)]P(low).
Now you know why those old---GSO-480's are still popular. Lots of juice and still efficient at high altitude if you roll back on the throttles. (but who would?)
bud
Subject: Re: HHO
Date: Friday, October 10, 2008, 12:18 PM
combustions engine.
are
cheers,
Chris
Posted: Fri Oct 10, 2008 2:32 pm Post subject: HHO |
willis robison wrote:
| Quote: | Now- now...enough pilot bashing. I think its cute you know enough
No way I'd ever bash John - he's an old buddy and I'm pretty sure he
knows I was just rolling with his humor about cold fusion.
I've heard of a drink called a latte, but don't think it's made it to
Oklahoma yet, so I'll just stick with the beer. I think it's more
likely to perfect cold fusion than streamline STC's.......
chris
John Vormbaum
Posted: Fri Oct 10, 2008 3:14 pm Post subject: HHO |
Chris, remember, ANY Delorean will exceed 88mph, IF you have the proper
Flux Capacitor and a power source that can generate 1.21 Gigawatts.
Chris wrote:
chris
Posted: Fri Oct 10, 2008 3:23 pm Post subject: HHO |
John-
I have a flux capacitor good to 1.21Gw powering all the electric displays we
just put into N414C... I have a spare on the shelf in the hangar just in
case we have to send one out for overhaul.
You guys can borrow it if I get a ride in the delorean OR the bear-can
burning commander.
Robert S. Randazzo
N414C
John Vormbaum
Posted: Fri Oct 10, 2008 3:48 pm Post subject: HHO |
Deal! Right now the only kind of flying I can do is hangar flying. Makes
me want to drink 1.21 Gigabeers and blow my flux into the porcelain
capacitor. Luckily I've matured (well, a little) and will instead remain
stoic until I have new engines hung on 3CC.
/John
John-
burning commander.
Robert S. Randazzo
N414C
Posted: Fri Oct 10, 2008 3:57 pm Post subject: HHO |
John-
How much longer, you think?
Rob
tfisher(at)commandergroup Guest
Posted: Fri Oct 10, 2008 4:01 pm Post subject: HHO |
Back in the early 70's I used to fly John Delorean around in helicopters at
his plant in Fredericton, New Brunswick, Canada.
Tom
C-GISS
