jbr79r(at)yahoo.com Guest
Posted: Sun Sep 28, 2008 8:05 pm Post subject: capacitance probes |
Hi Bob
I have a question regarding capacitance fuel probes. I am having a fuel level reading on my lt tank that was fluxuating and is now reading zero. I am trying to narrow the problem. Probes, analog to digital converter/ wiring / EngineAirdataUnit EAU. My first thing to eliminate is the probe. It has 3 wires red-black-white if that helps.
Jim Robinson
Glll N79R
nuckolls.bob(at)cox.net Guest
Posted: Mon Sep 29, 2008 6:41 pm Post subject: capacitance probes |
At 09:03 PM 9/28/2008 -0700, you wrote:
| Quote: | Hi Bob
Jim Robinson
Glll N79R
Sorry old friend. I'm not familiar with any of the
systems offered to the OBAM aircraft market. I am about
to take on a design task for a new capacity based fuel
gaging system for TC aircraft and I'm looking forward to
adding this technology to my bag of tricks.
My best guess is that if your probe has ordinary bundled
strands of wire for connection, these wires are NOT part
of the capacity dependent fuel sensing system. I would guess
that they are power, ground and some signal wire compatible
with the companion display. Do you have more than one sensor?
Right and left tanks perhaps? Try swapping sensors and see
if the problem swaps.
( -Thomas Paine 1776- )
Posted: Mon Sep 29, 2008 7:23 pm Post subject: capacitance probes |
Thanks Bob
I sent a second message, please disregard. I just jumped the gun
Jim
--- On Mon, 9/29/08, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net> wrote:
[quote]From: Robert L. Nuckolls, III <nuckolls.bob(at)cox.net>
Subject: Re: Re: capacitance probes
Date: Monday, September 29, 2008, 8:41 PM
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
| Quote: | Hi Bob
Jim Robinson
Glll N79R
Bob . . [quote][b]
Posted: Mon Sep 29, 2008 7:40 pm Post subject: capacitance probes |
Thanks Bob
The probe wires run to a analog/digital converter that feeds the display. It is rather difficult to remove the probes so I was hoping to eliminate this as a problem without removal. Maybe someone on the list is familiar with these things.
Jim Robinson
| Quote: | Hi Bob
Jim Robinson
Glll N79R
that they are power, ground and some signal wire [quote][b]
wlively(at)gvtc.com Guest
Posted: Tue Sep 30, 2008 12:54 pm Post subject: Capacitance Probes |
Jim
Could you describe your set-up more thoroughly? What type probes, converter and output volts, ect.
The probes themselve work as a capacitor, two plates with one wire for each. The three wires you mentioned probably go to the converter. Which converts the capacitive reading to probably vdc (0-5 my guess) for your display. If so, you can read the output of the converter with a multimeter and see if that jives with the level reading. You can also set your multimeter to diode check and use that as a voltage source to inject a voltage (1. something if I remeber right)to your gauge and see what level it gives to test the wiring and gauge. Can compare to other side. This ONLY applies if your system is set-up as I guessed.
Hard to say more without more details of the system.
Wade
Posted: Tue Sep 30, 2008 2:17 pm Post subject: Capacitance Probes |
Wade
Thanks for the response. I have Vision Micro probes (lt and rt) that feed into a converter box (analog to digital) then into the GRT EAU. I spoke to Princeston Electronics (they make the converter box) He said that they have had some problems with the older unit I have and they have improved the newer units. He was very gracious to warrantee my units, and is sending me new converters. The new units have some other diagnostic functions that mine don't so that should be helpful. I'll keep you posted.
Jim Robinson
N79R Glll
--- On Tue, 9/30/08, <wlively(at)gvtc.com> wrote:
[quote]From: <wlively(at)gvtc.com>
Subject: Re: Capacitance Probes
To: aeroelectric-list(at)matronics.com, aeroelectric-list(at)matronics.com
Date: Tuesday, September 30, 2008, 2:54 PM
[quote]--> AeroElectric-List message posted by: ""
Jim
to other side. This ONLY applies if your system is set-up as I [quote][b]
